Question about Symantec Norton AntiVirus 2002 8.0 for PC
I got virus
Hi.my pc got virus i think its torjan... its making folders in folders with
the same name i think u got my point so ...
i need help i want 2 remove it.plz
  • sos123 Mar 24, 2008
    My system has got affected by trojan virus. When i'm scanning my system using AVG antivirus free edition, its automatically getting restarted. I have formatted the system for 2 times, then also tat virus still exists in my PC. Whther i have to purchase any anti-virus or can be cleaned by any other process. Can u pls guide me giving your solution.
    Thanks,
    sos
  • Anonymous Apr 05, 2008
    Yes
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 13 Answers
If your pc is running on windows xp,, good news you can easily remove trojan virus by doing a system restore
Posted on Mar 16, 2008
My messanger sign out automatically
I think this is problem of Virus called torjan, Just run you antivirus & scan whole PC. Clean temporary internet files & other unwanted files from PC. Delete your Previous Chat & other History related with Yahoo Messenger. Then uninstall yahoo messenger. Don't forget to clean your PC.
Then Go to yahoo.com & Download latest updated version of yahoo messenger & install it on your PC. & Now i hope your problem will fixed 100% guarantied.
Thanks.
Happy to help you.
May 03, 2010 | Yahoo Messenger
Tip
Removing virus from "System Volume Information" folder
Quite often antivirus scanner locate a virus, quarantine it than you find that the next day it's back again. What happened is that windows have included the viruses into the system restore point when it creates one. The folder that contains the restore point information is the "System volume information" folder this is a protected folder.
You may be able to see the folder at all. There are two methods of ridding yourself of the virus if the scanner is incapable. Both require you to be logged on as an administrator.
First method:
The first method is to remove all the restore points. Unless you are 100% sure you will never need to restore to a previous point then by all means do it.
1. Right click on my computer then click on system restore tab. Place a check mark alongside "Turnoff system restore on all drives" click Ok and close the dialog boxes.
2. Run your antivirus scanner again to make sure the virus is gone. You can choose to perform the task you can do only in the folder where virus is detected. In this case “System Volume information” Folder.
3. Once your are happy return to System Restore tab and uncheck the mark while you are there highlighted the drives, click Settings and slide the slider to the left to around 2%. This will release a significant amount of hard drive space. Windows default setting is to reserve 12% and on a 150 gig drive that can total 18 gigabytes. 2% will still give you enough room for an ample number of restore points. Click OK and close the dialog boxes.
4. Next, Create a new restore point. With any name you want.
on May 08, 2010 | Computers & Internet
Tip
Preventing Reinfection of Virus for newly installed XP.
Hello XP users, Hi, here is a tip of how to prevent viruses from reinfecting your PC, the virus is well usually comes from your USB flash drives, and or your back up files from your hard drives as I assume you have a Drive D: Here are the things you should do so that you will not get reinfected.
Im assuming you are using XP
1. Reformat/reinstall again your OS and as for your Hard Drive, set 2 partitions, for system this would be drive C: and for Data, this is for drive D:2. After installing the XP (you now at this point have a start button) caution: do not use any flash drive or open your other drives, set you folder options to Show all files and Folders.
start->my computer->tools->folder options->view on the hidden files and folder, select Show hidden files and folderand uncheck the two checkbox below, (this is hide extension and hide protected .... )apply and or OK
3. Run GPEDIT.MSC from the RUN option
start->run then type GPEDIT.MSC then OK
4. Under Group Policies, goto administrative templates -> system -> turn off autoplay then enable select all drives -> OK ->exit
this will make the autorun.inf functions not to load automatically. This option makes the virus not to load automatically. caution again, at this point be cautious of what you will DOUBLE CLICK.
5. install an antivirus software, (any freeware will do, but i prefer the AVAST one)
your PC is now protected from reinfections.
you can now scan ALLl your drives and flash drives.
You can also manually delete the virus files on your drives. they are usually folder looking files, usually 743/744 bytes. You can also see some recycle bin ICONS with unusual names (who created them?) If you did not create them, erase them files.
Run SEARCH on all drives except C: with all .EXE files and under the what size is it? select medium. then click search.
on the search result, delete all the folder looking .EXE files with 743 or 744 bytes (usually).
caution one more: before opening a removeable flash drive, do the SEARCH thing on this drive.
