Question about Samsung Cameras
My samsung s750 camera keeps showing a low battery sign even with brand new batteries installed and camera keeps shutting down,thanks for any help michelle the bomb webster
A common problem i've found with many digital cameras is that the battery contacts can become dirty. Use a rubber eraser on the end of a pencil to rub the gold plated battery contacts. This should clean them very well and may very well resolve the issue.
Posted on Aug 24, 2008
I have the same problem with this brand. It's good but it is consuming batteries.
really I hate it for that and I advice all customers not to buy this sumsung.
dubai
Posted on May 30, 2008
Whenever i try to take a photo with my samsung s750 it just turns off andthe only way i can turn it back on is to remove the batteries and put them back in again plz help
It sounds as if your batteries are too low to function and need to be replaced. Batteries will rebuild a small amount of voltage once taken out of the camera, but once you push the button for a picture, the load is too much, so it shuts down.
Rechargeable batteries only recharge so many times.
You can try to clean the ends of both the batteries if they are exposed, as well as attempting to clean the contact they connect with if you see any corrosion. There's not much to do with plug in type batteries.
A pencil erasor is abrasive enough to remove light dirt/dust, then wipe to remove anything remaining.
Good luck.
Mar 25, 2012 | Samsung Digimax S750 Digital Camera
Low Battery Light Even with Brand New Lithium Batteries
If indeed the batteries are brand new and without a doubt charged,
then you definitely have a hardware problem in the camera.
You're probably going to have to give it in to be serviced.
Hope I helped!
Tom
Jun 18, 2009 | Samsung Digimax D53 Digital Camera
Says low batteries and shuts off. Batteries are brand new.
1. clean and adjust the springs in the battery compartment
2. use the right batteries, alkaline or NiMH, etc.
this tips may help
Why my camera keeps saying ‘change battery’ even with new batteries?
May 18, 2009 | Panasonic Cameras
Hi i have a samsung s750 but i can't take pictures because the screen is blank so i don't know what i am taking
Hi, I can help you. First, make sure you can see the menu by turning the camera on and pressing the menu button. If you can see the menu, scroll to the right to reach the setup menu.
Then scroll down to Quickview and then scroll right. Then scroll down to 3 sec and hit the Ok button.
That should fix your problem. If I can help you anymore, let me know, and thanks for coming to FixYa. Don't forget to vote my solution a fixya.
Rob
To the person with the camera showing low batteries even when they are new, make sure the battery door is on tight. Over time with use, the door can get loose. If it's loose, it will not make a good connection with the batteries and freeze up. Hope that helps. Let me know with a comment if you need more help. And don't forget to vote!
Rob
Feb 03, 2009 | Samsung Digimax S750 Digital Camera
Replace battery sign in New canon A590si camera.
You're using the wrong batteries. You need to purchase lithium batteries. They are quality batteries for high powered, battery operated electronics. Personally, I have a battery charger and use rechargable duracell batteries. (HR6/ DC1500/ NiMH/ 1,2V) Gives you approximately 16 hrs before having to recharge.
Dec 01, 2008 | Canon PowerShot A540 Digital Camera
Erratic Low Battery Warning
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Nov 05, 2008 | Canon PowerShot A560 Digital Camera
Low Batterie Sign
I had the same prolem. OK, try this. Try to discharge the AA batteries in some use, flashlight or else,,,,then recharge them, full charge, install the batteriers ...they should work fine....
I read somewhere that canon is able free of charge to correct a shortcircuit that the camera is susceptible to develop in the installation of batteries......But I hope the advise will work...
Remove batteries when not in use.
Oct 03, 2008 | Canon PowerShot A540 Digital Camera
How do u charge battery
well u can't "charge your battery", you have to put new ones in
Sep 09, 2007 | Vivitar ViviCam 3785 Digital Camera
Camera says brand new batteries are dead, then shuts down
It is possible that the batteries are dead (they might be faulty or too old) even when they are out of the package, though unlikely. Try another set of batteries, and if these don't work, you'll probably have to send it for a checkup.
Oct 28, 2005 | Fuji FinePix 4700 Zoom Digital Camera
Cameras Logo
291 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
