Question about Pioneer PureVision PDP-4330HD 43 in. HD-Ready Plasma Television
Pioneer TV External Tuner Problem
My Pioneer Tuner Box PDP-R03E, keeps switching to standy mode for no apparent reason and I can't get it back on. If I leave it for a couple of days, which use to be a couple of hours, it comes back on, but only lasts for a minute, then it switches itself back to standby again. Can anyhone help me with this problem.
  • 4 more comments
  • Anonymous Mar 18, 2008
    I have exactly the same problem with mine, and E01 is written in red on the screen before it stops. The green led (left corner) turns into red and flash... I have found no other solution than yours: waiting !
    If anybody can help me...
  • Anonymous May 04, 2008
    i also have the same problem on mine. sometimes it'll go for weeks sometimes it cut off 1-10 times a night. if I tap gently ontop of the left side it sounds just lke something is loose. the sound only appears with the box switched on. i have had it in several times at specialist but no one has so far located the problem. Excuse my bad english.
  • Ed39 May 20, 2008
    I am having the same problem. The T.V. goes off by it self and sometimes takes the next day before it will come on again. I have called Pioneer and they refered me to a local repair shop, I was informed that there was a problem with some part? they replaced it and it worked for about 2weeks then it started all over again. Today I called Pioneer again and was advised to push the "clear'" indentation on the front of the box. If that did not fix the problem then I could buy another box $500.
  • Anonymous May 31, 2008
    Exactly the same problem.
    It could be overheating, trying to find....
    If anyone finds a solution, let us know. lol
  • Anonymous Feb 23, 2009
    I have the same problem with my 42 Pioneer Plasma, it seem every day it wants to shut down to standby with E01 showing on the screen.
    I leave it for about 10 mins and it restarts fine.
    Please can anyone give me some advise?
  • jmcaudle Mar 08, 2009
    I have the same problem E01, does any know how to fix this?
  • 4 Answers
As you all know this is a very common problem. It is located in the two power boards inside the machine. These media receivers run really hot and the solder on these circuits boards crack, thus losing power when hot. Leave to cool and ok again. To fix you can remove these boards and touch each solder joint with a fine tip soldering iron until it becomes molten then move on to the next joint. Do all the joints, reassemble and presto, you should be back in business. These board are located between the on-off swith and the rear power input. It is a little fiddely, but if you halfway competant, then it shouldn't be a problem. I've done it a couple of times now, so if anybody feels a bit nervous, I'll do it for them for a small fee. contact glangford@tycoint.com
Posted on Jan 14, 2010
  • Glangford Jan 14, 2010
    Might be helpful if Boktan2001 could let everyone know where he got the switch from and any part numbers please. Thanks
  • philipram607 Dec 07, 2010
    Well done.At last a clear and concise explanation.I nearly took a hammer to mine.Pioneer may as well have asked me to drop my trousers and touch my toes!!!!Cheers fella.I'm on it now.......
I had all of the above symptoms and I ended up having to send the box back to Pioneer in California and paid $500.00n for it to be repaired. It is been working fine since that time (about nine months ago.) I wish I had been like (Boktan2001) and fixed it myself for $5.00..... Ed39
Posted on Sep 24, 2008
Ive had exactly the same problem and found it to be the on/off switch. I replaced this myself cost me £2.50p and have had no trouble since. Hope this helps.
    New Friend:
Wonderful tip! ***** thank you very much in my case it was the soldering too panasonic used minimum amounts of solder so this must break after a while Thanks guys
Posted on Aug 07, 2015
I have had exactly the same problem on and off for a while where I get E01 and the screen turns off and have had engineers out loads of times with no solution found but when googled recently got the same advice as from'Glangford' above and he is absolutely right it is the joints that need re-soldering. We just asked our local tv repair guys and they did it and brought the media box the same day and we've not had the problem since - it really does work!
Posted on Mar 28, 2010
Posted on Jul 14, 2009
So i've the same problem E01 appears on the screen, then the screen switches off and the green led turns into red and flash!
I've to disconnect the power and wait....
Who knows the solution?
Posted on Aug 18, 2008
Pioneer plasma model PDP-507XA. how can I tune a TV channel?
The PDP-507XA only has an analog tuner. You will need a set-top box (digital to analog converter) to receive over-the-air signals in most places. For analog cable, you need to set the source to TV. Press the Select button, if needed (it's above and to the left of the arrow keys), to put the remote in TV mode. There is also an Input button on the TV. If the Channel Up/Down keys do not work, you need to reset the TV Press the Home Menu button. Navigate to the Setup menu (Up/Down arrows followed by Enter) and select Auto Installation. Enter your password for the TV; the default password is given in the manual on page 41. It's available from Pioneer here: docs.pioneer.eu/Manuals/PDP_507XA_ARE1430_manual . Set the Language (use the Up/Down arrows followed by Enter. Then use the Left/Right arrows to change the setting). Then set the Country. Press Start to begin a scan for channels. Alternatively, select Analogue TV Setup and enter the password. Then identify the correct receiving system. Manually enter the channels in the Search area. Set Store to Yes to save channels.
I hope this helps.
Feb 14, 2016 | Pioneer Televison & Video
Pioneer pdp 507cmx has no sound does this tv have speakers
Yes,every tvs have a basic pair of speakers.Tries tv unplug,replug it back like about an hour later.Go into the tv Menu go to PICTUTRE SETTING go down to do a resetting for a back to factory setting of the whole tv main Tuner signal board.Go to Audio Setting go down to a resetting for the factory audio setting.Tries these steps,tv now should have sound back.
May 10, 2011 | Pioneer PDP-507CMX Television
I have a Pioneer Media Reciver PDP-R03E but no
I have a remote control for the PDP-R03E that you can have for £15. email me on glangford@tycoint.com
Oct 10, 2009 | Pioneer PureVision PDP-4340HD 43 in....
Plasma Display Starting Up
Could be heat build up in the Plasma display unit. Make sure it has the correct space around it for proper ventilation. Also count the number of blinks on the power indicator it is a code for the reason the unit shut down. On the Pioneer PDP-5060HD I have I was getting 12 blinks on the indicator which indicated a tuner issue. Check your instruction book for info on the over heating problem if it continues. You may have a fan out.
Apr 29, 2008 | Pioneer PDP-5060HD 50 in. Plasma...
Pioneer pro 506 pu 3 lights stuck on
You activated the trap switch. You must now call an authorized Pioneer service center near you. They are the only people that know how to deactivate it.
C-Dog
Feb 10, 2008 | Pioneer PureVision PDP-4340HD 43 in....
PDP-4330HD
This exact same problem happened to me 2 weeks ago on my Pioneer PDP-4330HD, and it did indeed turn out to be the power supply. The good news is, you can get it fixed for free, because Pioneer actually recalled the power supply in this plasma and others a couple of years ago.
Here is a link to the announcement on their website concerning the recall. They say that they will do a free in home replacement of your power supply, but when I called the local pioneer repair place, I was told I would have to wait three weeks for an in-home appointment. I ended up taking it in myself, and it was fixed for free 2 days later. Now it works perfectly.
Here's the number to call Pioneer in case the link goes down:
1-800-421-1404
Nov 10, 2005 | Pioneer PureVision PDP-4330HD 43 in....
Pioneer PureVision PDP-4330HD 43 in. HD-Ready Plasma Television Logo
2,541 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
