Question about JVC Cybercam GR-D90 Mini DV Digital Camcorder
JVC GR D90 ERROR EO1 UNIT IN SAFEMODE
This is all it tells me and when i reattache the battery it is still the same. david
    Problem Solver:
  • 5 Answers
Hi, when an E0 error message appears it is usualy time to take it to a technician.
Posted on Aug 17, 2008
Jvc gr-d350u. Constant E06 code with either battery or power adapter
if the screen keeps showing e06 device is in safeguard mode """"please remove or reattach the battery""""" If the error continues, please understand that it is a FAULTY BATTERY. This error is very common and results when the battery life has been changed or altered due to time elapsing. There is not a lot that can be done except to request a new battery. I performed more research on this and found that an equivilent may be purchased directly from jvc.com for a fraction of the costs then replacing the entire unit.
Jan 11, 2011 | JVC GR-D347U Camcorder
Shows fault E04 remove & reattach battery
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
Apr 28, 2009 | JVC Video Cameras
EO1 unit in safeguard mode
Try to replace loading motor
In the case the encoder position is not shifted
to the next point though the loading motor has
rotated in the loading direction for 4 seconds
or more. This error is defined as [E01].
1. The mechanism is locked during mode shift.
2. The mechanism is locked at the mechanism loading
end, because the encoder position is skipped during
mechanism mode shift.
3. No power is supplied to the loading MDA
Jan 09, 2009 | JVC Cybercam GR-D30 Mini DV Digital...
01 error code - unit in safeguard mode
I solved the problem! Open the video cassette door. Look closely at the gear mechanism and see if there is any small debris in the gears. If not, using a magnifying glass and a paper clip(must stretch it out and use the tip) gently move each gear(gently). I had my unit ON. Once I moved the gear it became unstuck and ejected Mini DV cassette. I then re-inserted the cassette and it worked. The dreaded SAFEGAURD MODE message was gone and it is as good as new.
Be Blessed
dennis@privatemtglending.com
Aug 26, 2008 | JVC GR-D250 Mini DV Digital Camcorder
Jvc gr-d33 eo1 error in safeguard mode
this is one of many very common problems with JVC camcorders.
maybe one of these wil help you, good luck.
http://www.pechorin.com/m/2004/08/10/JVC_service_or_questions-218073.html
http://www.howtomendit.com/answers.php?id=30228
http://www.greenspun.com/bboard/q-and-a-fetch-msg.tcl?msg_id=00Apdo
for your next camcorder purchase, stay away from JVC products.
Jun 06, 2008 | JVC GR-D33US Mini DV Digital Camcorder
JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Dec 16, 2007 | JVC GR-DVX9 Mini DV Digital Camcorder
JVC Cybercam GR-D90 Mini DV Digital Camcorder Logo
115 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
