Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Broken Tub Support Arm
Maytag washer MAH4000 drum support bracket broke 2 studs and bracket arms- Cant find the peices....Tub sore a hole about 14 inches, thought I could epoxy that closed but when I saw the support arm broken- should I consider this waser history?
  • Barringer_cp Mar 16, 2008
    Thanks, I agree after finding that the arm itself is over $100 and need new bearings and chancing the edge repair that could leak.
    Thanks
    President:
  • Maytag Master
  • 2,651 Answers
Ummm yea your int market for a new washer. why cahnce epoxying a tub thats holding water doesntsound like a viable option. ( not worth the chancing the flood )
Posted on Mar 16, 2008
My Neptune MAH5500BWW washer makes a loud noise while spinning. Sounds like whatever is supposed to stabilize the movement of the drum is either out of place or broken. Please advise.
If it is making a thumping noise when spinning, it could be that the spider arm supports are broken. It is expensive to repair. Get a few estimates, but depending on the damage, could cost more to repair than buying a new washer. Sorry.
Aug 30, 2010 | Maytag Neptune MAH5500B Front Load Washer
Tool to get tub bearings in and out on mah4000
you can rent the "TONY-TOOL" on the web for $79.00 or you can make one out of a piece of pipe 11/2" in diameter with a pipe joint screwed onto this piece of pipe on one end and it does the same thing
Apr 19, 2010 | Maytag MAH6700AWW Neptune Front-Load...
WATER STANDING IN THE DRUM AFTER WASH CYCLE
can you see water in the tub, or do you hear water when you turn the tub? if you hear water when the tub turns, it is not water. the stainless drum has a liquid inside it for balancing loads. if this is the case, there is no problem. but if you see water in the tub that didnt drain, you need to check the pump and the hose from the pump to the outer tub. look for restrictions (coins, tooth pick, nail, ect.). also check the pump impellers to make sure none of them are broke, there are three plastic impellers. if any are broke, replace the pump. hope this helps you. let me know if you have any further questions. shane
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Neptune MAH4000 AQW belt will not stay on.
If you installed the belt correctly but it still comes off, that means most likely that the drum pulley is tilted, which indicates another problem - the central bearings are going out. Another symptom for that is a loud noise when the drum is spinning fast. The cure for that would be replacement of the outer tub or just replacement of the bearings with seal.
If there's no noise during high spin - check if the drum pulley or the motor is loose.
Good luck,
Vladimir
First Choice Appliance
Jun 19, 2009 | Maytag Neptune Washer
My Maytag washer has a defect, technican told me, that lets water get between the tub and outer lining and sit there and stagnate smelling terrible.
The water always goes from the tub to the outer shell, that is where the pump connects. Put a little bleach in the tub with some water, shake the agitator side to side to move the drum enough to circulate the bleach around the tub. Then pump the water out and then lower the hose down to a bucket to get the last of the water out. Feel around between the inner and outer drums for anything that has jumped out of the inner tub to the outer drum. You should be able to push the inner drum aside enough to get your arm in. You may have to open the top to get your arm in the space.
http://www.pcappliancerepair.com/model-display.php Check this site for your machine.
May 07, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Can't get old lower control arm off 1994 geo metro. stuck at ball joint.
remove ball stud bolts .then remove suspension arm bracket nut .remove suspension arm bracket bolts. remove rear bracket and suspension arm. torque ball stud nut 44 ft lbs torque suspension arm rear bolts 32 ft lbs.
May 05, 2009 | 1994 Geo Metro
My Mother's Maytag Neptune front load washer has water left under the drum after the final spin cycle. I am not sure that this is normal. Please advise.
This is normal to hear water sloshing under the drum when machine is done washing and you spin the drum. This is part of their water balance method to help spinning procedure. I called a Maytag repair shop and they helped with my question.
Jul 23, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag Performa washer dead.
Your door lid has a switch that makes these functions work.First open the lid and look at the right side of it.Does it have a arm on it?If it does follow the direction where it is going to hit and now listn closely while your lifting the door up & down at this contact  can you hear it click?If its not clicking  or the arm is broken  off the lid replace  the lid switch/or the broken lid switch arm.
Apr 28, 2008 | Maytag Performa PAV2200
MAH4000 washer
VERY BIG JOB!!
This job requires replacing outer tub. If you want, I can spell out whats involved. Expect at least a couple hours and a pretty large parts bill. Let me know!!
Nov 15, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune MDE5500AY Electric Dryer Logo
78 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
