Question about Samsung CW29M64NS 29" TV
Connecting Dell Precision Laptop to Samsung 29 inch Easy View (CRT) T.V
Dear Sir,
I have a Dell Precision M90 Laptop and wish to Samsung 29 inch CRT TV. I Used a S-Cable to connect the laptop to the TV. However I was not able to obtain the display on the TV screen.
Do request you to kindly let me know the way my Laptop to the TV!!
Regards
Biju
  • Anonymous Sep 14, 2008
    I have a Dell Precision M90 with a Nvidia Quadro FX 2500 display card that tried connecting to a Sony Trinitron TV via the S-video port. I only see diagonal patterns on the TV. My son's Xbox connects without a problem as well as cameras. Do I need a special cable or do I need other drivers for the Dell's display card?
    Any suggestions to solve this problem?
    Scholar:
  • 143 Answers
Dear sir.
here u have to chek cable yr laptop is not support with a same s-cable u need to connecter for s-vadio to audio vedio connector and it's convort yr s-cable to comosite cable afer that it's automaticly dosply thru composet.... yeah one thing have to chek with different cable then selacet display propatise to set output setting is set in to s-video.. it's help u...:)
Thanks
please vote
jo_chinmay
Posted on Jan 02, 2009
No power Samsung flatscreen CRT 21 inch TV
Check its fuse. Check the rectifier diodes. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 18, 2014 | Televison & Video
Samsung flatscreen CRT 21 inch TV. problem no power?
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 18, 2014 | Samsung CW29M64NS 29" TV
Installing internal dell m90 smart card reader
You have to take apart a good portion of the laptop to reach the Smart Card Reader spot. You need to turn off the computer, unplug the AC power and remove the battery first. Make sure that you are grounded to the computer. Then remove your optical drive and the hinge cover. Next you remove the mini-card antennas either from the mini-card or their secure spot, display assembly, the keyboard and the palm rest. Then you can reach the screw for the smart card reader and the place on the motherboard where the smart card reader connects.
The full set of steps and pictures is available from the Dell support site, http://www.dell.com/support/Manuals/us/en/19/product/precision-m90 . See the Workstation Service Manual. The direct link to the English version is ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_precision_mobile/precision-m90_service%20manual_en-us.pdf . There are multiple pages you need to follow.
I hope this helps.
Jul 06, 2013 | Dell Precision Computers & Internet
My Mic in Dell Precision m90 stopped working after i downloaded Skype? Any suggestions on how to get it working again?
Have you checked the sound settings in Skype? Usually skype lets you to set your sound equipment individually rather than using the windows general settings.
Especially if you have onboard mic. Try the call settings sound options in skype and check to see if it is working.
Oct 22, 2012 | Dell Precision M90 Notebook
How to clean out dell precision m90 fan.
http://www.youtube.com/watch?v=0yyEVSkz_0M - similar laptop
http://www.youtube.com/watch?v=4ODaKRx7WPw - the lazy way!
Jun 23, 2011 | Dell Precision M90 Notebook
Dell precision m90 overheats randomly
Either your motherboard has gone bad, or you fan AND cooling grid needs replacement. The grid is simply a series of metal bars, so to speak, which absorb heat to be passed out of your system with the cooling fan. The cooling fan has 2 speeds. If the system is not kicking in the higher speed on the fan, it's more than likely a bad motherboard. Also, make sure you keep your laptop plugged into the wall as much as possible. Going on battery alone does slow down the processor considerably to conserve the battery.
Best wishes.
Feb 23, 2010 | Dell Precision 360 Workstation/Personal...
My Dell precision M90 will not turn on all the way it acts like its going to boot up and then comes to a screen that either says the battery can not support the system press F1 to shutdown (when it is not...
Seems that either the battery or the power adapter is defective. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Oct 27, 2009 | Dell Precision M90 Notebook
How to connect dell laptop to samsung 29 inch tv using cable
Dear Sir,
For getting display in TV you have to select input source as TV generally in all other laptop
short cut key is fn+f4. generally short cut function key shows picture of small square box.Search for that short key then activate the out put for TV by pressing that key with Fn keys.
I think it solves your problem.
good luck
Aug 27, 2009 | Samsung CW29M64NS 29" TV
Dell Precision M90
Try installing other anti-virus like NOD32 or karspersky. You can also try to do a system restore, this may or may not solve the problem though,also using the system restore may get rid of some application you have install prior to the date you will revert it to.
Or you can try this online virus scan
http://housecall.trendmicro.com/
http://www.bitdefender.com/scan8/ie.html
http://www.kaspersky.com/virusscanner
have them scan your system (its free),that way you'll know if your computer really has a virus or not.
Apr 30, 2008 | Dell Precision M60 Notebook
Samsung CW29M64NS 29" TV Logo
957 people viewed this question
Henry  Thomas
Henry Thomas
