Question about Gateway FPD2275W LCD Monitor
Picture problem after replacement of burnt resistor ,now picture of monitor is horizontally small.
    Novelist:
  • 138 Answers
You might want to try another smaller value of resisters I guess. Before you do that, check and adjust image setting using the screen buttons.
Posted on Mar 16, 2008
How to solve horizontal lines on a CRT TV monitor and what could be the possible courses for it
Monitor horizontal lines problems usually caused by a defective vertical output/driver ic. A missing supply voltage to the vertical output ic may caused similar faults which is one horizontal line across the display. Dry joints and missing vertical output pulse from vertical oscillator ic also could contribute the same symptom. If you discovered that the protection resistor (usually from 1 to 4.7 ohm) open circuit or burnt, then replacing it won't solve the problem. The resistor burnt or open circuit was due to a short in the vertical output ic. Thus you have to replace the vertical output ic and the burnt resistor together before you switch on the monitor.
Jun 12, 2015 | Televison & Video
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
It is a crt 17"
if its a cathode ray display its got vertical scan problems then its the line timebase more than likely a resistor gone high value or a leaky capacitor take the board out and have a good look for burnt out resistors and printed circuit damage change any electrolytic capacitors
Feb 22, 2018 | Zenith Computers & Internet
Kds vs-f14
There is usually an identical resistor somewhere else on the circuit board, so if you cannot read the colors of the burnt one, you can read the colors from an identical resistor on the same board. If you just replace the resistor, it will probably just burn out again or damage another component, you have to find the cause of the resistor burning out, most likely an electrolytic capacitor failing. Look for bloated or seeping capacitors and replace those as well. Also look for broken or burnt toroid coils.
Jul 15, 2008 | BenQ FP731 17" LCD Monitor
View Sonic monitor
I have Viewsonic 15" CRT Monitor (model E53)
When power ON, ther is only a colour patch appears on the middle of the screen . I observed some resistors and three transistors in horizontal sections were burnt.
I cannot read the real values of them because they are burnt.
Please kindly can you tell me those real values in that section.
Jun 13, 2008 | ViewSonic Computers & Internet
Resistor
LG 500G MONITOR
The problems is this set powersupply indicator led is blinking
Jun 12, 2008 | Acer AC713 17" CRT Monitor
Burnt resistors
Depending on where you bought the ICs you could have fried the new ICs when powering it up with burnt resistors as the green is controled by both ICs one IC controling the horizontal green Convergence and the other IC controling the vertical green convergence. Have you checked all the convergence resistors out of circuit?
May 18, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Convergence problem
replace the stk-392-110 (x2) and any burnt resistors. cost 20$
Nov 19, 2007 | Panasonic PT-47WX42 47" Rear Projection...
NEC FS-8001
NEC is famous for under rating it seems there sets. Not sayying that the sets are not good but I've seen hundreds of NEC with what looks like over heating. I too hace seen several power supply problems and it comes to mind that a small choke that looks like a small resistor with wire wrapped around it has been the problem several times as you must also take out the parts that looks burnt and clean the area and take off all the overheated solder and clean up the pcb and reinstall and resolder with new solder if you want to not have intermittant connctions again. Oh almost forgot that these coils are on the output of the power supplys and make sure you check all the caps as well in the output of the power supplys as well as in the sweep supply as this can cause your sort of problem as well.. Good Luck PS if a resistor looks burnt they are so cheap you should replace it as resistors that look or have been overheated can and will breakdown under power or a load.
Apr 11, 2006 | NEC FORTRON/SOURCE 145W POWERSUPPLY...
Gateway FPD2275W LCD Monitor Logo
35 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
