Question about Acer Aspire™ T180 PC Desktop
Aspire? T180 power supply appears to be working dvd drawer opens etc but no standby light and no screen display?
  • Acer Master
  • 19,396 Answers
If the PC does not to any beep then usually is a problem with the motherboard.
If the PC does a certain number of beeps on startup, then tell me how many beeps to troubleshoot the problem.
If the computer does single beep on startup as usual, then may be the monitor, monitor cable or graphic adapter.
Simple thing that you can do it yourself is disconnecting computer power cable from power outlet for 15 -12 mins. ac connect it back, this will solve troubles caused by electrostatic charges.
Also check video cable connections to monitor.
If you have another computer also test the monitor on other computer.
If the main unit is not booting (CD drives and internal fans often start up even if the Motherboard is blown). Then yo need to open the pc and test component inside.
If you have practice in fixing hardware you can start removing RAM modules and testing them, then buy a tester board for the MB and do a diagnostic test on motherboard.
Other options are taking PC to service or getting a new PC.
If the PC is still under guarantee, then contact Acer to validate your guarantee and get the machine to an authorised service centre.
Posted on Mar 16, 2008
My acer t180 freez in screen acer
Mine had the same problem. I left it on for 30 mins and it finally booted.
Have you tried the step of removing battery and unpluging power supply for at least ten minutes ?
Apr 21, 2012 | Acer Aspire™ T180 PC Desktop
I can only add 2Gig of Ram on my Acer Aspire t180 XP. The screen flickers when I add more. Help
The usual cause of screen flicker is a lack of power getting to the graphics card. The best way to check this is to remove another component to see if the flicker stops. If it does stop you need to upgrade the power supply.
Upgrading the power supply is a simple job. Let me know if you need more information on replacing the power supply.
Dec 27, 2010 | Acer Aspire™ T180 PC Desktop
I have a Acer Aspire T180 that doens't boot. The problem: When I hit POWER for about 1 second a red led is burning. After that; silience at all.. I don't hear any fan or noise from the powersupply. Nothing...
first you have to check if the power supplyof your CPU is not defective.or your power the one that is connected to the AC outlet. replace the power and try to turn it on if still not working purchase a new power supply that fits to your PC ....its up to you how many wattage your going to buy
Oct 09, 2009 | Acer Aspire™ T180 PC Desktop
I was watching my kp61v80 and the screen went black-can you give me the trouble codes for the flashing standby light
Diagnosis item
Number of blinks
Supposed malfunction Condition
screen display,
Diagnosis item: Results
•Power not ON 0
[Standby Power Supply System]
F601 open.
R607 open.
Q601 short circuit
[Main Power Supply System]
IC601 and R612 are broken.
VDR601 short-circuit
Cannot turn on the power.
LED doesn't blink.
+B OCP detection 2times Short circuit of power supply system in each circuit.
Goes to the standby mode
Short circuit of +B line
2 : +B OCP 000
+B OVP detection 3 times
T603 pin 78 open.
R672 open.
Malfunction of power supply circuit
3 : +B OVP 000
Vertical deflection stop 4 times
IC1509(V out) is broken.
Q1505(V Pulse Buffer) is broken.
Raster goes to one line horizontally, Aand then video
signal is muted.
4 : V Stop 000
Video out abnormality detection 5 times
Video out, Q705, 732, 761 and others in C board
Q218, 219, 220 (A board)
TIMER/STANDBY LED blinks approx. 30 seconds,
and then blinks for the self diagnosis.
5 : AKB 000
Horizontal deflection stop 6 times
C515, 516 open.
IC206(YC Jungle) is broken.
Raster doesn't appear. 6 : H Stop 000
Audio abnormality detection 8 times
IC406(Audio amp.) is broken.
PS401, 402 open.
The sound is not out.
8 : Audio 000
Jun 17, 2009 | Televison & Video
Acer T180 will not boot or power on. It has a bad attitude!
Try tapping F2 as it is booting to get in safemode. If that works we're in business.
Dec 29, 2008 | Acer Aspire™ T180 PC Desktop
Onkyo DV-SP301 DVD player stuck in standy mode
Had an Onkyo DV-SP301 that would only intermittently come out of standby. Found faulty resistor R2 on the power supply board (board ORTP-865), it was nominally 5600 ohms, measured much higher. This after checking most p/s caps! R2 runs warm when unit is in standby, so you may want to replace with a higher power rated resistor. I used same rating but 10 k ohm instead, worked fine then.
Nov 28, 2008 | Onkyo DV-SP301 DVD Player
System standby or hibernating feature
That should be on all Windows Computers.
Control Panel -> Power Options.
Play with the values to your hearts content.
Oct 07, 2008 | Acer Aspire™ T180 PC Desktop
Stuck on Standby
Do a hard reset. Unplug it from the socket, the DVD and leave disconnected for 4 hours. This may or may not help, but it is a necessary step to restore all internal software codes to their factory settings.
Hope this may help;
Aug 28, 2008 | JVC XV-523 DVD Player
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
Acer Aspire™ T180 PC Desktop Logo
308 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
