My hotpoint aquarius extra WMA36 is making a terrible banging noise whilst on final spin. When i open the door to take out the washing there was a smokey mist coming from inside the drum. Are the bearings shot? The drum does seem to turn ok by hand....
AS A TECHNICIAN, MOST OF THAT KIND OF TROUBLE I ALWAYS SEEN THE TIMER CONTROLLER IS ALWAYS DEFFECTIVE. YOU NEED A TECHNICIAN TO LET IT SEE AND REPLACE THE NEW ONE. IF YOU DON'T, IT MIGHT BE THE START OF FIRE.KIM
Posted on Mar 16, 2008
    Sergeant:
  • 236 Answers
Hotpoint had a problem with the early bearings on these, so it would probably be the fault. or you may want to check the security of the concrete weights, one at the top and 1 at the rear of the tub.
SOURCE:
Hi my hotpoint washing machine is near 3 years old the last few weeks it is making a terrible noise when on spin only. \r\nthe noise is really loud but everything is washing and drying the same its just...
Sounds loike the main drum bearings have failed.
Spin the drum by hand from the front, and if it feels rough, or is rumbling or grating, then the main bearigs have failed.
Quite an expensive repair, unless it is covered by the Hotpoint 5 year parts guarantee, check with Hotpoint.
Jun 16, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Thankyou.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My hotpoint aquarius front loader has power but wont work.
Most likely the Door interlock is faulty or has fallen apart (through the banging of the door)
Aug 21, 2009 | Washing Machines
Loud banging
Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
Check drum restraint spring(s) are not broken.
Check suspension legs for wear.
Check for loose motor fixings.
Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
Please rate my comments.
Thanks.
Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Indesit wil 113 washing machine
try to put more clothes but not to much it wont banging.
must change door lock switch.
Feb 14, 2009 | Hotpoint Aquarius WD63 Front Load...
Washing machine won't spin
This site should help -
http://www.washerhelp.co.uk/diy-repair-help_4.html#cl_q2
I am thinking moor brushes, but it could be any one of 3-4 different problems.
Jan 28, 2009 | Washing Machines
Started having a noisy rinse & spin cycle, then stopped.
Open the washer door and spin the drum by hand, if it feels rough or noisy and rumbling, then the main drum bearings have failed. There should be little or no noise when you spin drum
This is a major repair, and I would not recommend a D.I.Y solution.
Other possibility is there is something in the pump, but you would only hear this when the pump is working.
Plz rate my comments.
Thanks.
Jan 07, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint WD 440
FIRST OF ALL THE PERSON WHO INSTALLED THE MACHINE SHOULD HAVE REMOVED THE TRANSIT BOLTS YOU MAY BE LUCKY THAT ONE OF THE SHOCKS MAY HAVE COME OUT OR A SPRING MIGHT HAVE BROKEN
Jul 13, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing machine
probably a balancing spring broken it'll need attention very soon... it's not a big job but needs to be taken care of without delay
Oct 29, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
303 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