Your done. = }
on Apr 28, 2010 | Computers & Internet
How do I delete or repair the threat to my Laptop system that has
HOW TO REMOVE RAILA ODINGA VIRUS IN 2 MINUTES
How to remove raila odinga virus is a very easy process. Firstly, Raila odinga is a worm that attacks Microsoft word files, but it looks like a JPG file and mostly found on the desktop.
Raila odinga has some common characteristics
1. If you delete the picture file it will delete and return to where it was.
2. It runs from the driver folder in system 32 folder
3. it auto runs at system startup
4. It makes the computer boot slowly
5. It makes your computer to hang.
6. It creates new folder.exe folders in your computer
How to remove raila odinga virus, open my computer, double click drive C: open WINDOWS folder, double click on system 32 folder, open driver folder,
locate the word file in the folder, note the name. Right click on the task bar, open task manager, click on the process tab locate the name of the word file you saw in the drive folder, right click on the name of the file, click end process, to terminate the running process
Open the driver folder of system 32 where the file is, delete all the ms word files on that folder, then close the folder locate the raila odinga picture file usually on the desktop or somewhere in your computer, delete the picture file. Please do not double click on the picture file only delete it, finally empty your recycle bin and restart your computer. That way odinga is off your machine.
Mar 25, 2010 | Computers & Internet
Window can not find gphone.exe
gphone.exe is nowadays one of the most dangerous virus spreading very fastly.Its a trojan and changes your IE homepage and sends tries to open gtalk and yahoo messenger.It even sends messages to gtalk contacts.Its icon is just like that of folder icon and people thinking of folder click on it get infected by the virus.
Gphone virus basically is a 260 kb .exe file which looks like a folder and it can take any name of any other folder if you have clicked on the virus folder which looks like a folder but it isnt.If you have a folder name “comptalks” in your D drive it will make a exe file in the folder named comptalks.exe and if you click on that exe file it too work as a virus.It makes .exe files in all the folders you have with the name of the folder.
To remove the gphone.exe virus you just need to follow simple steps:
Go to Task Manager ->Processes and then click on gphone.exe and click on end process.
After that manually go to folder where gphone.exe is present and simply delete it.
Or simply search for the exe file clicking which started sending messages through gtalk. If you clicked on 1.exe search for that file on task manager and then delete it.
Good luck.
Sep 02, 2009 | Microsoft Windows XP Professional With...
Usb flash drive icon changes into folder icon
This issue may have resulted from a virus infection on the machine the drive was plugged into.
You’ll need to delete the file autoruns.inf located on your flash drive.
By default, Windows hides this file, so before you can delete it you must make a couple of changes (you may reverse these after you’ve finished):
Open My Computer
Tools
Folder Options…
Click on the View tab
Under “Hidden files and folder” choose “Show hidden files and folders”
Remove the tick from “Hide protected operating system files (Recommended)
OK
Go back to My Computer and click on your flash drive. If you can’t open it that way, try right clicking on it and choose “Explore.”
Find the autoruns.inf file, right click on it and choose “Delete.” Confirm “Yes.”
Unplug and re-plug the drive in. You should be back to normal.
Hope that helps.
Feb 26, 2009 | LG KU250 Cellular Phone
Computer viruses
Download and run avast free anti-virus software. They give a 60 day demo or you can register on the website before you download and they will Email you an unlock code, schedule a boot time scan and let it run its course. after the first virus is detected choose option 2 to delete all (automatically).
LINK
Jul 21, 2008 | E-Machines eMachines Desktop PC
Effected with Virus
the phone's firmware will have to be reflash
Jul 08, 2008 | Nokia 6233 Cellular Phone
Hidden files
hit show hidden files to left
Jan 27, 2008 | Microsoft Windows XP Home Edition
Virus
turn off system restore, restart pc, keep pressing F8 while it boots up into safe mode, run antivirus programme again and antispyware, when the virus is found, restart pc, then turn system restore back on.
Sep 12, 2007 | Microsoft Windows XP Professional With...
Symantec Norton AntiVirus 2002 8.0 for PC Logo
Top Symantec Computers & Internet Experts
Lisa
Lisa
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
