Question about Sony PlayStation Portable (PSP) Console
I want to replace the joystick
I want to replace the joy stick on my psp slim with one of those after market ones,ive tried to just "pop" it off but it wont and i dont want to screw it up,is there a trick?
    Problem Solver:
  • 15 Answers
Nah, theres not really a trick to it, apart from sony tricking you into voiding your warranty. if you want to change the joystick, your gonna have to remove the faceplate. get a small phillips head screw driver. the first thing you should do is put the psp face down on a flat suface. next remove the two screws on the right of the console, and the one on the very bottom on the underside of the console. now, take the battery out and there should be two stickers underneath one black scrwe and one silver screw. remove the black one. now, you only have one screw left, but problem is its under neath the warranty sticker and if you remove, you remove your warranty. it is possible to take it off using a hair dryer, just so long as you dont damage the sticker. once you have the sticker off, the faceplate will just pop off so just take out the screws on the back of the joy stick, slap your new one in, put it back together and away you go!
Posted on Mar 16, 2008
SOURCE:
Analog stick broken
The following website does PSP analog joystick repairs. You can click on the "SEND US YOUR PSP FOR REPAIR" link on the following page:
PSP Slim PSP 3001 PSP 3000 Analog Joystick Assembly
Dec 04, 2013 | Sony PlayStation Portable (PSP) Console
The analogue joystick isnt working properly. the character wanders off in wrong direction on its own.
simple, get a replacement joystick module and install it on your psp. i did a couple. the psp really isnt that intimidating to take apart. compared to an xbox 360 or playstation
Dec 01, 2010 | Sony PlayStation Portable (PSP) Slim...
Joy Stick
If a joystick sticks, there is no other option but to buy a new one (Sorry!)
http:/bestofferbuy.com
Dec 19, 2009 | Sony PlayStation Portable (PSP) Console
One of the joy sticks on the console does not work
I had the same problem and what you need to do is order a psp joystick replacement pack. They come with fool proof instructions and are only about twenty bucks.....worked for me
Jul 10, 2009 | Sony PlayStation Portable (PSP) Console
Joystick Stuc
Sounds like a $10 ebay repair replacement joy stick. Have a good one.
Jul 09, 2008 | Sony PlayStation Portable (PSP) Console
The joy (control) stick.
i had this problem to, and your either going to have to replace the joy stick, or if your lucky you can take it out, clean it and it may go again. if you want to change the joystick, your gonna have to remove the faceplate. get a small phillips head screw driver. the first thing you should do is put the psp face down on a flat suface. next remove the two screws on the right of the console, and the one on the very bottom on the underside of the console. now, take the battery out and there should be two stickers underneath one black scrwe and one silver screw. remove the black one. now, you only have one screw left, but problem is its under neath the warranty sticker and if you remove, you remove your warranty. it is possible to take it off using a hair dryer, just so long as you dont damage the sticker. once you have the sticker off, the faceplate will just pop off so just take out the screws on the back of the joy stick, slap your new one in, put it back together and away you go!
Mar 18, 2008 | Sony PlayStation Portable (PSP) Console
Grinding PSP joystick
you have to replace the joystick. do not use graphite as it will conduct accross the track. You need a thin philips srewdriver to remove 5 srews one under the label that says do not remove label in battery compartment.once all srews are removed cover pops out and its very easy to replace unit. Look on ebay for replacement joystick for SLIM MODEL PSP.
Feb 28, 2008 | Sony ACY-BR81/OB
Analog stick
then it is a internal fault is it under warranty if so id take it back and try your analog stick on the replacement one then your see if it your machine or the analog ?
Feb 09, 2008 | Sony PlayStation Portable (PSP) Console
Psp joystick problems
Good day all
I recently ran into this same problem of a PSP joystick "jumping" or hopping around. Since I'm an electronics engineer I was determined to get to the bottom of this annoying problem, I read all the posts on the site and none helped, but the problem turned out to be much easier fixed than I first anticipated.
First of all I assume that you know how to take the PSP apart and take out the joystick module as well. The Joystick module connects to the PSP mainboard by means of 4 contacts, seperated by a spacer conductor that appears like a rectangular rubber, be careful not to lose this during the process.
Here is why the problem occurs, when you have a faulty joystick module, one or more of those 4 contacts don't connect to the main board anymore, so the when the PSP is trying to measure the resistance to determine the joystick position, it reads a varying value, i.e. the contact is floating.
This happens for mainly 2 reasons, dirt or a faulty module, as stated in the previous posts, the contacts could be dirty, but this can usually easy be seen, and this wasn't the problem in my case, I had a faulty module, but luckily all is not lost.
Here's how to fix a faulty module in most cases. Remove the joystick module from the PSP completely, put that little rectangular rubber on the 4 contacts (clear in my case) aside and keep it safe. There is metal clasp on the bottom of the module, you can simply pop it off with a screwdriver, by slightly bending the clasps on the side and taking it off. Now you should be able to see a VERY SIMPLE mini circuit board with tracks on, on the bottom of the module, you can indeed pop this off too. On this you will see tracks where the joystick sliders move. Put the circuit board aside too. Now look at the now completely open joystick module, you will see the two sliders each having a metal part, each of these metal parts has 2 very small contacts that run on the circuit board tracks that you just removed, most times these small contacts get bent inward and they can't make contact with the circuit board tracks anymore. Just bend them slightly outward again, so that when you put circuit board back, they touch the tracks on the board nicely. Put the circuit board back, it just slips back on, put the metal clasp back, put the rubber back in over 4 contacts on the module and voila, if all goes well you will have a nice working joystick module again. Put it back in the PSP and test it to see if it worked. In my case it worked 100% and saved me a few bucks. Hope this helps everyone. Let me know if it worked.
Oct 16, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
