Question about EPoX EP-9NPA+ SLi Motherboard
Cant run dual channel.
Why cant I run in dual channel mode with amd 4400+ x2 ? The RAM ran in dual ch. mode with 3800+ x2, why not with the 4400+ ?
Epox EP-9npa+ sli
2x1gb Ocz Platinum
Bfg 8800GTS 512
Amd 4400+ x2 Toledo
2x WD 250gb Raid 0
bios version 6.00pg
Apeiva 550w PS
  • CYBERJ Mar 23, 2008
    I'm sorry I forgot to mention EPoX customer support is ****. Even though I thought I was good, I did as you instructed but in-fact I do have the most updated chip set drivers and bios. I would like to mention your willingness to help and support is outstanding. What is going on is I cant even get it to post when ram is in dual channel config. with the 4400 x2 just beeps & error code C1 I have tried all possible configurations, it will only boot in single chan. But seems to run OK ( 8450 3D Marks @ 2.6 ghz single chan.) I put the 3800 X2 back in and runs fine in dual channel (8230 3D Marks @ 2.4 ghz dual chan.) Also the 4400 x2 runs dual chan. fine in my wifes HP, WTF?? All I can think of is that either the board or bios dosent support the 4400, I just cant figure out
  • 2,351 Answers
You can update your chipst nVIDIA nForce4 SLi.
This is not a easy task. It requires you to download the proper drivers. nForce will do this for you by checking your current system. Click this link to nForce:
Do not update your system by doing an install. You will have to remove the current nForce devices manually through device manager. (DO NOT restart your PC untill you have replaced the nForce drivers with updated nForce software).
If you do, you'll find your going to have to do a complete reinstall of windows & you will loose your current data.
Updating your ssocket 939 will run better. Your dual channel should post after update. It was a waste searching EPoX for faq's. Couldn't even download their/your manual. Please read recommended files to help with the update, these are worth every minute. (I learned the hard way).
Good Luck & Kind Regards.
& please vote.
Posted on Mar 19, 2008
  • Mike Peluso
    Mike Peluso Mar 19, 2008
    After a couple restarts check your windows for updates.
  • Mike Peluso
    Mike Peluso Mar 24, 2008
    CYBERJ, if your still haveing trouble try testing your memory. Download
    ** Memtest86+ V2.01 (21/02/2008) **
I have an asus m2n mx (windsor) motherboard and an amd athlon x2 3600+ processor . . . i have a pair of 667mhz 512MB (total 1GB) ram and a pair of 800mhz 1GB (total 2GB). . grand total(3 GB) . . My problem...
The manual for your motherboard states:
For dual-channel memory configuration (2), you may:
• install identical DIMMs in all four sockets OR
• install an identical DIMM pair in DIMM_A1 and DIMM_B1 (yellow
sockets) and another identical DIMM pair in DIMM_A2 and
DIMM_B2 (black sockets)
* Always use identical DDR2 DIMM pairs for dual-channel model. For
optimum compatibility, we recommend that you obtain memory modules
from the same vendor.
Sep 11, 2011 | ASUS M2N-MX Motherboard
Acer aspire m5100, AMD Athlon 64bit x2 dual core processor 5000+ 2.60Ghz. Win Vista Business 64bit. When i upgrade and put more than 3GB of ram into the machine, it turns off the lan and my display driver...
Acer official site says:-
Up to 4 GB DDR2 533/667/800 MHz SDRAM
(dual-channel support on four DIMMs)
Try these bus speeds and for dual-channel support read this article :-
Dual-channel architecture requires a dual-channel-capable motherboard and two or more DDR, DDR2 SDRAM, or DDR3 SDRAM memory modules. The memory modules are installed into matching banks, which are usually color coded on the motherboard. These separate channels allow each memory module access to the memory controller, increasing throughput bandwidth. It is not required that identical modules be used, but this is often recommended for best dual-channel operation. It is possible to use a single-sided module of 512 MB and a double-sided module of 512 MB in dual-channel configuration, but how fast and stable it is depends on the memory controller.
If the motherboard has two pairs of differently colored DIMM sockets (the colors indicate which bank they belong to, bank 0 or bank 1), then one can place a matched pair of memory modules in bank 0, but a different-capacity pair of modules in bank 1, as long as they are of the same speed. Using this scheme, a pair of 1 GB memory modules in bank 0 and a pair of matched 512 MB modules in bank 1 would be acceptable for dual-channel operation.
