Question about Samsung CLP 300 Laser Printer
Clp-300 makes holes in the middle of the paper
Hi, i bought this printer yesterday and everytime i print a photo on a a4 paper, it makes in the middle of the paper 2 or 3 holes, like it burned the inkt off of it, it doesnt burn trough the paper but it makes like holes, who can help me??
    Sergeant:
  • Samsung Expert
  • 406 Answers
Please check the imaging unit or fusing unit that some thing has sticken to it. Only this should be the cause.
Posted on Mar 26, 2008
Samsung CLP-300 paper does not seem to be catching when printing?
Hi. Kelly,
I think the issue is the due to paper pick-up roller. When the rollers get dirty or worn-out, the printer fails to pick the paper, which results in paper jam etc.. So, remove the paper tray and toner cartridge and locate the paper pick up roller in the middle. Clean it with damp (with luke-warm water) and lint-free cloth. I hope this would fix the issue. If the Roller is damaged or worn out, it needs to be replaced.
Hope this helps! Good Luck!
CreativeTECH
Feb 15, 2011 | Samsung CLP 300 Laser Printer
Printing in black is not the same shade through out the paper
This is a very common problem with the Samsung CLP 300 and CLX 3160 printers. What happens is that the toner or developer blades become coated with toner. The developer blades meter the amount of toner that the printer uses to make the image on the paper. When the blade become blocked, the image become faint. To fix this problem, you and either replace the imaging unit for about $100 or you can clean the blades yourself. I have posted instructions how to clean them on my Tips section.
Jan 26, 2010 | Samsung CLP 300 Laser Printer
Samsung CLP-300 paper feed
Clean the feed roller.
Remove the paper tray, from the bottom there is a grey rubber semi wheel in the middle front of where the paper tray would be. Use a cloth with WD-40, brake cleaner, or lighter fluid to lightly wipe the rubber clean. Put the paper tray back in and it should print.
Jan 24, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP-300 dark prints and smears
For starters remember this is not meant to be a PHOTO Printer, I am guessing the Spearing is because Glossy paper does not hold the toner like Regular paper or at least until it is fused. I am a technitiian and i also own this printer.
Jul 14, 2008 | Samsung CLP 300 Laser Printer
Using far too much ink
This came from brothers website:
The Yellow ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Magenta ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Cyan ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Black ink cartridge yield is up to 350 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
so it appears that what you are experiencing is not normal and you may have a leaking printer.
There is one thing you can check though, everytime you print, make sure that you are not printing at the highest quality option selectable as this almost certainly will fire out more ink than regular printing... choose a middle quality option or even draft option if you will be printing regular text.
Jul 02, 2008 | Brother Office Equipment & Supplies
IT DOES NOT PRINT!!! I've bought it yesterday....
Open the front cover, pull and remove the paper protecting the image drum (this is more towards the right side). You will need to remove the toner cartridges again to do this.
May 25, 2008 | Samsung CLP 300 Laser Printer
Clp-300 with printed lines
when you remove the imaging unit, look into the area and you will see a black shiny belt, make sure there is nothing on their.
Mar 30, 2008 | Samsung CLP 300 Laser Printer
No photo paper showing in "TYPE OF PAPER
I would recommend using the thick paper settings, also just pull on the front of the tray and then you need to remove the paper in there and then adjust the guides to fit the paper, also if you are using A4/Ltr/lgl then you will also need to collapse the back section by pushing down on buttons and then pushing on the back to shorten the unit
Also remember that this printer was not designed for photo printing, also make sure to place the paper face up(the side you want to print on)
Best of luck,
Mitch
P.S. don't forget to Rate me!
Jan 02, 2008 | Samsung CLP 300 Laser Printer
Printing photos
Of course you can use 4x6 photo paper
you have select the paper size from page setup as 4x6
and put the paper in the tray after adjusting the tray size
Dec 27, 2007 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
132 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
