Sansui STBHD01 Connection Issue
I have a Sansui STB HD01 digital receiver and I have a problem with it. Firstly it started getting frozen on the channel then now it has power but I am unable to get any reception with it. When I click the pwoer button it just goes from the time symbol to a square symbol on the display area of the unit. Can u please tell me how this can be fixed.
  • sarasc Jul 13, 2008
    Hi
    I have the same problem.
    Regards
    Richard
So do I..
i think we should just buy a new reciever...
Cheers
Trish
Posted on Aug 28, 2009
If I connect antenna coax to the tv in on my dish receiver, can I get ota programming on my non-digital signal ready tv with out a stb?
Hi James,
Normally, no. Most areas have gone digital-only. Here in Canada, just about everywhere has completed Phase II of our DNU (Digital Network Upgrade) regulated by the CRTC... meaning that you will need a STB to view any sort of programming.
Check with your local cable provider to see what's up. They'll know for sure.
Hope this helps!
Mar 01, 2015 | DISH Network 311 DTV Receiver
Wont receive digital channels after scan non found
Hi Patrick,
You must have a UHF / VHF antenna connected to the antenna input of the TV to scan for digital channels. Most new TV's have a threaded, round 75 ohm coax cable connection for this - but yours might even have connection consisting of 2 small screws to connect a 300 ohm twin lead antenna cable instead. Use which ever yours has.
If you are using this input for the input of a cable TV "set top box" (STB), satellite STB, or similar, you will likely only find a single analog channel (Ch3 or Ch4) after a scan as the scan will only find the output of the STB - which is usually on Ch3 or Ch4 - and not be able to scan the STB channels.
Additionally, the antenna input of the TV will only provide a standard definition picture if connected via coax cable from the STB. It will only provide a high definition picture if connected to a UHF / VHF antenna and a broadcaster is close enough for its signal to be received by the antenna. The way to obtain the best possible picture (high definition) when using an STB for tuning channels is to use an HDMI cable between the STB and TV. An HDMI cable will provide the very best picture and audio signals from the STB to the TV; all over a single cable and is the recommended practice.
I hope this helps!
Dec 26, 2014 | Televison & Video
I need a information Manual for my LENOXX DBT please. The Phillips No's are 2480635 29970323.
I'd love to help you - and I probably can - but you are going to need to provide a little more info.
Firstly, I'm not exactly sure what a DBT is - my educated guess would be that you need a manual for a set-top box / digital tuner. These usually have DVB-T marked on them (Digital Video Broadcasting - Terrestrial).
I can supply manuals FREE for some models of Lenoxx digital tuners but not all of them. Lenoxx charge AU$15 for these so hopefully I can supply the one you want - assuming this is what you are actually requesting.
If you can let me know the model number of the device you require a manual for, I may be able to supply one. For Lenoxx digital tuners, the model numbers generally start with STB (meaning set-top box) and then 3 or 4 numbers, e.g STB-300, STB-500, STB-800, STB-1200.
If you need a manual for some other Lenoxx product, then please supply a model number for it. These can usually be found somewhere on the product, often in small letters on the front panel or on a manufacturer's sticker on the back.
I am also a little confused to the relevance of the Philips numbers you listed. I'm assuming they relate to your TV, but they are definitely not model numbers and therefore could relate to anything. They are most probably serial numbers of some kind, in which case those numbers are only relevant to your TV and as such it is not possible to determine which product they relate to.
If you need information for your TV, again you are going to need to provide a model number. You should be able to find this somewhere on the back of the TV.
Please clarify exactly what you need and I'm sure I - or someone else here - will be able to assist you.
Regards,
BElectric
Jan 14, 2011 | Philips Televison & Video
I got this message lnb short ,what can i do ?
Start at any outside exposed connection of your Sat cables. They get water in them in the bad weather. The "Barrel" F connector then needs changing and dry out the mates. Sloppy installers do not put in "Rain Loops" (a loop below the connection so water runs down to loop to drip instead of runing into the connection), rubber boots, or Silicon protective coatings at the connections. 4 way Diseqc supplied with STB should have caps on the unused ports to keep moisture out. Good luck.
Dec 16, 2009 | Humax HFA100 DTV Receiver
How do you connect a Sansui STB-HD01 (set top box) to an LCD tv?
Hi trishallan! I will be more than glad to assist you in this concern.. On the back of your Sansui STB-HD01 (Set top box) there is an input name - ANT In- Attached an external antenna to this terminal. If your LCD TV is an HDTV you can use the HD-YPbPr (you will see there Red, Green, Blue) on the back of the Sansui-STB-HD01, The cable that your going to use is the component cable - the color is Red, Green, Blue) - connect the 1st end to the back of the sansui-set top box and the other end is going to your LCD-TV. If your LCD TV is not and HDTV you cand use the other terminal which is on the right side of the HD-YPbPr, the SD-YPbPr, you can use the same cable - the Red, Green, Blue, .. then there is s display switch-Set this switch in conjunction with MODE switch according to your TV display capability.and there is a mode select- Set this switch in conjunction with DISPLAY switch according to your TV display capability, then u need to tune in the tv to compionent channel, use the LCDtv remote to cycle the input of your tv.
if you have any query please feel free to get in touch..
Aug 28, 2009 | Televison & Video
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Toshiba vcr will not recoganize digital from sansui tv
connecting your vcr through your cable or satelite receiver instead of your t.v. should solve this issue.. i hope this solution resolved your issue...
Dec 16, 2008 | Sansui DFTC2000 20" TV
Sansui 6010
Firstly, you're kidding right?
If not, follow the manual which can be found with a google search if you don't have one.
Once you set the clock properly you should have no problem programming the future record time.
Good luck and please tell me you don't drive a vehicle on the roads...
May 28, 2008 | Sansui VHF6010 VHS VCR
Hi, I have a Sansui high
i have same problems has any resolved this yet??
Mar 25, 2008 | Televison & Video
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
