Home | Apple | iBook Blueberry Mac Notebook | Cant send e-mail wit...
Apple iBook Blueberry Mac Notebook
Problem for Apple iBook Blueberry Mac Notebook
Cant send e-mail with entourage
By gaillouise1 on Mar 16, 2008
I have a blackberry which i can receive  and send messages I can receive messages on my laptop i cant send messages .on my laptop  my e-mail address is gail@gailshopping.com
Comments:
Mar 16, 2008
- the server says the recipients or server refuses to allow you to send mail
Mar 16, 2008
- for sending a message its
smtp.gailshopping.com
Mar 16, 2008
- I would like an answer now please can you help with this problem or not
my e mails are with entourage
address
I cant send e mails
the server message
the server did not recognize the recipients or server refuse to allow you to send mail
smtp.gailshopping.com(port25)
Mar 16, 2008
address
I cant send e mails
the server message
Mar 16, 2008
- i dont understand your help
how do i fix it
Mar 16, 2008
- sorry i just paid for this help i dont understand what to do i do not understandcoputers thats why i paid for your help
Solution #1
posted on Mar 16, 2008
Somewhat Helpful)
ginko
Rank: Guru  Apple Expert Computer Hardware  Expert
Rating: 89%, 4933 votes
Common cause for it is bad entourage settings.
Which error message do you get when sending mail fails?
Comments:
Mar 16, 2008
- I need to know the following to help you further:
which computer are you using (eg.mac)
Any error message whe mail not sent (eg. Error: 5500)
do you use additional software to send emails? (eg outlook, netscape etc.).
If you can receive but not send mail then probably is smtp server settings.
I will have to leave in minutes , In case I do not get your answer soon, expect replay to them tomorrow
regards
Mar 16, 2008
- If it is the recipients then may just be a matter of wrong address, double check them , and check that you have the same problem on a tested correct address(eg. info@fixya.com ).
Most likely it is a problem witht he server, check smtp server settings on your mail software and on entourage.
It may also be a problem that does not depend from entourage.
It would be useful if you can post a screenshot of exact error message and eventually of your mail server settings.
regards
Mar 16, 2008
- The problem is with smtp.gailshopping.com. You usually get in trouble when you use smtp server provided with your hosting.
You should use smtp provided from internet service provider.
For example if you use wannadoo broadband in UK , then you need to use smtp.wannadoo.co.uk.
You need to check with your ISP for correct smtp settings.
Contact your internet service provider and find out your smtp name, user and password.
You may need to change the setting called 'server requires authentication' in outlook or other mail software.
This above is the solution, ask your hosting company or ISP, they will confirm easily . I wasted 20 minutes of my time to type it for free for you. therefore I will be grateful if you can remove the negative rating you just game me.
Best regards
Mar 16, 2008
- CALL your ISP, Get SMTP server, user ID and Pass from ISP, for (example: smtp.telecom.de, user:aaaaa pass:bbbbb)
Put the new ISP smtp server (example:smtp.telecom.de) in outlook (or whatever you use) settings.
Use this server. Call ISP tech support, there is people payed to tell you this information over there.Also ask them if their smt requires authentication.
ISP=company giving you broadband service
(smtp=simple mail transfer protocol, used to send mail)
Goodbye
Mar 16, 2008
- If you tell me which is your ISP (for example: french telecom) and your area I can find smtp information for you. Then you will have to just put smtp This is useless for me as you refused my solution on start (well thanks a lot ), I think this happened because rating system is quite confuing.
thanks
Mar 16, 2008
- If you do not understand anything about computers you should have gone for the chat or for your ISP/hosting free customer support.
Mar 16, 2008
- gotta go now, call your ISP and ask smtp details, this will fix it.
Mar 16, 2008
- Tell me where you did get Internet service (wannadoo, telecom etc.) and where you are located (LONDON PARIS etc.) I will find Right SMT info, only I cannot post them before tonight.
All the best
Ginko
Mar 16, 2008
- Here is SMTP list for Europe.
Find SMTP for company from which you have broadband. Put SMTP details for company providing you broadband, For example if you are paying tele2 in France put "smtp.tele2.fr" use broadband user id and passwor to configure new SMTP.
Replace smtp.gailshopping.com with new one.
Try if it works.
If it does not work go back to SMTP settings and chose "server requires authentication" Put user ID and passwd provided for your broadband in settings.
If you are not able to perform the simple operation above, then I suggest calling a technician .
I tried to be as coincise and precise as possible.
If be willing to give me your ISP (company giving you Internet service) information I can be even more precise.
In any way you have all the information you need, this should fix your problem.
Best regards and thanks.
Solution #2
Not Rated)
djnick999
Rank: Guru  Computer Hardware  Expert
Rating: 87%, 73 votes
u will need to call a tech ok this fix is beyond u the avg compuser call local tech ok
Popular Solutions for Apple iBook Blueberry Mac
Questions and Unsolved Problems for Apple iBook Blueberry Mac
Do you recommend Apple iBook Blueberry Mac Notebook?
Answer
Answer
i want to to get an ibook g4 screen and it says it was from a 933 mhz ibook g4 and i have a 1.33 ghz... (More)
Answer
Apple mac to ML-4500 printer - USB - Parallel cable (driver disc that came with lead is too small to... (More)
Answer
I have just recetly got a samsung laptop and the webcam doesnt work on msn i have tried clicking on... (More)
Answer
i don't know my product key
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Apple iBook Blueberry Mac...:
Top Mac Laptop Experts
Rank: Guru Guru
Solutions: 437
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Mac Laptop Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
