Question about Asko T701 Electric Dryer
Noise our asko 701 dryer has had continuous problems.  now, it's making a noise--really loud vibrating hum.  a repair guy fixe it once but i don't know what he did.  thanks in advance for the help. chris
Hey.  I had the same problem with my 701 about a year and a half ago.  A great tech came out and had a very simple solution that fixed the problem: clean out the fan.  A lot of lint collects down there and causes the dryer to become incredibly noisy.  It's so easy to do and whenever the problem resurfaces - every 4 months, or so - I now take care of it myself.  To see if this is the same problem you're having, just pop the lower panel off, then remove the fan cover (you'll just need a screwdriver for each).  You can pull the fan out and remove any lint that's collected, and wash with a brush and water.  Replace everything and see if it solves the problem.  Good luck.
Posted on Apr 29, 2008
    Sergeant:
  • 351 Answers
Remove the drum and check the front rollers,and the jockey pulley/belt for wear.also grease the jockey pin,you need to know how to remove the back panels on these asko dryers so you may want to ring asko to do it.remove all outer screws, centre nut and three screws left side about 3 inches up from base.hope this helps.
Posted on Mar 20, 2008
Why does my gas dryer make a loud vibration noise?
Hey friend, I appreciate your post!
I understand that your Electrolux gas dryer is making a loud vibration noise and is also loud while tumbling. There are several components in your dryer that could be causing this noise. Based off what you are describing it might be an issue with your suspension rollers, motor, or pulley. Since it could be any of these underlying issues I would suggest getting a technician out to diagnosis and repair your dryer. Hope this is helpful. - Matt
Jul 21, 2014 | Electrolux Dryers
Frigidaire electric dryer (model # LEQ1442ESO) is making a loud noise. It's like a loud humming or vibration. Is it the motor?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 08, 2011 | Frigidaire FEQ1442ES Electric Dryer
Gas Dryer making loud humming noise and vibrating. It just started doing it.. it was not a slow progression.
heatman101
Nov 04, 2010 | Frigidaire Dryers
I get a loud humming noise . The dryer works good but makes a loud humming noise when it's working .
The motor is going bad and this will make that loud humming when it is running...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 25, 2010 | Maytag Dryers
LG DLE2516W Dryer suddenly making loud vibrating noise
Until you know how serious a problem you have, I'd advise against continued use. If you are in the USA, go to http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp
to find a service provider for in warranty service, or call LG USA at 800-243-0000.
Aug 18, 2009 | LG DLE2516 Electric Dryer
My t712c asko dryer is making some loud noises.
heatman101
nfgnc
May 04, 2009 | Asko T712C Dryer
Dryer making clicking sound, humming and vibrating hard
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up "
Apr 23, 2009 | Frigidaire GLGR331A Gas Dryer
Asko T780 Dryer Vibrating/Grinding noise
Sounds like a bad roller. You'll have to remove the drum to get at them. Even a free one may make noise at speed. Use high temp grease. Also check roundness. And don't forget the belt tensioner roller, just don't get any grease where the belt touches.
Apr 23, 2009 | Asko T781 Electric Dryer
Loud Humming noise every time we run the dishwasher
Hi, I had this exact same problem. In my situation it turned out to be the pump that pumps out all of the used water. It was rubbing up against the floor so that every time it turned on it made a loud vibrating sound. I just reached under the washer and put a piece of rubber between it and the floor and it solved the problem.
good luck!
I saw this post because I am considering buying the same model you have. Other than the noise problem you have, what do you think of it?
Mar 29, 2009 | Jenn-Air Dishwashers
Vibrating and noise after cleaning
heatman101
ioipuio
Jan 04, 2009 | Frigidaire FDE336RE Dryer
Asko T701 Electric Dryer Logo
333 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
