Question about Jenn-Air JGS8750 Gas Kitchen Range
A Bad thing happened..
I have a Jenn Air JGR 8855 gas AOS range. It is seven years old. The broiler was accidently left on high for about four hours. {Yes, what a ******** - lucky the house didn't burn down} Everything still works, except that when we turn oven or broiler on, we smell noxious smell like burning plastic. We turned it off, felt all around to feel if anything hot, as we suspected electrical fire, but found nothing. We can continue to use the burners. Everything works. We took out all the trays in the oven, the bottom plate and hand cleaned, but thinking we toasted some electrical insulation or something. Any suggestions? Is this thing toasted?
  • dalriadalass Mar 16, 2008
    addendum. The smell seems to come from the top control panel area. Again - everything still works.
Sorry's i don't have a solution for you, but I need your help , because I just bought a same model and I don't have an instruction booklet , is-it possible for you to send a copy of principal instruction by email.
Thanks very much
Posted on Mar 18, 2008
  • Jenn-Air Master
  • 2,651 Answers
Honestly cant think of anything magor that could have happened.. there are saftey thermstatsin key locations around the unit turning the unit off of a runnaway temp is detected.. altoughthe broilerwas "on" for 4 hours im sure it had been cycling on and off for that time not constantly on.Figure your self cleaning cycle lasts for 3hours and om sure attains a much higher temp then just running broiler.. NOW all that being said,a call to a local servicer to inspect for possible damage couldnt hurt for the piece of mind!!!!
Posted on Mar 16, 2008
Broiler does not light....Put in new ignitor; still not working. Checked orfice to make sure its LP and not Natural gas. Its number is #56...Is this correct for LP?
The Jenn-Air Broiler LP broiler orifice is part number: AP4091112. A picture of the part is here: . (To me the number looks like 65 to me. The natural gas version is number 47.)
Check the current draw at the igniter. (The meter must be in series with the igniter. I know the bake igniter needs to be above 3.2A.) Other possible causes of the problem are a selector switch problem or the glow bar. (These are things to check if the oven works.)
I hope this helps.
Jul 30, 2011 | Jenn-Air PRG3601P Gas Kitchen Range
Jenn-air dual fuel jds9860aap intermitently display blinks like it lost power, reset and it will happen again. originally started with a f9 code that has not reoccured. If the oven is on, it will shut off...
Sounds as if you have a bad ground or nuetral wire connection. Unplug and check the connections to your control assembly and the pigtail on the range. I have also seen displays on Jenn-air go bad as well.Replace the clock assembly.
Apr 19, 2011 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Gas oven doesn't work. Broiler does.
Hello - Most likely failed lower burner ignitor. Tests good if above 4ohms. Part is 40$. Can give replacement instructions if needed. Let me know if this helps. Thanks. -ED
Mar 03, 2010 | Jenn-Air JGR8875QDS Gas Kitchen Range
Oven wont bake
sounds pretty simple a bake element
Oct 03, 2009 | Jenn-Air JGR8750 Gas Kitchen Range
Cleaning surface grates on 10 year old Jenn-air Gas-electric
Spray them w/ oven cleaner, put them in a plastic trash bag, and let them sit overnight. They should clean up w/ minimal scrubbig.
Sep 18, 2009 | Jenn-Air Kitchen Ranges
Jenn air gas/elctric slide in range self cleaning does not work
Apr 02, 2009 | Jenn-Air JGS8860BDP Stainless Steel Gas...
Jenn-Air Electric range clock display
The problem is likely bad capacitors on the clock module. I had the same problem on a similar oven and fixed it by replacing the capacitors on the clock module. Find someone who is good with electronics to help you. The parts will be a few dollars at most. See this link for more info:
Oct 06, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Jennair 8855 F9 error
take a 24 inch peice of coat hanger make a small u in one end and insert it from the left side gentlw fish for the door latch hook and pull it over to un latch the door and let me know if the code goes away
Jul 12, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Usually you need to turn the temperature to broiling (high), some require the door to be open about 2 inches (assuming yours has a detent (hold) there.)
Apr 25, 2008 | Jenn-Air JGW8130A Electric Single Oven
Jenn-Air JGS8750 Gas Kitchen Range Logo
284 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
