In regards to using the dvd function I am currently inserting a DVD disc and the machine is failing to recognise that a disc is loaded and ejects the disc. However if I load a CD it recognises this and goes through to the menu and options page. The DVD's i am loading are compatible as all are region 2
  • Anonymous Jun 22, 2008
    is adjusting the lens something you can do yourself?
    Problem Solver:
  • 6 Answers
YOUR DVD PLAYER HAS THE PROBLEM WITH THE LENS INSIDE THE UNIT. THE ONE WHO READ THE CD'S. YOU HAVE TO ADJUST THE TWO SMALL ADJUSTMENT AT THE BACK OF THE LENS OR IN THE SIDE OF IT. AFTER ADJUSTMENT, IF THE PROBLEM STILL THERE, THEN YOU HAVE TO REPLACE A NEW LENS. [email protected]
Posted on Mar 16, 2008
SOURCE:
Machine will not recognise a new disc when trying to copy a recording
Did the previous machine show EXACTLY the same problem, or did that machine have another issue?
Regarding this one, does the DVD drive respond well to playback discs, such as commercial release DVDs, or DVDs recorded on other machines? Does it play back CDs OK? If it passes these tests, move on to-
I suggest trying to record on different discs - such as a DVD-RAM, or on a different brand of DVD-R, or DVD-Rs from a different batch to your current ones.
If the machine succeeds here, all good and well, if it fails at this point, it seems the machine is faulty and should be returned.
Oct 09, 2014 | Panasonic DMR-EX773 DVD Player/Recorder -...
I have a new samsung bd-f5700 player and tray won't open. Tried using the remote to open & the panel on top of player to open. Nothing works.
First, try resetting your player. Unplug it from wall for at least 1 full minute, then plug it back in. If eject function (remote or top panel) still doesn't work:
MOST DVD players (including every one I have ever worked on or owned) have a tiny manual eject pinhole located close to the tray. You may have to gently open the flip door to see it. It is usually to the right of the disc slot, but could be underneath or elsewhere close by (use a flashlight, it can be hard to see). Carefully insert a straightened paper clip in the pinhole to eject the disc. (It shouldn't matter if machine is on, but for safety I usually do this with the machine OFF and unplugged).
see http://www.ehow.com/how_2324439_eject-stuck-dvdcd-drive.html
or
http://www.ehow.com/how_2036594_fix-dvd-player.html
and http://www.ehow.com/how_6330619_retrieve-jammed-cd-dvd-player.html
If above fails, your only recourse is likely the disassembly of the machine (search "dvd disc stuck" on Google or YouTube), or taking your machine to a repair person. Best of luck to you.
Jun 23, 2014 | Samsung BD-F5700 Blu-ray Player
Hp pavillion dv9000 dvd drive will not eject cd. The orange light is on and the drive and fan run ci ontinously like its forever trying to load the cd. Please help. I have Norton 360 and it finds no...
Maybe the ejectable part of the dvd is not functioning. Use a pin to eject dvd disc insert the pin to the small hole you can see in the front of dvd drive and push. Now you can get the dvd disc.
Mar 25, 2010 | HP Pavilion dv9000z Notebook
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
I have a Samsung DVD-R155. When I insert a DVD, the screen reads "load", but eventually it screen will say it can't read the DVD, and then ejects the DVD. It doesn' t matter if it is a new or used DVD. I...
Try using a DVD scanner eye cleaner. It is aDVD with a brush grafted to it. I suspect the scanner eye is dirty so it cannot read the boot starp properly and so ejects
Aug 15, 2009 | Samsung DVD-R155
When a DVD is inserted, the screen indicates its loading, but it never goes beyond that point. The only other info that might be relevant is that initially the eject mechanism wouldn't function, so the...
there might be some compatibility problem . some times the dvd is not recognised by many players. not ot panic , just try ur dvd on some laptop to check whether there is problem in dvd or the system
Aug 11, 2009 | Soundstream VCM-81D 8in Overhead Monitor...
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
The player is not recognising the disc..when inserting it ejects
the lasers's lens is to dirty, and the unit will need to be taken apart and the lens will need to be manually cleaned , also it would be a good time to relubricate the gears and door sliding mech's
Dec 09, 2008 | Samsung DVD-V4600 DVD Player/VCR
LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Jun 04, 2008 | LG RH177 DVD Recorder/HDD Recorder
RCA RTD210
you should never use a disc thats scratched inside yiour machine its most likely your dvd machine is having trouble reading your media the best way to solve this is to unplug your machine wait turn it back on keep pressing eject it should eject dont use that dvd disc again hope this solves your problem did for me ;
Jul 31, 2007 | RCA RTD210 System
Televison & Video Logo
184 people viewed this question
Top Televison & Video Experts
Ekse
