Question about Microwave Ovens
I have thin baked on sticky residue in my microwave. How do I clean it without damaging it?
    Scholar:
  • 104 Answers
Wet a hand towel or multiple layers of paper towel and lay it over the sticky residue and turn the unit on high for 20 to 30 seconds to heat it. Then use a plastic spatula to scrape it off. The heating should loosen it up and the plastic spatula should be safe to scrape without damaging it.
Posted on Mar 16, 2008
6ya staff
SOURCE:
How do I clean the stainless steel interior of my electrolux icon microwave
Hello - Interior cleaning after convection, mix or broil cooking:
Spatters may occur because of moisture and grease. Wash immediately after use with hot, soapy water. Rinse and polish dry. Harder to remove spatters may occur if oven is not thoroughly cleaned or if there is long time/high temperature cooking. If so, you may wish to purchase an oven cleaner pad with liquid cleaner within it-not a soap filled steel pad-for use on stainlessor porcelain surfaces. Follow manufacturer's directions carefully and be especially cautious not to get any of the liquid cleaner in the perforations on the wall or ceiling or any door surfaces. Rinse thoroughly and polish dry. After cleaning the interior thoroughly, residual grease may be removed from the interior ducts and heater by simply operating the oven on 450 F for 20 minutes without food. Ventilate the room if necessary.
Interior cleaning after microwave cooking:
Cleaning is easy because no heat is generated to the interior surfaces; therefore, there is no baking and setting of spills or spattering. To clean the interior surfaces, wipe with a soft cloth and warm water. DO NOT USE ABRASIVE OR HARSH CLEANERS OR SCOURING PADS. For heavier soil, use baking soda or a mild soap; rinse thoroughly with hot water. NEVER SPRAY OVEN CLEANERS DIRECTLY ONTO ANY PART OF THE CONVECTION MICROWAVE OVEN.
Nov 09, 2012 | Electrolux E30MO65GSS Convection Microwave...
Unable to eliminate odour from previous cooking despite the fact that I wipe the microwave with a soapy cloth & then with a clean cloth each time to Microwave is used
  1. Fill a plastic bowl with 1 qt. of warm water. Add 2 tbsp. of liquid dish soap and 1/4 cup of chlorine bleach to the water. Thoroughly mix the solution.
  2. Dampen a clean cotton rag in the solution. Wipe all inside surfaces of the microwave with the soapy rag to remove food debris and stains. Scrub stubborn residue with a nylon scrub brush.
  3. Moisten another cotton rag with warm water. Wipe the microwave surfaces with the rag to wash away soap and loose food debris. Thoroughly rinse the inside of the microwave.
  4. Dry the microwave's interior surfaces with paper towels. If odors remain in the microwave, fill a microwave-safe bowl with 1 cup of cool water. Add to the water 2 tbsp. of baking soda, half of a chopped lemon (including pulp and rind) and four whole cloves.
  5. Place a microwave-safe plate on the microwave turntable. Set the bowl on the plate.
  6. Heat the microwave on high for three minutes. Operate the microwave according to the manufacturer's directions. Keep the bowl in the microwave for 15 minutes.7
  7. Remove the bowl from the microwave. Wipe the microwave's interior surfaces with clean paper towels to remove steam moisture.
  8. Leave the microwave door open overnight to completely air out any remaining odors.
  • Sep 05, 2012 | LG LTM9000 Microwave Oven
    Is it best to clean a Teflon skillet by hand or can you put them in the dishwasher?
    This is what Dupont the maker of the cookware coting has to say about cookware care:
    2. "What is the best way to clean my nonstick pan?" Simply wash with hot, soapy water after each use. A sponge or dishcloth is usually all it takes to get the surface thoroughly clean. If oil or food residue is left on the pan, further cooking will harden the residue and cause sticking over time. For pans that have "carbonized"-where a thin film of oil has baked onto the pan-we recommend you use a little more elbow grease when cleaning in order to break through this layer. Future cleanings will be as easy as with new.
    http://www2.dupont.com/Teflon/en_US/products/qanda_cookware_care.html#careq2
    Nothing about a dishwaher in the above. It appears you should wash it by hand.
    Thanks for choosing FixYa,
    Kely
    Jun 19, 2011 | Microwave Ovens
    Stove fire smoke on microwave above stove.what will clean off this smoke residue? we encountered a stove which left a heavy smoke residue on the microwave above. the microwave has a plastic handle and...
    Mr. Muscle Kitchen cleaner will remove the smoke. It won't hurt the plastic. Just make sure to either wear rubber gloves or wash your hands soon after cleaning off the smoke residue. It will make the skin on your hands / fingers slick and then dry after your done. Let the cleaner sit for about a minute before trying to wipe off the smoke residue.
    Mar 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
    Bosch microwave door sticking
    I have the same issue on a later model, and the cam that releases the door is a poor design and only works if well lubricated.
    You can lubricate the end of the engagement catches with some silicon oil or similar which worked for mine, although I did disassemble to understand the problem
    Jan 10, 2010 | Bosch HLK4525GB Convection/Microwave Oven
    I was storing the rack to my microwave in my regular oven where I also stored plastic. It melted on the microwave metal rack and I need to know how to clean it off. It is mainly sticky plastic residue...
    Hi plastic residue as I expect you have discoverd by now is very difficult to remove. I have found that paint thinners are very effective when used with a scouring pad.
    Hope this helps
    Jan 07, 2010 | Microwave Ovens
    Difficulty cleaning Electrolux High Speed Oven
    Most that say no oven cleaner have a self clean. If your does not. Take ammonia and wipe inside down and set a bowl of it inside over night. This will help a lot. One of my grandmothers tricks. It works great.
    Please rate solution.
    Sep 02, 2009 | Electrolux ICON Microwave Combination Oven
    Sparks and Flames in my Kenmore 66561652100 Microwave
    usually the only thing i'm aware of that will do that is if there is some kind of metal object in the microwave when you cook... even plates with thin painted metalic bands on the cause that affect.
    remove the hook... place a container filled with water inside the microwave for about a minute to aid in cleaning... and examine the hook for any metal.
    Mar 23, 2009 | Kenmore Microwave Ovens
    Cleaning vents
    GE Spacemaker Profile X1800.
    I would take out the grills and boil them, but cannot see how to do that.
    Also, the GE stove top (Model JGSP44BEY) has so much baked on crud that I may never use it. I poured a whole bottle of easy off onto it and still cannot loosen it all. Same goes for the removable parts from the burners.
    May 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Microwave Ovens Logo
    63 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Marvin
    Marvin
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
