Question about Hotpoint First Edition WMA20 Front Load Washer
Hotpoint first edition
Machine will not start wash door open light comes on when door is fully shut
  • 1 more comment
  • rainbow26 Mar 18, 2008
    the door does fully lock
    sorry the door doesn't fully lock it can be opened after pressing the start button
  • Anonymous May 11, 2010
    Is the door actually locking or can it be opened after pressing the start button?
  • 16 Answers
UNPLUG THE APPLIANCE - Hi sorry about the delay - the door needs to lock before anything will work - So - Either the door lock is faulty or the circuitry to the door is faulty.
The door lock is not too difficult to replace. Engineers reach it by going through the front ( where the door seal connects onto the front panel)
The lock connects directly to the Timer/circuit board so if it is not the lock it will be the timer board.
Hope this helps
Posted on Mar 22, 2008
6ya staff
SOURCE:
Hi, I have a Hotpoint wm53w first edition 1200 and the door light does not come on when the door is shut. When I switch it on and set a programme, the amchine sometimes does not start, the door light
Generally the problem lies with a faulty door interlock switch rather than a programmer fault. These are can be purchased easily but don't be fooled into buying cheap alternatives, and if you are a competant diy person no problem to fit.
Feb 27, 2014 | Hotpoint BWM12 Front Load Washer
Door will not open have wash cycle
Switch off, put in spin/drain cycle and switch back on; check water is fully drained and then check filter. If not all drained, lower hose to ground level and drain to a bowl.
Apr 28, 2012 | Hotpoint Washing Machines
Washing machine door wont open - hotpoint
Never reach inside the washing machine with it connected to the mains. The door interlock is always live.
There are several reasons why a Hotpoint door could be jammed shut.
•A broken door catch or door frame where the door catch screws in (they are rubbish on many Hotpoints - always breaking) you can sometimes get the door open if you push the door firmly in as you open it
•If there is water still inside the washing machine, then the door wont open either on these Hotpoint washing machines (not on some others though) If this is the case, when you try to open the door the ****** won't try to move down at all. You can open the door usually if you drain the machine. (only applicable with door interlocks that have a rubber pressure hose attached to them)
•A faulty door interlock
•The pressure chamber can be blocked on some earlier Hotpoint washing machines which gives the same effect as having water in the machine. Basically the washer "thinks" there is water in when there isn't. This would require the washing machine being stripped down to remove and clean the pressure chamber bottle. This cause is only applicable to washing machines where a small rubber hose is connected to the door interlock. This hose allows the door mechanism to be locked and unlocked by air pressure activated by water rising inside the pressure chamber bottle attached at the other end on the tub. Gunge can block the very small aperture where the pressure hose fits to the pressure chamber bottle.
Thanks for contacting fixya.com
Nov 07, 2009 | Hotpoint First Edition FEW12 Front Load...
My hotpoint few10 washing machine wont work,it wont come on at all and none of the lights at the front come on
On some front load clothes washers, the door has a safety interlock switch that prevents the washer from operating if the door is not fully closed (or the door / safety interlock switch is not aligned or broken.)
I would check that first. Please report back, OK?
Apr 20, 2009 | Hotpoint First Edition FEW10P Front Load...
Hotpoint first edition washing machine door will not open after completing its full cycle
hi from the uk susan ? this is not uncommon and easily fixed if you are confident DIY ? and req's a little patience with a posi drive screwdriver if you want to save $$$$s on call out fee ? the problem is most probably the time delay switch which prevents door opening too soon after cycle/machine has finished and the light has gone off then door can be opened if you feel confident ? will help/instructions on how to rectify fault if you reply back ?
Apr 15, 2009 | Hotpoint First Edition WMA12 Front Load...
Door will not lock on my Hotpoint Aquarius WMA35 1100 Spin
i would get a new door or catch from the hotpoint website hope this helps
Jan 24, 2009 | Hotpoint WMA40 Front Load Washer
Washing machine not working
I Put A Set Of New Brushes In motor And It started
Jan 17, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint first edition few 12p,not working
parts are free but a call out charge is made approx £80.00
Washer door won't open (hotpoint first editon 800)
I have just had exactly the same problem. 10 seconds of washing, fuse blew, replaced it, cycle completed but now the door lock is stuck on. Like you I tried a new cycle but this has done nothing. In the end (and I'm not suggesting that this a remedy to the problem) I unplugged the machine - pulled the door handle til a gap appeared at the top of the door and forced it open by working a pair of scissors in to the gap and pulling. Of course as soon as I shut the door again and turned on the power the lock light came straight back on the and the door was locked tight. Sorry but this is the best I have come up with short of calling some one out.
Aug 13, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint First Edition WMA20 Front Load Washer Logo
178 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
