Grundig Satellit 500 "Radio Boy"
No AM and SW, FM comes in fine. Radio worked on 3 times for this same thing. Still get AM for a short time and then just humming. It never comes back to any AM stations. Can you help me?
Runnynose
    Brigadier General:
  • 6,966 Answers
Offhand, can you pls try and do a reset. This model don't have a reset button, but you can try removing the batteries for say an hour or so. The idea is to reset the microprocessor if the problem is software/firmware. Preset/memory would be erased as well as any personalized settings if you do this. But the unit will be back to factory default.
If the reset doesn't work, then your particular version/model has a slight offset resulting to the "humming sound". This is a known problem and many in the "ham" world have written corrective procedures which would require an insulated tuning/alignment screwdriver or at the very least a jewellers screwdriver and doing a bit of alignment by "ear"
If you are adventurous to give this a try, pls post back. Otherwise your best bet would be to seek the services of a qualified ham radio technician.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 16, 2008
2 Suggested Answers
SOURCE:
  • 58 Answers
SOURCE: I have a Grundig Satellit 500 "Radio Boy"
If you sent it in 3 times, then I would suggest getting a new one if you know for sure that other's work in that area. If other's don't work, then then you have some type of interception between the radio waves and your radio. There is nothing I can do about that, and probably nothing you can do.
Otherwise, you should get a new radio.
Grundig satellit 800 antenna replacement
Assuming its broken outside the unit: most aerials are very similar to fit, serving the exact same function and not worth the cost of locating the exact same one used for your model due to time, and purchase costs.
Find an old transitor radio with similar sized aerial, ie length and diameter to fit your radio. Measure it and the replacement from an old radio you or a friend does not need.
Purchase a small screwdriver to remove and refit aerial to your grundig. Small sets of screwdrivers can be bought cheaply from discount stores, ebay etc.
Jul 13, 2011 | Grundig Satellit 800 AM/FM/SW Radio
I just got grunding 800 radio,no reception either am,fm ,sw please help me.
This is valid for the Satellit 750 by Eton (current owner of Grundig)
When you use it the first time you go through a system code setting to fix the memory page configuration, the AM gap between stations, the type of batteries and FM frequency range.
If it is used in North Ameraica, you are told not to go through procedure but do it any way.
SYSTEM Code setting
Turn Radio off and press a quick short press on the ENTER Button. -- appears on the upper right corner of the display
1. The first code could be 00, 20,25 or 50, meaning the memory is divided into 10, 20, 25, or 50 pages.
2. The second code fixes the AM frequency gap between stations. Enter 09 for 9kHz or 10 for 10 kHz (in North America)
The 3rd code selects the type of batteries used 29 for D size batteries (1.5V each) or 28 for rechargeable batteries (1.2 V each)
The 4th code concerns the FM frequency range: 76 for a range 76-108 MHz (for Japan) or 87 for a range 87-108 MHz
Read your manual to see how the procedure is performed, or try this one valid for the Satellit 750. It might work. Go through all the procedure and press ENTER to confirm system code.
Aug 11, 2010 | Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 800 LCD display doesn't work correctly
If the radio uses memory batteries, try changing these with new alkalines. The microprocessor needs this power to drive the display.
Jan 30, 2010 | Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 800 powers on but no sound on any bands or modes. It appears to have a signal on AM but nothing on FM. It's completely dead and the MAIN large tuning dail will not function either. All...
HI,
THE FIRST THING YOU HAVE TO LOOK FOR IS WHAT KIND OF ADAPTER 9V 1AMP YOU SHOULD
HAVE FOR THAT PARTICULAR RADIO AND ANTENNA FOR SW AND FM SHOULD BE CONNECTED.IT MUST BE THE ADAPTER THAT'S ON THE OUTS NOT ENOUGH VOTAGE TO POWER THE RADIO.
Jun 30, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Mar 16, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 500 loses reception
Hi
I had such a pb.
IC 103 CX7961 stopt to oscillate after ~30s ...
so the plls ref was out
I changed it without results
In fact the plastic trimmer C138 (4-20pf) was bad???( insulation?)
Since changing (10 years ago) : no problem
Good luck
Dec 13, 2007 | Grundig Satellit 800 AM/FM/SW Radio
Loses sound
It is soppoused to seek when pressing search and scan and scan buttons If you dont like the idea of that for now on only use tuning up and down dial or buttons.
Nov 20, 2006 | Grundig Satellit 800 AM/FM/SW Radio
812 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
