Question about Philips 55PP9401 55" Rear Projection Television
Where can i buy remote control for phillips 55pp9401?
I got this set from a friend. converge is bad and i want to try manually adjusting convergence before i attempt to replace the IC's. problem is he lost the remote - does anyone know where i can procure a remote control for this set?
Thanks!
  • emakina Mar 16, 2008
    thanks, but I'm looking for the specific remote because of of the intellisense function. I don't think a universal remote will have that function or the programming to the get into the service menu where you have to take a battery out and press certain trigger keys.
  • emakina Mar 18, 2008
    does anyone have any advice? or do i just have to basically throw out the tv.?
You can access the Intellisense with any universal remote that has a settings button.
TV > Settings > Video > Scroll down to find Intellisense.
Posted on May 26, 2008
  • 32 Answers
Get a full universal at your local walmart for less then 20 with full menu and program functions, get a phillips brand and no programming required.
Posted on Mar 16, 2008
  • Anonymous Mar 19, 2008
    try www.remotes.com
2 Suggested Answers
SOURCE:
  • 1694 Answers
SOURCE: how doi adjust convegence manually on phillips 55pp9401
Order service manual from partstore.com ..........
procedure is complicated..............T.
Posted on Dec 10, 2007
We no longer have the remote for model 55pp9401 and we have a convergence problem what can we do
Here's the Philips support URL for your TV:
www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=55PP9401&slg=en&scy=US
PDF download of your Owners' manual:
http://download.p4c.philips.com/files/5/55pp9401/55pp9401_dfu_aen.pdf
Here's what Philips FAQ says about your convergence procedure:
Question How do I adjust convergence (align colors)? Answer Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
Press the INTELLISENSE button on the remote (under the flap). During the convergence process DO NOT press the INTELLISENSE button again and DO NOT move the Projection TV.
So, I think you're going to need to order a replacement remote.
search "replacement remote" at http://www.philips.com
May 13, 2011 | Philips 55PP9401 55" Rear Projection...
Don't have remote is there another way to line up colors I've already changed the convergence chips but not the resistors
Chances are the new ICs have failed since the 6.8 ohm resistors werent changed a phillips will almost always blow one or two of the 6.8 ohm resistors and if new ICs are installed without replaceing the resistors the new ICs are usually destroyed by the blown resistors. You will need the original remote or authorized replacement to adjust the convergence properly.
May 06, 2011 | Philips 55PP9401 55" Rear Projection...
I have a Phillips model 55PP9401 TV and there is no red color, but the picture is still good. What do I replace? The corners are also losing clarity? Please Help! Thanks
Ur convergence it dead.Must know how to solders?Buy a convergence kit,replaced what in that kit.Tries Tv repair World.com,Tvrepairkits.com
Dec 23, 2009 | Televison & Video
My picture has red ghosting. I tried to perform
This set has a bad convergence amp ic. This can be a complicated repair involving in depth convergence adjustment. You may be better off having a shop check it out for you. Thanks for using fixya.
Dec 12, 2009 | Philips 55PP9401 55" Rear Projection...
Intellisense button
If the model number on the set is 55PP9401/55 you have an interesting set----this model says Philips but was made by Hitachi---they made them for Philips for one year while Philips was gearing up to produce their own sets---very good set and is better than the Philips sets that came after it.
It uses (if it is this model) two STK-392-110 CONVERGENCE IC's----both need to be replaced and the set adjusted---no need for an original remote---with the set engaged in the convergence adjustment mode( there is a micro switch on the front of the main circuit board) A HITACHI REMOTE CAN THEN BE USED TO ADJUST THE CONVERGENCE. Hope this was helpful.
Aug 11, 2009 | Philips 55PP9401 55" Rear Projection...
Convergence problem
reset your tv with defaults settings.f chip and resstor blown then it need change.
Jan 06, 2009 | Philips 55PP9401 55" Rear Projection...
Lost remote / convergance problem
u can not set the convergence without the remote control just look on the web they are between 30 and 60.00 dollars
Oct 07, 2008 | Philips 55PP9401 55" Rear Projection...
55pp9401 convergence problem
try aligning them using the yoke control rings.
sometimes the alignment is so far out that you have to adjust the magnet rings instead.
Feb 25, 2008 | Philips 55PP9401 55" Rear Projection...
How doi adjust convegence manually on phillips 55pp9401
Dec 08, 2007 | Philips 55PP9401 55" Rear Projection...
Phillips 55PP9401 Convergence Problem
STK392-110 convergence IC's upgrade to STK394-160.....
I use Hitachi brand part # CZ 01341 ... change both.......
Check for dis-colored resistor (s) = replace with exact value...
Please respond............T.
Aug 12, 2007 | Philips 55PP9401 55" Rear Projection...
Philips 55PP9401 55" Rear Projection Television Logo
510 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
