Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Blank Screen - Panasonic PT-50LC13-K
Hello, I have a Panasonic PT-50LC13-K (rear projection) TV and it has some issues starting. When I plug the TV in and power up the TV, it shows a faint light in the background of the full screen and then some green lines and then it fades to a full black screen. During this time the sound of the channel is being played through the TV speakers. The power button shows a solid green light, but there is no display on the screen.
Once you turn it off and properly wait for the lamp to cool and the power button to become a solid red. I unplug the TV for 5 seconds and plug it back in and power on the TV, sometimes it will work and power up to the the proper display, other times it will just show a brief light on the screen, then the green lines and fade to black.
I am trying to find out if this is a known issues, or if the TV is worth fixing or not?
Thanks,
Ben
Hey Ben, The TV is alerting you it is about time to change your light bulb, it will keep on doing this until the light bulb just dies.
Order your Bulb via On Line at any of the places, there are different prices, but average for the authentic one with the chasis included is @ 260.oo and only takes @ 5 days to get delivered. You can save up to 140.oo if you just order the pure light bulb, and go the extra mile changing it, I just explain someone how to about it, only takes you 30 mins. Good look, I hope I get help for my problem too.
Posted on Jul 30, 2008
Is Worth Fixing Panasonic PT-50LC13-K Rear Projector TV
most likely a bad mainboard or bad caps in the power supply. Borderline on the repair-ability. I would check Shopjimmy.com to see if used parts are available. If they are it may be worth it.
Sep 14, 2015 | Panasonic PT-50LC13 50" Rear Projection...
Why does My PT-50LC13 panasonic has a green tint to the entire screen ?
Hello, the optical block or light engine which ever you want to call it has gone bad, it's a very common and expensive repair to which I do not recommend doing. I would put the money into a new set. I'm sorry for the bad news.....tks
Sep 02, 2014 | Panasonic PT-50LC13 50" Rear Projection...
PT-50LC13 reset lamp timer
Replaced the Lamp, on my PT-50LC13 pan TV. But cannot reset the timer because the screen does not light up. and the instructions say to hold down the -Vol button and the pip button. But which one? there are 3 buttons with the word PIP
Apr 02, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Pt-50lc13 is it a HD tv?
It is a HD ready TV meaning that it may not have a HD tuner. If you have cable this should not be an issue but if you want to receive HD channels through the air, then you would need a HD tuner.
Mar 01, 2010 | Panasonic PT-50LC13 50" Rear Projection...
I need a diagram to change the air filter for my Panasonic 50'' LCD TV PT-50LC13
hello here is my email address i'll send it to you for free superred@talktalk.net thanks
shaun
Oct 28, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Need to replace bulb in lcd panasonic
After lamp replacement, make sure that lamp cover is properly fixed on its location and if TV still does not turn On then it is ballast power supply issue, qualified TV tech will fix it.
If you think you can repair ballast supply and have enough knowledge about TV repair, let me know to provide you technical info about that.
Oct 02, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 reset hour meter
on the tv itself push the volume down button and at the same time using the remote control press the pip button. I just did this on my tv - had the same problem. it worked perfectly. Jeanne
Jun 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic projection TV power blinks in orange 5 times every 5 seconds
did you ck the lamp,  can you ck voltage to ballast should be around 300 volts
Oct 23, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
426 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
