Epson stylus dx7450
I have installed the software for this printer - in German!
I heve tried to re-install it but there was no option about language - any idea how I might change from german to englis?
  • 12 more comments
  • Anonymous Apr 21, 2008
    help!!!! how do i get my dx7450 in english???
    have tried numerous sites but no help.
    please give me your infp.
    thanx
  • clarebear22 Jun 01, 2008
    i have installed my epson stylus DX7450 a few times to get it from german to english and have not been able to manage it, i have gone on to the epson site to get help and have found no solutions please help! i`m very frustrated!!!
  • moonpie-x Jun 05, 2008
    what do I do once I get to select the OS to change to English?
  • Anonymous Jun 13, 2008
    i ve lost the cd intallation i am looking for downloading from web
  • Anonymous Jun 18, 2008
    epson stylus dx7450 i want it to print instructions in engiish.
  • mjjhook Jul 16, 2008
    printer information shown on screen is in german have reinstalled on computer but no question about language.
  • Anonymous Aug 02, 2008
    Printer instructions are all in German -- have tried to reset but there is no option for changing the language to English.
  • Anonymous Aug 12, 2008
    this problem not contained in instruction booklet
  • Anonymous Nov 01, 2008
    I have the same problem, but I think the language is French instead.
    Epson Stylus CX3810
  • Anonymous Nov 11, 2008
    Mine is in German!
  • Anonymous Dec 02, 2008
    don't even bother trying the epson website because the support section of the website loads as an error, its a f*cking joke
  • louise35 Feb 23, 2009
    lol how do you print these instructions off so you can follow them heheheh. will be back with my review when it works xx
    Hooray that worked I now have an english printer thanks Grey xx
  • ormandyb Mar 25, 2009
    the epson has installed in german how can i change it to english
Windows uses a foreign language information file when installing a printer driver via USB. This then installs the associated foreign printer driver and utility files.
This can be corrected with a full uninstall of the printer driver. The standard uninstall will not remove the original foreign language files. Please follow the steps below to install the English version of the printer driver:
Step One:
Switch off and disconnect the printer. Go to Add/Remove Programs in Control Panel, and remove EPSON PRINTER SOFTWARE (this may be named in a foreign language like 'EPSON DRUCKER SOFTWARE' - when you are at this stage and have selected to 'change/remove' this item, a window will appear titled 'EPSON Printer Utility' - above the icons of each of your EPSON printers will be a 'Printer Model' tab and 'Utility' tab (Note, if there is no Utility Tab then just continue). Please click on one of the printers so it is highlighted, then select 'Utility' - please tick every box listed in the 'Utility' section and select 'OK'. Answer positively to all questions and once the uninstall is complete, you will need to follow the same procedure to remove the other EPSON printer drivers by clicking on 'EPSON PRINTER SOFTWARE' again and 'CHANGE/REMOVE'.
Step Two:
Open up Windows Explorer or My Computer, and navigate to the drive (usually C) where windows is installed. Browse to the folders called windows/inf on XP, or winnt/inf on 2000. If you can not locate the INF folder please go into the START MENU and select RUN. If there is any text within this box please remove and type C:\windows\inf and press enter. Please be advised that 'C' represents the hard drive on your PC. If your hard drive is a different letter please amend as necessary.
Find the files labelled OEMxx.inf or OEMxx, where xx is a number from 00, 01, 02 etc upwards. You will need to double click on each INF file in turn, and if it says “SEIKO EPSON” or “EPSON” within the first few lines, then you need to close the file, and then delete it. Please also can you delete the corresponding PNF. Repeat this until all EPSON INF files are removed.
Note: You cannot open a PNF file.
Step Three:
Staying in Explorer or My Computer, stay within the windows folder (winnt folder on 2000) and navigate to system32/spool/drivers, and go into the folder named "w32x86". Delete any folders that begin with "epson", and then restart. Once rebooted, empty the recycle bin, and attempt reinstallation of printer, using the instructions below.
Step Four:
MAKE SURE YOUR PRINTER IS STILL SWITCHED OFF AND DISCONNECTED AT THIS POINT. Insert your driver CD. Double Left Click on My Computer and select your CD drive by right clicking on the CD icon and select open. When you first open/browse the CD-Rom then you should see various folders. Please browse to the Common Folder. Within here select the Printer Driver Folder then choose the WinVISTA/XP_2k folder. Run the Setup.exe file and complete the installation as normal making sure you only connect the printer when requested to do so.
Step Five:
Once this has completed installing, please remove the CD from the CD drive and reboot the PC. The foreign language tabs will now appear in English.
Posted on Jan 05, 2009
    New Friend:
Posted on Jul 25, 2013
    Genius:
  • 1,027 Answers
Try the epson site, select UK etc. etc.
HERE
Posted on Mar 16, 2008
  • Mark Williams
    Mark Williams Mar 16, 2008
    The link I provided is for UK, select ALL-IN-ONE, Select Stylus Dx-7450, Select OS
Have epson stylus dx7400 without cd. Want to
I have an Epson stylus DX7400 for some reason when I installed the printer language is in German. My disc is broken therefore I am unable to reinstall. What can I do?
Sep 21, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Change language from german to english on my epson dx 6000 printer?
When you install the printer it asks the language in which you want to install the printer in the beginning of the wizard. You have to uninstall the printer software and then reinstall it with English language.
Aug 02, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Default language is German
Uninstal driver.And when installing the driver choose English folder as drivers folder.
Apr 12, 2010 | Epson Stylus DX5050 All-In-One InkJet...
How do I change from German to English on my Epson
you've installed the software there is a language option somewhere in the set up.look on the Epson website and down load the latest set of programs & driver in englishremove the old ones firsthttp://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=vRaxNXeC8zji0Ysb1U002F3rPxD0p00NXrm3&tc=6
Jun 15, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Installed in german not english
are you saying the german language you can see this on the computer? or are you saying the words on the printer appears to be in german?
If the words you can see on the software you only have to uninstall the printer driver and download and install the driver from the epson.com website just select your product name and your operating system.
Mar 01, 2009 | Epson Stylus CX3200 All-In-One InkJet...
How do i change the language to english on my epson stylus 4050 p
hello
plz tell me the model of the printer?. maybe you need to download the right language software for your printer. go to the www.epson.com site.
Feb 23, 2009 | Epson Office Equipment & Supplies
All the setting pages have changed language
My guess is that you have a language specific version of the driver that does not contain the English language files.
I suggest getting the latest driver version from Epson and then uninstall the old version before installing the newest.
If this still doesn't work, contact Epson...
Feb 16, 2009 | Epson Stylus Photo R1800 InkJet Printer
Default language German
alta vist babel fish is an online translator use it to figure out how to switch to english
Dec 03, 2008 | Epson Stylus Multifunction Inkjet Printer/...
EPSON STYLUS DX7450
can you help change the lanuage settings on my epson stylus dx7450.its in gemanand i want to change back to english.
Nov 07, 2007 | Epson Stylus DX6050 All-In-One InkJet...
Language
i have the epson stylus cx3200 and the main printer options are in english (ie number of copies ect) but the rest are in french!
Oct 16, 2007 | Epson Stylus CX4800 All-In-One InkJet...
2,323 people viewed this question
k24674
jasbo
jasbo
