Northstar 941x hi. i have a northstar 941x.the last two weeks it loosees his signal and it finds it sometimes and then loose that again.my gps antenna is new.i am sure that is a problem from the main unit.how can i do a full reset?is there any update i can do?
941 doesn't do wass. Trash unit as not worth fixing
Posted on May 18, 2008
941x doesnt recognize new wass sat 32.....contact northstar for software upgrade.
Posted on May 05, 2008
SOURCE:
Need manual for Northstar 941X--gps system works
Here are the downloads, including the software need to connect from your PC to your GPS for updates, sorry no mauals:
http://www.northstarnav.com/Downloads/
Here are your updates:
http://www.northstarnav.com/Downloads/Software-Updates/
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 05, 2011 | GPS
Trackfish 6600 stops and starts again by himself many times in a few minutes; first screen map thouthand miles away from real boat position !
Try a factory reset - that worked for me when my Northstar Explorer 660 stopped by itself again and again. You find this reset commando by pressing MENU twice and then under Systems menu, if I remember it correctly. There is also a RAM Clear commando. This is done by holding the MENU button pressed when the GPS is switched off. Keep it pressed while switchin on the GPS, still holding the button pressed until the RAM Clear menu appears. You will probably loose all waypoints etc. by doing this so try Factory Reset as your first alternative. Good Luck! // Jonas, Sweden
May 12, 2011 | Northstar Explorer 660...
My Northstar 6100i display had water incursion. After disassembling and drying/cleaning out the unit, it worked fine for about a day. Then it started to flicker and lose lines, then went gray.
When electronics have taken water on, it must be dis-assembled within the hour and washed using rubbing alcohol to have a chance in saving the device. Once corrosion sets in and ic's are compromised it is already to late. The only option from your description is replace the unit for new one, because you can spend time and money to find it breaks down again days from now or even weeks.
Mar 07, 2011 | Northstar 6100i GPS Receiver
My northstar explorer 538 is not picking up signal were i am. what i can do to fix the problem
the northstar 538 does not have an inbuilt aerial (that is the 538i). You need to attach a compatible aerial and then you will be fine.
Nov 28, 2010 | Northstar Explorer 538 Chartplotter GPS...
Gps will not aquire
It needs a software update.
Jul 01, 2010 | Northstar 952 GPS Receiver
I have navman tracker 5500 gps and the gps signal not working so there is no signel but all the charter is there
I HAVE THE SAME PROBLEM.U WILL FIND THE ANTENNA IS BUGGERED.THERE ARE NO SPARE PARTS AVAILABLE FOR THIS MODEL.LESSON; DON'T BUY NAVMAN OR NORTHSTAR.I HAVE ONE OF EACH. NEVER AGAIN!!!
Nov 17, 2009 | Navman Tracker 5500i GPS Receiver
Yes my northstar 6000i keeps losing gps signal
how old is you Gps antena ,with a older one it can happen that they lose fix
Where is the Gps antena fixed inside the boat or outside
Allway try to put tha antana outside. abou 20 % more signal
Look after the antenakabel if the kabel is a little bit broken water coms inside thae kabel an the signal gets lower.
Aug 27, 2009 | Northstar 6000I GPS Receiver
Gps loses signal
It would be good to make sure that the 951 software is up to date. The most recent software upgrade includes new code required due to changes that have been made to the GPS system. You can download the software for free from the Northstar web site but it requires a loader cable, power supply and a Windows based PC to perform the update. Most Noprthstar dealers know how to do this but they will charge for their time. The GPS antenna should be mounted where it has a 360 degree uninhibited view of the sky right down to the horizon to get best performance. Basicially any conductive material including pigmented paint, tinted glass or wet canvas can block the signal. Inspect the GPS coaxial cable and it's connections for any signs of corrosion or contamination. Sometimes just removing and reinstalling the connections is enough to remove contamination and get better performance. If in doubt concerning the coax and it's connections, temporaily substitute a new coax assy by-passing the existing cable to see if this makes a difference. You can monitor changes from the GPS status page. See the user manual for information concerning how to understand the numbers being presented. You should be tracking at least 4 SATs with signal levels higher than 30. Generally 95% of all GPS signal issues are related to the coax or its connections.
coax assy to v
Jul 26, 2007 | Northstar 951XW GPS Receiver
197 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
