Washing machine i have a bosch washing machine which is filling up and draining but not spinning when there are clothes in it. i have run it on a cycle of rinse and drain and it is draining but not spinning it is make all the noises but working. could this be the bushes or something more serious
  • kazz2 Nov 17, 2008
    i have this same problem with my bosch classixx 1000 E-Nr wfl2062gb/12. don't know if this model has carbon brushes or where they are????
  • 16 Answers
UNPLUG THE MACHINE BEFORE CHECKING!
It is Usually the Brushes on the Motor that cause the problem. The Brushes DO wear out on all Brush Motor washing machines eventually. How quick depends on USE and Manufacturer.
In my experience Most Bosch Brushes last between 3 - 8 years before requiring renewal. You will need to remove the brushes to check how much carbon is remaining.
Replacement Brushes are available. It would help if you provided your E.NR ( number ) which you will find on a label on the inside of the Door.
Posted on Mar 16, 2008
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
Spinning cycle
Keeping in mind that the soap & bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water. Is your cold water valve screen plugged causing your washer to rinse poorly? Are you using the HE detergent? If not maybe the washer is sudsing up to much and having a hard time rinsing all the suds and bleach out and leaving the clothes soapy.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up? Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is a lot higher than the top of the washer it might have a hard time draining out all of the soap water before the next load
Mar 23, 2008 | LG WM-2277HW Front Load Washer
Fills with water then does not rotate, also does not spin
Check for large items of clothes being tangled if the Bosch washing machine doesn't spin. The weight could not be evenly distributed in the drum and the spin cycle will have been disabled to prevent damage to the clothes..
Load the drum with large and small clothes together and run the entire washing cycle and spin cycle again.
Add more powder and run the entire washing and spin cycle again if you haven't found tangled large items, but the spin cycle still failed. This indicates the amount of cloths was too small.
Add 1 tablespoon of fabric softener to 1 pint of water and pour it into the main detergent dispenser if there's no tangling and the load was a normal size. The cause would have been excessive suds because of too much, or the wrong kind, of detergent. Use HE (High Efficiency) detergent in Bosch washing machines.
Nov 01, 2010 | Bosch Washing Machines
Hi, our simpson enduro 701 washing machine does not spin back and forward in the deep rinse cycle. but operates ok and spins in spin cycle. thankyou Tina.
Hi Tina just read your posting. From the information in your posting the machine fills, then when the machine is full of water the agitator moves clockwise then anticlockwise until it gets to the rinse cycle then drains the water ,then it fills for the rinse cycle but does not move the agitator in the rinse cycle.Then it drains and spins the clothes dry .Is this assessment of your posting correct.If it is not 100% correct please reply to tell me what the machine is doing or not doing.If it is correct then the problem with your machine is the control board.Is your model the electronic one with the push buttons?Looking forward to your reply.
Jun 26, 2010 | Washing Machines
My washing machine is washing but not drainning well and not spinning well please help model classixx 1400
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
May 24, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
Sep 26, 2009 | Admiral AW22 Top Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
IFB Bosch washing machine.
I have an IFB washing maching it does not spin dry the clothes any solution
Mar 24, 2008 | Maytag Performa PAV2200
Washing Machines Logo
386 people viewed this question
Top Washing Machines Experts
