Question about Apple Epson Stylus C80 InkJet Printer
Epson C80 printer
How do you cleanthe printer heads?
  • Anonymous Jan 25, 2009
    I have contacted Epson Support and have read the instructions on the Epson utility disk for cleaning the heads on my Epson C80 printer. However, I cannot find the link to Head Cleaning anywhere (i.e., not on the Epson C80 utility disk, not in the maintenance section of that I have accessed through the Control Panel, and not when I right click the printer icon in the task bar), How do I access Head Cleaning for the Epson C80?
My printer prints a little red but no black
Posted on Aug 28, 2009
You need to post your OS.
usually what i do in Vista.
start, settings, control panel, printers, click on the printer, right click properties, click printing preference button, the window that pops up will have 3 tabs, click on third, maintenance, you should see head cleaning, nozzle check, and alignment.
if you are looking for a way to clean the head because that utility doesn't work, you need to go to fixyourownprinter.com and get the special head cleaning kit which comes with solution to do this.
Posted on Feb 14, 2009
6ya staff
SOURCE:
I need a driver
"http://mac.brothersoft.com/epson-stylus-c80-driver-x-download.html"
that is the link to the driver for your pinter rate this solution
Dec 19, 2009 | Apple Epson Stylus C80 InkJet Printer
Won't print
Epson printers will typically not print if any of the print cartridges are empty.
Nov 06, 2009 | Epson Stylus C80 InkJet Printer
Colgged printer heads on an epson c80 printer
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, you can try soaking the print heads for 24 hours (or more), as follows.
Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results.
Mar 19, 2009 | Apple Epson Stylus C80 InkJet Printer
I have an Epson C80 and want to remove its head and replace new one how can do it?
preachw996 is absolutely right, officially, of course, BUT it is perfectly possible for us ignorant, sub-normal users to do it too! The key thing is, do you have a replacement print head? If not, repeat your query when you have one! If you do, come back with a new comment and I will provide the information you need, step by step, do do this.
Mar 14, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Need steps to install epson stylus c80 printer to computer
Drivers, Software, lost C.D....come this way!
If you have lost you cd or don't know how to install your printer then all you need to do is download the drivers and software from the manufactures website that suits your operating system and printer.
Nov 19, 2008 | Apple Epson Stylus C80 InkJet Printer
Printer making electronic buzzing noise
In the absence of a response from this poster, we can only assume he has solved this problem. So, let's archive it as "Poster Solved".
Oct 31, 2008 | Epson Stylus C80 InkJet Printer
Ink cartridge carrier jam
Once it jams on the left turn off the machine. usually my lights are all red at that point, one is blinking the other two are solid red. open the cover. shine a flashlight in there, you will see a clear or light grey plastic ribbon that runs from the left to the right. it is the top most thing. Very carefully, clean it with a paper towel and a little water. or a kleenex. it should be almost clear.
after done, move the cartridge head to the right without turning on the printer. once again, clean the clear plastic ribbon where the cartridge head was located. finally turn on the printer, when it stops initializing, click the paper feed button, if you were successful, you won't see it jam into the left side.
if not, try repeating again. I think the optical head could also have some junk on it, and will deposit it back on the clear grey plastic strip.
the clear strip passes through the cartridge head. I'm told it is called an encoder strip and the optical head reads the strip to know it's position.
when that strip is dirty or covered with some ink spots, the print/cartridge head, can't read it and slams into the side the the printer.
this happened to my c80 at least 3 times now in seven years.
Feb 09, 2008 | Apple Epson Stylus C80 InkJet Printer
Epson C80 - single color won't print
If you still have this problem, please open a new comment & I promise I will help you fix it! Otherwise I think we can consider it solved!
Mar 25, 2007 | Epson Stylus C80 InkJet Printer
EPSON SYLUS C80 indicates "printer error: paper jam"
Epson has an interactive troubleshooting guide on their support site. http://www.epson.com/cgi-bin/Store/support/SupportIndex.jsp From the link above, choose your model printer. You will then be brought to the main page of your printer. Then, click on the "interactive help program" link under the Troubleshooting Guide section. Through this, you will be able to find an article describing what all the indicator lights mean and how to possibly resolve the issues.
Sep 21, 2006 | Epson Stylus C80 InkJet Printer
Apple Epson Stylus C80 InkJet Printer Logo
190 people viewed this question
Top Apple Office Equipment & Supplies Experts
jasbo
jasbo
Alun Cox
Abdul Mannan
Abdul Mannan
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
