Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Fisher and Paykel dishdraw DS603
I have attached to the dishwasher a current monitor which supplies electrical protection
Last night the dishdrae just would not go on, I looked inside cupboard at the current monitor and the red light was on.
This then let me know there is an electrical fault, I immediately switch it off.
The problem I now have is the door of the dishdraw is locked and will not open no matter what I do, and it is full of dishers as we were ready to put it on to wash when all this happenned.
The book says to hold down the lock button and it should unlock, but nothing happens
When the draw went off it did not come up with any reading to say what the fault was.
Can you put any light on this with any experience to maybe what the fault is and how to open the draw???
Thankyou regards KJ
  • jconron Aug 03, 2008
    Unit sudenly failed to power up. We tested the electric outlet and it is functioning correctly. Dishwasher drawer is locked, and because the untit will not opwer up, there are no "lit" indicators. Pressing any and all control buttons does nothing.
    President:
  • Fisher and P... Master
  • 2,651 Answers
Look closely at hte display in theright corner is there a little icon that looks like a "lock". if so your control lock is on. do you get any response from any buttons??? if your able to power it up did you try to stop/andrestart unit. sounds like a silly question but sometimes the lid locks down from a power surge/interuption. restarting or canceling current cycle forced drawer to unlock and lock itself..assuming this is the top drawer is the bottom functioning ok??, behind the bottom drawer taped on back wall of inside of unit is atech sheet, with a pretty good troubleshooter. to remove the drawer push in rectangler hinge locks in hte bottom front corner of drawer front, just below the circles(no noeed to remove the circles)push themin and slide back the drawer will lift off and your able to set it aside(wont come out to far its connected by the hoses but itll come out enough(reset the door unto the hinge slides and pull hte lock latch foward to lock back into place
Posted on Mar 16, 2008
Why does our dishdrawer tripout the safety switch in the fuse box?we have tried different electrical outlets in the house same result?
User Guides, Installations & Parts Manuals - Fisher & Paykel
https://www.fisherpaykel.com/nz/support/user-manuals/
Fisher & PaykelFind and Download User Guides and Installations Manuals for your Fisher & PaykelAppliances: ... This will help getting a quicker and more accurate result.
Expert Tips, Troubleshooting & FAQs - Fisher & Paykel ...
https://www.fisherpaykel.com/au/support/expert-tips/
Fisher & PaykelExpert Tips. Select a product type to see solutions to most common problems you may encounter with your appliance. Search. -Select-, Built In Ovens, Electric ...
[PDF]user guide DishDrawer Ph7 Eng - Fisher & Paykel
https://www.fisherpaykel.com/.../590199D%20DishDraw...
Fisher & Paykelguide', you can download it from our local website, listed on the back cover. Refer to ...Preference options and how to change their settings ... standard safety regulations.Fuse cover. Fuse. Electrical connection (GB IE only) ... Do not use an extension cord or a portable electrical outlet device (e.g. multi-socket outlet box).
[PDF]Controls (models with LCD) - Fisher & Paykel
Dec 25, 2015 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher Paykel Nautilus dishwasher
There is a drying cycle that runs for around an hour once the DD has finished its final rinse . It should show it on the LCD
Jun 03, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
DS603 fisher paykel motor noise when starting up
The pump and motor for DD603 is the same device. It is a rotor lodged inside a cavity under the drain filter plate. I am assuming the dishdrawer is drained properly and at end of the wash there is no water sitting inside. You need to take the rotor device out from its cavity and check for damage. This video will help.http://www.youtube.com/watch?v=UXzuJvKIIgU
Mar 26, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
The top dishwasher of my Fisher&paykel Paykel DDd603 &DS603 model ontinuallly beeps. I tried unplugging the power for several hours and it still beeps. Any recommendations ??
Assuming the bottom dishdrawer is working ok, it is likely the controller on the top drawer is either faulty or sensing some incorrect signal. If pressing any of the panel buttons makes no difference, then most likely the controller is faulty.
By the way I am unclear why you mention two models in your problem description. DD603 is a double drawer dishwasher and DS603 is a single drawer unit.
Apr 10, 2013 | Fisher and Paykel Dishwashers
Fisher paykel dishdrawer keeps beeping with f1 error
http://www.scribd.com/doc/6462163/DD601V2-Manual#fullscreen
Nov 17, 2011 | Fisher and Paykel DishDrawer DS605FDSM...
Leaking fisher & Paykel DS603 Dishdrawer
i think there is a hole in the grey sump underneath rotor motor, the motor is the grey blades u took out of sump. pull out drawer, take filter tray and rotor motor out of drawer, dry all of water out of drawer , then look underneath unit , pour a little water into drawer and see if it is leaking past motor windings . if it is then there is a hole in the sump. if it doesnt leak from there try looking at the little black drain hose. please turn off power b4 u work on dishwasher do not want any accidents . please reply 4 more help.please tell me what u find. good luck
Apr 09, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel DD603 service manual
Check to see if the Child lock is on...Check your email
Aug 28, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & Paykel Dishdrawer DS603
2 quarter sized circles on either side of drawer will release the drawer fronts and allow acess to the electronics, behind the bottom drawr taped to back wall of unit is a troubleshooter/techsheet which might prove to be very helpful
May 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
464 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
