Question about JVC HX-D77 Shelf System
VOLUME CONTROL PROBLEM.
WHEN I TURN THE VOLUME DOWN IT DOESNT LIKE TO GO DOWN RIGHTAWAY,SOMETIMES IT GOES UP VERY FAST WHEN I'M TURNING THE KNOB SLOW, OR WHEN I TURN IT UP SLOWLY THE VOLUME GOES DOWN,IN ORDER TO USE THE VOLUME KNOB I MUST GO VERY VERY SLOW. IT HAS DONE THIS EVER SINCE I TOOK IT OUTTA THE BOX. I WOULD HAVE TOOK IT BACK TO BEST BUY , BUT I DIDNT TAKE IT OUTTA THE BOX UNTIL I MOVED INTO MY PLACE, WHICH WAS PAST THE 90 DAY RETURN POLICY. SO, IS THERE A RECALL ON THIS ? OR EVEN SEND ME THE PART THAT WOULD FIX THIS?THANK YOU .
  • 4,234 Answers
If the volume control can be turned continuously in either direction (no stopping), then the control is what is called an encoder and the behavior you are describing is an internal logic failure. If the control has an upper and lower limit (only turns so far), then it is a standard volume control and is physically broken and needs to be replaced. In either case, the unit should be under warranty. Return it to Best Buy for repair. Given that it just came out of the box, talk to a manager and request an exchange.
Dan
Posted on Mar 18, 2008
SOURCE:
Why could my volume knob be stuck on max volume and not adjusting?
There is probably grease or dirt on the contacts inside the unit. Here's a video that shows you how to fix it:
http://www.youtube.com/watch?v=y4XF9PoidJQ
Hope this helps!
Aug 08, 2014 | Marantz SR-4320 Receiver
Why does the volume increase when I'm trying to turn it down on my AIWA receiver?
Your volume control is bad. If you are good at this kind of stuff, you can remove it from the board, open it up and clean the contacts. Otherwise you need to get it replaced.
Jul 20, 2014 | Audio Players & Recorders
Huawei problem
phone is huawei ascend g510.very slow and unresponsive sometimes.
May 29, 2014 | Huawei ASCEND G510-0251 Unlocked GSM...
Radio volume goes up and down when its on a low volume not on high
Check the dealer and see if your radio automatically adjust to your speed. Some radios were built to raise the volume when driving at higher speeds and when you get in slow traffic or when you stop it would automatically adjust down the volume. You can also go to a Radio Shack and get a spray cleaner for electrical parts and pull the volume knob off of your radio and spray the volume control and turn it rapidly to remove any hidden dirt on that volume control.
Sep 13, 2009 | 2003 Chevrolet Tahoe
Honda Civic Issue with Radio Volume Control
This is a known problem with the factory units and no, there is no fix. There is a series of checks you can do, but short of that the only option has been to replace the unit. I have included the graphic for the checks, other than that it is not fixable.
Sep 24, 2008 | 1996 Honda Civic
Car radio volume control knob is erratic
When I turn on my radio, the volume is on and o.k. but when I try to turn it higher or lower the volume is lost completely. Any comments?
Jul 06, 2008 | 2001 Pontiac Aztek
Volume
the volume control needs to be cleaned. this control is a step switch basicly. and the switch contacts are not making proper contact. cleaning this requires dis-assembly and desoldering so if you are inclined to do this work happy fixing if not it shouldn't cost much to fix.
Jan 19, 2008 | Aiwa NSX-A115 Shelf System
Volume
This sounds like a case of a dirty/defective rotary encoder. The volume control used here is not the conventional potentiometer type , but a rotary set of switches that tell the sytem if the knob is being turned left ot right.
Do you think you'd be able to open the unit and spray some contact cleaner into the rotary encoder? It might involve dis-assembling it down to front bezel removal.
jango.
Aug 18, 2007 | RCA RS2044 Shelf System
Volume knob
Hi Your Problem need an expert Technician, this Aiwa stereo has the digital type volume control that gives pulses to the cpu to make volume up / Down. Solution to be fixed by a technician: - Remove the volume from the front board, disassemble it and clean the conductive parts inside it then reassemble back and check. Good Luck Toufic G. Malek
Aug 02, 2006 | Aiwa NSX-A777 Shelf System
JVC HX-D77 Shelf System Logo
357 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
stynger007
Level 1 Expert
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
