Question about Olympus EVOLT E-500 Digital Camera
Lighting problem with Olympus E 500
I've got this camera two weeks (bought it used). It worked fine at first resulting in great sharp pictures with proper lighting. But suddenly the good results started to be lesser and lesser. Ofcourse I went through the menu couples of times to get to know the camera better. This is the problem: when pointing the lens towards a light source it is resulting in pictures with strange vertical beams of light and the pics look heavily over exposed. There seems to be some pattern repeating also. Like when I take a picture of the tv with the pioneer logo on it, you will also see the logo floating in the air above the tv.
I did set everything in auto mode and the lighting metering in ESP. At night time it is not that obvious but a light source (lamp) will result in a straight vertical beam of light like a laser.
Does anyone have an idea why this might happen?
With regards,
André S.
    New Friend:
It sounds like it may be a broken shutter.
Posted on Apr 05, 2010
SOURCE:
I have an SP800UZ. I have upgraded my computer to a Windows 7 machine with 64-bit. Now I can only get pictures off of my camera if there are only a few. If I have too many (I am not sure what the max is),...
Please, install the Olympus ib program which originally is on the internal memory of the camera, or install the better and free Olympus Viewer program. It will automatically install the needed driver for the camera. I use the latter program on my notebook and pc and both are using Windows 7 (64bit) and it works splendid with the Olympus SP800uz.
Sep 07, 2011 | Olympus SP800UZ Digital Camera
I'm not getting crisp, in-focus photos from my EV500 (they appear somewhat fuzzy). In a studio environment with 5500K softbox lighting, using a tripod and AF on a portrait subject, with ISO 125 in Manual...
You can try a few things to see if they help
  • First is to power off the camera and detach and reattach the lens just to make sure you are getting a good connection for the auto-focus
  • The second thing you want to do is shoot in RAW format to be sure you are able to retain the most information in the image.
  • Make sure the noise reduction is turned off in the camera menu
  • If you aren't using a cable shutter release you can opt to have the shutter delay after pressing the button. This will allow the camera to stop shaking from you pressing the button before it releases the shutter. You can find this option in the menu. Camera 2 > Anti-Shock > 3 sec.
  • Another consideration is the quality of the lens you are using. The G10 has great glass while a kit lens from Olympus may not give the fidelity throughout like the G10 does. You can try another lens if you have one available to see if this is the case. The G10 is a single purpose camera that has a great lens on it. The E-500 may need a better quality lens on it in order to achieve the sharpness you desire. Olympus makes a great 50mm macro that has an f2.0 brightness.
  • You can also set the camera to manual focus and then choose to do focus bracketing. This is a little more involved and you can find out how to do so in the manual for the camera.
Advanced Camera Manual for E-500
Feb 25, 2011 | Olympus EVOLT E-500 Digital Camera
MY OLYMPUS SP 500UZ constantly kills batteries...any ideas? I can't go even an hour without replacing batteries most days.
The best thing I EVER bought for my Olympus was the Re-chargeable Lithium Ion battery. The worst thing I did was buy an off brand. That was a waste. I ended up getting the more expensive brand Olympus recommended and all was GREAT again!! 1,000's of pictures later and they still work great.
Good Luck
Dec 25, 2009 | Olympus SP-500 UZ Digital Camera
Settings for indoor business presentation
you need to set for fluorescent lighting..... look in settings to find best match..do a test before event ..good luck
Jan 13, 2009 | Olympus EVOLT E-500 Digital Camera
Olympus E-500 view in LCD whwn taking picture
It is not available while taking pictures on the E500. After you shoot a picture you can program how long you want the picture to show then disapear. Thats the only option for the LCD.
Nov 22, 2008 | Olympus EVOLT E-500 Digital Camera
Olympus e10 problem. Even with new batteries, could only take a couple of shots before the low battery icon came up & camera shut down. Would work fine using mains supply. Fixed by buying new battery...
You didn't say what type of batteries you are using. Best are CR-V3 lithium which should give 500 shots. 2300 mAh Ni-MH rechargeable batteries should give 200 shots. Worst are alkalines which Olympus do not recommend.
Have you checked the contacts in the bottom of the battery chamber for cleanliness?
Aug 14, 2008 | Olympus Cameras
Sharp VE-CG40
Fixya does not supply software of any description. Contact the manufacturer or use a USB card reader.
Jul 09, 2017 | Sharp VE-CG40U Digital Camera
Sharp VE-CG40
I bought this camera off ebay. I do not have any software for it. I cannot get it to transfer pictures to my computer. I think i need to install a driver. It is a Sharp 3x Optical Zoom Digital Still Camera VE-CG40. Where can I download a driver?
Dec 25, 2007 | Sharp VE-CG40U Digital Camera
Dead Olympus D-560
Seem like its a dud card.
There have been problems with XD card I hear
checkout Sandisk and Olympus support.
Nov 21, 2007 | Olympus Camedia C-350 Digital Camera
Olympus FE 190 pictures are blurry
Check any adjustments that have to with resolution. Do they look more pixellated when you look at them on the computer. Or do the pictures look out of focus?
You should check under the Shooting guide #3 (blurring background) to see if this helps you.
If none of the settings (ISO settings, resolution, lighting, image stabilization mode) help you, contact HP next.
This camera, if I recall correctly, is a fairly basic camera. I would contact HP and see what they can do for you. Since the camera is close to the warranty period of one year, they should cover it under warranty.
Mike
Nov 12, 2007 | Olympus FE-170 Digital Camera
Olympus EVOLT E-500 Digital Camera Logo
71 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
