Question about Smartdisk - Peripherals - HARD DRIVE, CROSSFIRE 160GB EXTERNAL (XG160F)
Verbatim 120GB external hard drive
I recently purchase a Verbatim 120GB external hardrive and I backed up a Windows XP home edition computer, and attempted to transfer it over onto a Windows XP professional computer. When I went to My Computer to open the drive, it called itself Removable disk (E:) and when I attemted to open it, presented me with the error message "Please insert a disk into drive E." When I checked under properties, it showed 0 free and used space. Please help.
  • Borusick Mar 16, 2008
    If I do it, do I loose the data that is already there backed up from another computer?
    I cannot do it.
    It says REMOVABLE DISK NO MEDIA
  • 32 Answers
Goto Control Panel, administrative tools, Computer Management, Disk Management, If it pops up a new disk install wizard follow the directions in it. If not then find the new disk that has no partition on it, right click on that drive to create a partition, then right click on the drive to format it, if it hasent done so already.
Posted on Mar 16, 2008
  • Anonymous May 10, 2008
    going back to basics, open my computer first before pluging in the drive. to make sure you know the correct drive letter that appears when you connect the USB drive to the computer. Also this way you can make sure the computer see the drive as being connected to the computer when you plug it in. and not a memory card reader that you may have showing up as drive E. then if it connects make sure that your windows XP professional has Service Pack 2 installed for proper LBA (large block addressing) support. As your XP home addition may have this support, and the XP professional may not. Third possability is that your drive may not be compatable with USB ver 1.1 if your not using a USB 2.0 port to connect the drive. another possable problem is that your USB driver in windows XP is courpt, but this would result in the lack of running any USB device on your computer. Please email me at [email protected] if you have any specific questions.
6ya staff
SOURCE:
The USB plug has loosened itself inside the hardrive how do I fix it?
Look up Verbatim in the phone book. Find their phone number. Speak to customer service and they will repair/replace your unit free of charge, even if you don't have proof of purchase. I know, I just got my unit back, all fixed!
Mar 23, 2014 | Verbatim 160GB USB FireLite: The "drive...
I have a Simpletech pininfarina 120gb external hard drive that I used to back up my computer.
did you purchase the storage sync program youmight not be able to download that version again unless you pay for it
if you can or want another free backup utility
save this to a document then click on it to open and download second back up free edition
http://dw.com.com/redir?edId=3&siteId=4&oId=3000-2242_4-10405044&ontId=2242_4&lop=linktitle&ltype=dl_elite_gen&pid=10999341&mfgId=6272401&merId=6272401&ttag=lst-4&destUrl=http%3A%2F%2Fdownload.cnet.com%2FSecond-Backup-Free-Edition%2F3000-2242_4-10405044.html
hope this helps
Nov 12, 2011 | SimpleTech 120GB SIMPLEDRIVE PORTABLE USB...
320 external hardrive
Most commonly, 297 GB is the formatted capacity of the 320 GB hard drive. You can check if there is any unpartitioned space left on your hard drive. Right click My Computer, click Manage, click Disk Management, locate the hard drive which shows 297 GB (a big reactangle). If this rectangle is all the way from left to right, everything is fine. Else it will also show another rectangle next to it as Unpartitioned space which you can format and use.
May 29, 2010 | Western Digital My Book Essential Edition...
2 usb plugs which goes where??? maxtor 120gb external hardrive pn9nx2dc-500
You have what is call a USB POWER Y ADAPTER: this is designed to provide extra current to your USB HDD drive from a second PC USB port. Plug the end with two USB connectors to your PC/LAPTOP and the single-ended plug to your drive.
Hope it helps! Let me know how you go.
Dec 30, 2009 | Maxtor OneTouch III Mini Edition 120GB...
1TB Verbatim external hardrive not recognized
Try taking the drive out of the enclosure and buying a usb adaoter that will fir the interface the hard drive has...either EIDE or SATA, then hook that up to a usb port and see if the computer will load it. May be the controller card in the enclosure is your problem.
Sep 02, 2009 | Verbatim VER95327 USB Hard Drive
Verbatim external hardrive not showing up on computer?
A Hard disk making noise, does not sound too good. if it was waorking before on both PC's & not having issues then it has to be with the unit. try on a nother computer. if its the same thing i suggest you look for that warranty card of yours.
Jun 09, 2009 | Verbatim 160GB USB FireLite: The "drive...
Can't open My WD Mybook Home edition 500 GB External Hardrive
sounds like the hard drive is failing... i suggest you find yourself a data recovery program soon
Jan 05, 2009 | Western Digital My Book Essential Edition...
Verbatim 250GB External Hard Disk not recognized by PC
Almost always, when a USB drive doesn't assign a drive letter in MY Computer the issue is a Mapped network drive using the drive letter the USB drive is attempting to use.
With the drive connected, open DISK MANAGEMENT find the USB Drive, right click it and assign it an available drive letter.
Jun 12, 2008 | Computers & Internet
Re problem with maxtor one touch 111 Mini
Try downloading the most recent one-touch drivers for xp that are available and installing those.
Nov 03, 2007 | Maxtor OneTouch III Mini Edition 120GB...
Computers & Internet Logo
235 people viewed this question
Top Smartdisk - Peripherals Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Smartdisk - Peripherals Computer and Internet Expert? Answer questions, earn points and help others
