Question about Microsoft Windows Vista Ultimate Edition
E drive/ cd drive
Thank you for your concern. what actually happened is, i right clicked on the E drive/ cd drive and one of the options that came up was "safely remove." i did not know what this meant, i thought that it meant eject cd! when i selected the safely remove option it deleted the link to the cd drive and the computer dosen't seem to recognise cd when they are inserted. is there a way to get the E drive / cd drive back?
  • da-rok Mar 16, 2008
    i figured this out myself. lol. the computer said to simply remove the actual drive from the tower then put it back in again. all fixed. funny problem put [email protected]#$% lol
  • 31 Answers
User Himself already commented the solution....
Posted on Mar 25, 2008
SOURCE:
My laptop says boot from ahci cd-rom operating system not found and i have no disk but i can switch it on and press f2 which brings me 2 the set up utility but then i dont know what 2 do
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
if you need more help with this or if I have misunderstood the problem post a reply
hope this helps you
Sep 28, 2011 | Samsung R519-53S Notebook
How can I add NEW files to my portable drive Seagate Expansion 500? Thank you, Mike
click start click on computer to open you should see your drives C: and your other drives cd dvd and your usb drive E: or F: from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to usb drive then drop them example on how to safe data/files to a usb drive
click start all programs accessories open windows explorer navigate to your data
right click on the data select copy navigate back to the usb drive right click select paste or select the data hold the mouse cursor then drag the data to your usb drive then drop it in
or if you are downloading data from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device or a usb device
if you need more help with this post a reply
hope this helps YOU
Sep 11, 2011 | Seagate 500GB USB 20 5400RPM Portable 500...
Unable to boot dell xps 420 into safe mode in order to retrieve data files and copy them to an external drive.
Can you explain what files you wish to retrieve and what version of windows the dell is running
Mar 12, 2011 | Computers & Internet
Dell Inspiron 1420 dvd icon missing, what had happen
Try the following *Check weather required driver for your DVD drive is installed or not(in Windows 7 it automatically installs drivers) if yes.......try this.....
*If you are using Windows operating system Go to Start>Control Panel>Hardware and Sound>Device Manager>select DVD/CD drivers>Right click on your name(Name appears after clicking arrow beside DVD/CD drivers option)Ridht click on your device name>Select enable
Thank you Don,t forget to rate
Jan 28, 2011 | Dell Inspiron 1420 Notebook
My dell inspiron 1545 refuses to boot after gone to sleep
This happen to my 1525 and XPS system when I upgrade to Win7. Check your power option by going into your control panel --> hardware and sound --> power options -->advance setting or just click the battery icon on the bottom right by your clock and click "more power option". You can change it to where it will not turn off your hard drive when in sleep mode. I recommend checking the Dell recommended setting. You may also need to update your bios, system firmware and hard drive drive firmware. you can download from Dell support. Enter your service tag # to get the right firmware specfic to your system. If it still fail than you will need to take it to a tech for more troubeshooting of the hard drive or mother board.
Jan 09, 2011 | Dell Computers & Internet
My Acer Aspire One only loads in Safe mod. I cann't run any diagnostick tools like Hirm's Boot CD from an external CD drive, which is connected via USB.
This happens when set you PC on Safeboot Option.
Follow the steps mentioned below to boot in normal mode.
1: Once you are in the Safe Mode, Click on Start and then Click on Run.
2: Type msconfig (you will see system configuration utility).
3: Click on Boot.ini tab and check for the Boot Options.
4: You will see Safe boot options check.
5: Uncheck it then click on apply and then then ok.
6: Now your computer will boot in Normal mode.
Once you reach the desktop you will again see the system configuration utility screen. Just check the option don
Dec 18, 2010 | Acer Aspire One Netbook 8.9" Notebook
Need help formatting new hard drive , Thx in advance Setup steps say "Double-click the Lacie icon in My Computer to get the Lacie Setup Assistant" and that didn't happen .
The LaCie hard drive should have come with a CD. If you pop that CD in, then their directions make more sense:
1: Put in the LaCie CD
2: Double-Click on "My Computer" to open windows explorer
3: right below the "Local Disk (C:)" you should have a LaCie icon for your CD-rom -- double-click this icon for their setup assistant.
If you don't have a CD-ROM, you can still use the drive but it's more involved.
1: right-click on "My Computer" and select the option "Manage"
2: On the left panel of Computer Management, you should have an option "Disk Management" under the heading "Storage" - click on Disk Management
note: The Disk Manager shows your current disks in the top right panel, and ALL disks in the bottom right panel. You might need to resize the window to see them all.
3: In the bottom right panel, find the grey-ed out box that corresponds to your new disk, and right-click on it. One of the options will be to format it.
4: After formatting, if it doesn't automatically come up with a drive letter, you can once again right-click on it in the bottom right panel of the Disk Manager and assign it a drive letter.
Once it has a drive letter, Windows should see the drive and you should be good to go!
Jul 31, 2009 | LaCie Computers & Internet
HL-DT-ST DVD+RW GWA 4164B DOENSN'T WORK
open explorer and go to 'My Computer'
right click the DVD/CD-ROM Drive
click on the tab labeled 'Recording' (usually on the far right)
click the option that is labeled 'Enable CD recodring on this drive'
...and POOF, magic happens...
Dec 31, 2008 | Computers & Internet
Using Dell oem xp sp2 installation disk to do sfc
there is always an option where it says whether u want to install windows,it will not do that before u give permission..there will be a repair option too..what u can do is right click on the C drive and use the options to check for errors..hope it helps!
Nov 19, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
