Question about Philips 190B6CB/27 19" LCD
Osd locked - Philips 190B6CB/27 19" LCD
  • Anonymous May 08, 2008
    I have the message which says that the OSD menu locked and I do not know what to do to solve this problem
  • Anonymous Feb 16, 2009
    i have the same problem osd main controls lock helppppp someone
  • 8 Answers
Hold the menu/ok button for ten seconds, to unlock the OSD.
If this doesn't solve the problem, then it's probably the button that got stuck.
There are two things you can do to repair it, but both require that you dismantle the casing, which voids any warranty.. so, if the monitor's still covered by the warranty, or if money is not an issue, have it repaired by professionals on an accredited brand shop (check your warranty details for more information on this subject).
If not, remove the casing, locate the menu button's contact switch on the circuit board, and try to release it using something thin like a screwdriver, x-acto knife, or set of plyers.
If this doesn't work, chances are the menu button is stuck on a loop, sending a continuous signal to the board (which keeps locking/unlocking the OSD).
If so, your only solution (other than take it to a repair shop) is to remove it, by prying it off with a screwdriver or set of plyers.
Of course, you'll lose access to the OSD features, but I guess this is better than to have a message stuck on front of your screen all the time..
This is a tried and working solution, since I had this problem myself (with a Philips 190B monitor), and solved it successfully, with this method.
Posted on Sep 25, 2008
My computer says OSD locked , ive tryied every thing and nothing worked , HELP!!!!!!!!!! PLEASE
On screen display is locked. Fix it by:
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD. Source(s): http://h10025.www1.hp.com/ewfrf/wc/docum...
Aug 12, 2011 | Computers & Internet
"OSD LOCKED" box on my screen
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
Can not stop monitor from truning on then off. then it says osd locked.
OSD Lock
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for 10 seconds.
plz do rate the solution if helped
Nov 22, 2010 | HP L1506 15" LCD Monitor
The brightness icon stays on my screen
May need to do this with if off (OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then press power button to turn the monitor on.)
Oct 31, 2010 | Office Equipment & Supplies
Osd locked , keeps flashing on screen
hi
vote me if you have your solution
Aug 11, 2010 | Computers & Internet
Show "OSD Locked".in that cause i-Menu is not working. what i do?
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD. Source(s): http://h10025.www1.hp.com/ewfrf/wc/docum…
May 15, 2010 | Computers & Internet
What to do to unblock osd lockout
You can download user manual here: http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=447388&
See Page 54:
? OSD Lock — The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message "OSD Lock" displays for 10 seconds. ?If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD. ?If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Please leave good rating, thanks.
Mar 31, 2010 | HP vs15 15"LCD Flat Panel Monitor
MY LG FLATRON L1951S, THE OSD IS LOCKED. HOW CAN I UNLOCK IT.
Mar 14, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
Help me my system is OSD Lock give me the solution.
Option 1: OSD lock - all 4 buttons are locked except the "POWER"
button. Press and hold the "MENU" and ">" buttons for 3
seconds to lock the buttons. Repeat this step to unlock.
Option 2: OSD & Power button lock - all 5 buttons including the
"POWER" button are locked. Press and hold the "MENU"
and "<" buttons for 3 seconds to lock all 5 buttons. Repeat
Mar 06, 2010 | ViewSonic E70f 17" CRT Monitor
Compaq FP5315 monitor with OSD Lock out
Here is the tip to solve your problem. Hope this might be helpful to you.
OSD Lock—The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message “OSD Lock” displays for five seconds.
❏If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
❏If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Aug 07, 2009 | Philips 170S7FS 17" LCD Monitor
Philips 190B6CB/27 19" LCD Logo
1,347 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
