Question about SanDisk Sansa c200 MP3 Player
Device not been identified
My MP3 player was working perfectly from past 6 months. I removed all filed from the player. from then when plug it into USB and try to access it my computer says insert disk in the drive. Please help me solve this problem.
RAvishankar
  • lambour Mar 24, 2008
    vista not recognized my sansa
  • Pdebra Apr 14, 2008
    I have the c100 and everytime I plug into the computer it says device not reconized? I need help..
  • 8,596 Answers
Lambour - go to Sandisk website for Vista drivers
ravi, pdebra -
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 28, 2008
SOURCE:
How do I download songs on my eclipse mp3 player
Things You'll Need
Microsoft Windows 7 computer with an open USB port and iMesh installed
USB cable compatible with Eclipse MP3 players
Instructions
  • 1 Plug a USB cable into the Eclipse MP3 player. Plug the other end of the USB cable into an open port on the Windows 7 computericon1.png.
  • 2 Click the "Start" button on the Windows 7 desktop taskbar and click "Computer" in the menu that appears. Click the "Music" item located in the left pane of the "Computer" window that appears. Double-click on the "iMesh" folder. For Windows 7, XP and Vista. Recommended. Download Now.
  • 3 Click the "Start" button on the Windows 7 taskbar and click "Computer" and then double-click on the "Removable disk" icon that represents the Eclipse MP3 player device. A window will appear displaying the contents of the Eclipse MP3 player storageicon1.png area.
  • 4 Right-click on a music file in the "iMesh" directory that has the "mp3" suffix, and click "Copy" in the menu that appears.
  • 5 Right-click on empty space in the "Removable disk" window and click "Paste" to copy the music file to the Eclipse MP3 player device. Repeat for each file you wish to download to the Eclipse MP3 player.
    To copy multiple music files at one time to the Eclipse MP3 player, press and hold the "Shift" key on the keyboard. Click once on each file you wish to copy. Right-click on one of the highlighted MP3 music files and click "Copy" in the menu that appears. Right-click on empty space in the Eclipse "Removable disk" window and click "Paste."
Oct 21, 2014 | Audio Players & Recorders
Where do you plug in the mp3 player to transfer music?
You MP3 player will be supplied with USB cable. Attach the cable to the MP3 player and plug the other end of the cable into a computer's USB port.
The computer will see this as an removable device, you can then open this device and copy mp3 music files from your computer and paste these files into your MP3 player.
Nov 07, 2010 | Compaq Presario 5000 PC Desktop
How to transfer music into my NWDB105FB MP3 Player
plug-in to cpu or computer at usbch you2.0 port, click computer, search your device, click on music files then right click to file/copy- open your device, riht click/paste
Jul 31, 2010 | Sony NWDB105FB MP3 Player
I need instrutions to put music on it
1st you need to plug your mp3 player to a usb port on your computer. then You open the file on your computer with the music you want to put on. then go to the my computer icon on your computer then you open the removible device. Doubleclick on it then make a new folder in it called MUSIC then you go back to the music file and you high light the music you want on it then you copy and paste the mp3,or wma format and paste them in the folder you just made.
Feb 22, 2010 | Sears GC-822 MP3 Player
Sansa m240 files won't show up on computer
Uninstall/remove the mp3 player from the device manager of windows while its plugged into you computer and unplug afterwards from your usb port and plug it back in, windows now sees a new device and starts installing it.
Go to the configuration panel\system and click at the tab hardware and klik at the button device manager.
This should solve the problem.
Succes.
Aug 31, 2009 | SanDisk Sansa m240 MP3 Player
How do I download Pictures to MP3?
A generic procedure is :-
  1. Turn on your computer. Plug the USB cable that came with your MP3 player into an open USB port on your computer.
  2. Step 2 Turn off your MP3 player and plug the other end of the USB cable into the USB port located on top of the player. Turn on the player.
  3. Step 3 On your computer, right-click the pictures you want and select "Copy" from the menu that appears.
  4. Step 4 Double-click the "My Computer" icon on your computer. Double-click "MP3 player " or ' MP3 Device" in the "My Computer" window.
  5. Step 5 Open the "Pictures" folder. Right-click and select "Paste" from the menu that appears.
  6. Step 6 Let the files copy. Click the "Safely Remove Device" icon located on the left side of the Start toolbar at the bottom of your screen.
  7. Step 7 Click "Safely Remove USB Storage Device." Wait for a message to appear that says it is safe to remove the device, and then unplug the USB cable from your computer and your MP3 player.
Hope i helped you.
Thanks.
Aug 30, 2009 | Audio Players & Recorders
AMT MP3 PLAYER USB 2 DEVICE VIRUS PROBLEM
It could be that _your_ computer is virus-infected, and it tries to infect any device that you connect to your computer.
Find some other computer with "current" and "good" anti-virus software.
Connect the device to that computer.
The anti-virus software should both _detect_ and _remove_ the computer-virus from the device.
Then, on your computer, download and run the Microsoft MRT (Malware Removal Tool): http://support.microsoft.com/kb/890830/
Also, on your computer, download and run the virus-scanner from: http://www.prevx.com
to "clean" your computer.
Then, once your computer is "clean", connect all the USB devices that you have, and virus-scan each one of them.
Jun 15, 2009 | SanDisk Sansa e250 MP3 Player
GPX MW3847 MP3 QUESTION
Uninstall all GPX software first. Try Windows Media Player again. If Windws Media still crashes, uninstall then reinstall Windows Media Player.
-Tha Mp3 Doctor
Sep 04, 2008 | GPX MW3836 MP3 Player
Iclick sohlo7 mp3 player problems
borre el programa device cuando estaba borrando mis canciones como le hago para recuperarlo
Dec 21, 2007 | iClick Sohlo 7 MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
