Question about Dryers
Dryer starts on it's own when timer is turned or door is shut
I have a whirlpool electric dryer LER4634DQ1 that works great but it began starting up as soon as timer is turned or door is shut. The start button feels OK but I'm worried it may be a fire hazzard
  • jmguypack Aug 20, 2008
    I have the same problem with the electric dryer
  • 156 Answers
Its the door switch more than likely are less likely the push start button stuck
Posted on Mar 16, 2008
SOURCE:
Whirlpool dryer LER7646E02 will not turn on
Could be something as simple as a broken belt or door switch is broken. Open top and check if the belt is still in tact. If yes, then check door switch to see if electrically closing when door is shut (check resistance with power off).
Jan 11, 2014 | Whirlpool Dryers
My Whirlpool electric dryer does not shut off when a load is done. The door must remain open in order for the dryer to stop. Other than that, the dryer works perfectly. Is it a switch or the timer or...
Pull the dryer out from the wall and take the vent hose OFF it is in the back, and then try it on auto-dry with no clothes in it and see if it runs through fine if it does not turn off then a new timer should fix it. Good Luck Tim. here is a website that will help click on timer motor, or you can use the virtual repairman:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 23, 2010 | Whirlpool Dryers
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
I have an electric whirlpool with start switch not working
OPEN THE DOOR/PUSH THE START SWITCH ON DRYER/THEN PUSH THE DOOR SWITCH/HAVE A PERSON TURN THE DRUM/IF IT STARTS TO TURN (DRUM) OR STILL HUMS AND DRUM WILL NOT TURN YOU HAVE A BAD MOTOR/REPLACE MOTOR.
FREDDY
Feb 14, 2010 | Whirlpool LGB6300 Gas Dryer
Whirlpool LER5644A No heat and motor wont Turn
Replace the dryer wires.
Put your meter leads into the 4&5 slots.
Make sure the door switch is closed or jumpered.
Push the start button.
If you read no voltage the issue is with the wiring, the timer, or a relay.
Mar 11, 2009 | Whirlpool LER5636P Electric Dryer
Dryer starts on it's own - won't shut off
TRY DISCONNECTING THE START BUTTON WIRES AND SEE WHAT IT DOSE WITH THE DOOR CLOSED,IF IT DOES NOT START IT YOUR START SWITCH-MIKE
Feb 16, 2009 | Whirlpool LER5636P Electric Dryer
Dryer wont start
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208522243.pdf
if possible, with the door open, push the limit switch the door normally hits to let the drier know the door is shut. That switch may be bad.
Dec 27, 2008 | Whirlpool LEQ9858P Electric Dryer
Roper dryer won't shut off
The timer motor isn't moving the timer. You'll need to replace the timer. Turning the timer **** to off should stop the machine.
Exception: If the shutting the door automatically starts the motor, then the start switch/relay is probably shorted.
Mar 10, 2008 | Roper REX4634KQ Electric Dryer
Get dryer to work, no instruction manual for Indesit Washer WDG 1195 W
What to check when your dryer won't start-
The wall outlet 240 volts:
The first thing to check when your Whirlpool dryer is not starting is the wall outlet to make sure that the dryer is getting the proper voltages. On an electric dryer there should be 240 and 120 volts present at the terminal block.
A blown fuse or tripped circuit breaker are one of the major causes why the dryer won't start. To check the voltage on an electric dryer you will need to use a multimeter.
The wall outlet 120 volts:
A gas dryer connects to a 120 volts wall outlet, and it is very easy to check the outlet. Disconnect the dryer and connect a hair blower or any other small appliance on the outlet.
If they work, then the problem must be on the dryer. If the don't work, check for a blown fuse or tripped circuit breaker. If the problem is bigger than that, have a license electrician check the house wiring. A bad wall outlet could be the reason why your Whirlpool dryer is not starting.
The thermal fuse:
The thermal fuse is use on an electric dryer as a safety devise to open the motor circuit if the operating thermostat fails to open at the preset temperature or if the motor draws too much amperage.
A blown thermal fuse could be the reason why your Whirlpool dryer is not starting. It is located behind the back panel on the dryer.
The door switch:
The door switch is another safety device use on the dryer. It is connected on the neutral line of the motor circuit. A door that is not closing properly or a bad door switch could be the reason why your Whirlpool dryer is not starting.
The push to start switch:
The push to start switch is use to start the motor. There are two types of switches. The older type switch is a solenoid operated door switch and the other one is a simple push to start switch.
A bad solenoid operated or regular push to start switch could be the cause why your Whirlpool dryer is not starting.
The timer:
The timer is the distribution center or the brain of the dryer. Inside of the timer is that the electricity gets routed to the different electrical parts in the dryer.
The timer has contact points, and the contact points wear or burn out depending on the amount of use. Contacts burnt inside of the timer, could prevent the dryer motor from starting..
The motor:
Also, the motor could be burnt bad. A motor that smells like rubber burning, makes growling noises, runs for a wile, the won't start until is cool down or a motor that runs fine, but the centrifugal switch is not making the right connections is a bad motor and must be replace.
So...as you could see, there are many parts that could be the reason why your Whirlpool dryer is not starting.
Feb 16, 2008 | Washing Machines
Dryers Logo
119 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
