Error code on a T-A TA215Z copier.
Error code C5 comes up when copy cycle starts.
What does it mean/
Have you a list of T-A error code meanings?
  • Anonymous Feb 28, 2009
    hi,
    i have the same problem with my 215 Z, but the main charge wire seems OK. Warming up the copier is without problems if the main charge wire is installed or not. In both cases the error occurs when pressing the start button. Any suggestions? Thanks.
  • 168 Answers
C5 is a Main Charge Wire Error. Either the main charge wire is broken or the plastic blocks are arching out.
Open the front door, and look for a gray handle that will slide out towards you. This is usually located above the drum.
The main charge wire is a very very thin wire that charges the drum in the copy process. If the wire is broken, no copies can be made. To make sure that this is the problem, leave the charge stick out, and close the front door and let the machine warm up. If it does, then you have located the problem.
If it still show a C5 error, the the problem is in the Transfer Charge coronas which is located under the drum.
Let me know what happens, and I can try to help you further.
Good luck.
Mac
Posted on Mar 17, 2008
Culligan Mark 100 Had code C5 Doe not work. What does code C5 mean?
A lot of people mistake the "S" as a 5. The error dispaly says "CS" which means call service. You probably have a gasket hung up and need a new seal pack.
Mar 04, 2015 | Culligan Measuring Tools & Sensors
I have a Toshiba Model 1350 copier and get an error message C5. What does that mean?
hi friend ,your machine motor drive gear Broken or game or motor problem
Oct 07, 2014 | Toshiba Office Equipment & Supplies
What does error C5 mean on the Lexmark X2600 all in one printer mean?
hello
For error C5 on an X2600 printer it means that you have a defective cartridge and you need to replace it. Please see link for more information: http://support.lexmark.com:80/lexmark/index?page=content&locale=en&productCode=&segment=SUPPORT&clearQuestion=Y&userlocale=EN_US&id=SO4438
Hope this helps.
Aug 28, 2014 | Lexmark X2600 InkJet Printer
Clc color copier error code E061-0321
Disable potential control by going into service mode Copier > Option > Tempo > F-POT-SW. Now copies can be run.
1) A solid black copy means laser is defective.
2) A white copy means you should check the Primary corona and HVT.
3) A good copy means you should check the Potential sensor PCB.
Dec 01, 2012 | Canon CLC 4000 Copier
Canon ir c3220 color copier error E000020-01b0. What means? How solve that error?
Canon Error Code E000020 01b0
Although the yellow drum is indicated, in the link above, please note it may not be the yellow drum if instead it is the:"laser shutter or the plastic actuator on the right side of the front door."
Jan 24, 2018 | Office Equipment & Supplies
On our Ep3170 we get a C5 error code and the wrench symbol
Hello sir;You must remove the left side panel to access the service switch(s1) on PWB A you press this switch to chose the "C" then enter 0 press "#" ,then press "CLEAR" to terminated.
Jan 17, 2010 | Minolta Office Equipment & Supplies
I have a F2-41 code. What does this code mean?
- Impropercartridge (destination error, life cycle error) Identification error model error type error destination error data abnormality Misc error
Apr 15, 2009 | Sharp AR-BC320 All-In-One Led Printer
Ch 5 error code
ch5 error code, means that there is a
communication error (serial comunication) between the outdoor and the indoor unit.
Only for LG-airconditioners.
Jan 02, 2009 | LG Art Cool LA121HNP Split System Air...
UNABLE TO PRINT
press menu then start bk copy then fourtimes arrow-up button (tel.index) quick after another.
machine will be in maintenance mode and lights will flash.
press start bk copy in case machine wont directly display the error code.
Error starting with 4 means defective print head.
Error starting with 5 menas defective purge station or cycle problems.
both error series means: you need a new printer...
Feb 13, 2008 | Brother MFC-5840CN All-In-One InkJet...
Minolta CF2001 error code C3720
original glass cooling fan motor turning at abnormal timing
Jan 25, 2008 | Minolta CF2001 Copier
131 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
