Question about Sony KV-27FS13 27" TV
Digital does this set have a digital tuner?
  • 129 Answers
Good day,
Yes, it has a digital tuner. It is functioning based on the command set by the buttons or signal/command from remocon.
chris
Posted on Mar 23, 2008
Using a digital antenna to channel scan for broadcasted channels
It is no different that channel scanning for cable or analog over-the-air channels. You simply ensure that you have selected the digital tuner of the set prior to scanning. Some older flat panel sets do not have integrated digital tuners. A digital antenna alone will not allow these sets to receive digital broadcast channels. A converter box is needed to convert the digital broadcast signals to analog for the tuner in the set. Also, sets that do not have digital tuners may not support the resolution rate of digital TV broadcasts. Most digital HD broadcasts are 720p and a few are 1080p.
Jul 28, 2016 | Televison & Video
Where can I buy a digital tv tuner to replace the analog tuner in a DVDRHD04
Generally recording machines fitted with an analogue tuner can only continue to be used to record digital tv by using a digital set-top box.
It would not be practical or economic to remove the internal analogue tuner and replace it with a digital tuner unless the person is a highly skilled and experienced repairer.
Digital set-top boxes are available from all sorts of outlets at all sorts of prices. Many surplus boxes can be found at boot sales, garage or yard sales or charity shops at very low prices.
Most boxes have the minimum of connections and often offer only a scart output but some of the older, more expensive and usually better quality boxes also contained a UHF tuner in a similar way to the old vhs recorders so even older tv sets could be used with digital even though no scart input was fitted.
Dec 03, 2015 | iLO DVDRH04 DVD Recorder
Model c-13910. Does it have a digital tuner?
most crt tv's such as this do not have digital tuners built in and would require a set top box to receive digital signal i know that in Australia where i am we no longer use analog signals so all tv's must have a digital tuner or set top box in order to still work
Nov 03, 2015 | JVC Televison & Video
Cant seem to tune in after digital switch over not got any chanels
If your TV is an older variety that wasnt set up for digital signal you will need a set top converter box.
Jun 22, 2011 | Toshiba Televison & Video
Does this model DVD/VCR recorder have an analog tuner or a digital tuner?
Is there a manufacture date on the back of it. The Commission's digital tuner rule specifies that as of March 1, 2007, all new TV sets must include digital tuners. I believe that rule follows when it comes to DVD players with built in tuners. If you bought this before that date then most likely its analog. I see in the owners manual has no listing for a digital tuner. So I would come to the assumption that its analog tuner. Hope this helps!!
Jan 14, 2011 | LG LRY-517
Can the tuner be upgraded to get digital signals?
There is no way to directly change the internal tuner to receive digital/HD signals. I would simply purchase an external tuner unit, but be sure to get one that has at least component signal outputs and is HD. You want to be able view HD & not just digital. One of the small tuner boxes would get digital, but not HD. I personally have a Digital Stream tuner with a set I own and have been very pleased with it. The tuner has many extra features and also has an NTSC output I use for recording with a regular vcr. Shop for an HD tuner unit. You will be impressed by the kind of performance you will get from this set.
Nov 09, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Do I have digital tuner?
No, this set does not have a digital tuner. The TV must be an HDTV in order to have a digital tuner built in.
Dec 31, 2008 | Sylvania 6720FDF
Zenith B32A24Z Digital Tuner?
I have an B36A24Z Zenith TV set Does this set have a digital
tuner?
Jul 13, 2008 | Zenith B32A24Z 32" TV
Is my tv digital compatible or not
https://www.dtv2009.gov/FAQ.aspx What you need to know is whether your TV set has something called a “digital tuner” already built in. If it does, your TV set will work after February 17, 2009. The best way to determine whether your TV set has a digital tuner built in is to consult your owner’s manual. If that’s not possible, you may be able to look up information about your TV set on the manufacturer’s website. Or, you can take an up-close look at your TV set. In any case, you’re trying to find out if your set has an input connection labeled “digital input” or “ATSC” (for Advanced Television Systems Committee, which is the DTV format).
Here are some general guidelines that may help:
TV set made before 1998 was a traditional “analog” set. If you bought a big-screen, projection TV between 1998 and 2004, it may have a built-in digital tuner inside. But chances aren’t great. Only a limited percentage of projection TV sets (and generally only those 42 inches in diameter or larger) included digital tuners before 2004.
If you purchased a new TV set since 2004, your chances of having a built-in digital tuner improve dramatically. Starting in 2004, many of the TV sets sold at popular electronics stores feature digital tuners that will work after February 17, 2009. But it’s not a sure thing. Even some of the newer TV sets are purely display monitors that lack the internal circuitry needed to pick up digital broadcasts. Usually these sets have been advertised as “HD-ready” or “HDTV monitor” sets. That means they can display digital and high-definition signals, but they need help getting those signals in the first place. You’ll still need a special converter or a cable TV connection. Hope this info above helps. Also, check your manual, and if you don't have it some manufacturers, (Philips does for some models) offer the manual on their websites.
Apr 07, 2008 | Philips TV Tuner Video Capture PCI Card -...
Problem with digital tuner.
Talked to Hitach and yes a dicky tuner. but it's ok they will replace the tuner card but it will take 4 weeks to get one. :o(
So I have my nice new TV but I can not use it for 4 weeks
Not happy.
Jan 13, 2008 | Hitachi 42PD7800 42 in. HD-Ready Plasma...
Sony KV-27FS13 27" TV Logo
41 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