Modules rated at different speeds can be run in dual-channel mode, although the motherboard will then run all memory modules at the speed of the slowest module. Some motherboards, however, have compatibility issues with certain brands or models of memory when attempting to use them in dual-channel mode. For this reason, it is generally advised to use identical pairs of memory modules, which is why most memory manufacturers now sell "kits" of matched-pair DIMMs. Several motherboard manufacturers only support configurations where a "matched pair" of modules are used. A matching pair needs to match in.
Good luck
Rate the solution if got help
Dec 06, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
I want video,lan,audio drivers for amd athlon 62*2 dual core 3800 processor
you need to go to the web site of motherboard to get them if you have a asus go to it jim
Nov 17, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
My wife's computer is an Acer Aspire 5100 with a 4000 AMD Athlone 64 processor. It came with only 1 GB of memory and is runniing Vista Home Basic. It is terribly slow and I would like to increase the...
yes one will be for single channel ram the other for daul channel ram.if you have the acer owners manual it will tell witch ones are single and witch one is daul.
Sep 21, 2010 | Acer Aspire 2100 (91.AB675.D02) PC Desktop
AMD 64 x2 dual core processor 3800+ speed problem.
increse your RAM to a heigher is necessary to load large graphics.or insert a graphics card
Aug 19, 2009 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Nvidia 9500GT frame rates
try 2 matching pieces of ram (both speed and size)
hope this helped
Jan 18, 2009 | Computers & Internet
Type of ram
ASUS A8N-SLI Premium Specifications
CPU: Socket 939 for AMD Athlon 64FX / Athlon 64 /Sempron / Athlon 64 X2
Chipset: NVIDIA nForce4 SLI
Front Side Bus: 2000/1600 MT/s
Memory: 4 x DIMM, max. 4GB, DDR 400/333/266, ECC, non-ECC, un-buffered memory, Dual Channel Architecture.
Expansion Slots:
2 x PCI-E x16
- SLI mode: x8, x8
- Default (single VGA): x16, x1
1 * PCI-E x 1/ 1*PCI-E x 4(x2 mode)
3 x PCI
Storage/RAID: nForce4: 4 x SATA 3Gb/s
NVRAID: RAID0, RAID1, RAID0+1 and JOBD span cross SATA and PATA
2 x UltraDMA 133/100
Silicon Image 3114R RAID controller
4x SATA with RAID0, 1, 10, 5
Audio: Realtek ALC850, 8-ch High-Definition Audio CODEC
LAN: nForce4 built-in Gbit MAC with external Marvell PHY MARVELL PCI Gbit LAN controller
or see this site:
Oct 30, 2008 | ASUS A8N-SLI Premium Motherboard
Open Questions:
won't boot into fresh installation of xp pro on raid0 drives I performed a fresh installation of windows xp pro on raid0 drive array. the entire process goes without a hitch...until windows is completely loaded, and its time to actually boot into the operating system to continue with chipset and other driver loading. I get the normal posting and system info screen, goes on to screen "detecting array, healthy Nvidia RAID", continues to screen looking for boot device, verifying dmi pool, boot from CD?..., then proceeds to a notification and selection screen: "start windows normally", safe, ... That's it. I will not boot into Windows normally, nor into SAFE mode. It will cycle through the above 3 screens until I just shut it down. I have gone through this process 4 times (format & reload), thinking that some BIOS settings were overlooked on the previous attempts. I have SATA ports and RAID enabled in the BIOS. I've checked several times to make sure that they remained. Windows will install and run normally on a single SATA drive. I only have this problem when I stripe it. Incidentally, I had reloaded this computer 2 times previously, without any problems with the RAID. Further, this is a RAID floppy taken from the original MB CD, not something new to the system hardware. I feel like there must be something stupid-simple that I am overlooking. But I have been unable to find the answer. System: Epox 9NPA+SLI, 2GB PC3200, 2x80GB Seagate SATA2 drives, AMD FX55 cpu, Evga PCIx video card 7900GTS, Aopen DVDRW Any help you can offer will be greatly appreciated. Regards, Rick Stacy
Apr 06, 2009 | EPoX EP-9NPA+ SLi Motherboard
EPoX EP-9NPA+ SLi Motherboard Logo
149 people viewed this question
Top EPoX Computers & Internet Experts
Steven Wander
Steven Wander
Are you an EPoX Computer and Internet Expert? Answer questions, earn points and help others
