Question about Belling 644 Electric Kitchen Range
Belling e297 just got my new electric cooker, but it has come with no cable, and how would i connect it to the electrics, there is a box on the wall ready for it?
You would need a 6mm twin and earth cable about 2 mtrs in length connections need to be made following the manufactures instructions. only attempt if you deem yourself competent. I guess if you need to ask the question perhaps you should get an electrician.
Posted on Apr 07, 2008
SOURCE:
Replacement user manual for Belling Format 645 cr double oven electric cooker
http://www.manualsonline.com/mdownloads/ff2c5d47-49a9-4d8c-9232-8033f1e3e147.pdf
Apr 13, 2014 | Belling XOU482 Electric Double Oven
Stove and oven not working
IF ELECTRICAL APPLIANCE
1. Check the fuse in your mains electric box, something may have triggered it to shut off, If off, switch on, if it doesn't stay on, you may have water/moisture in the electrtics (wait a few days, see if it has evaporated, try to switch on again).
2. Most electric ovens have a seperate fuse/switch in the kitchen normally at counter level, check to see switch is on, and fuse is working, sometimes indicated by a red light. You may need to change the fuse in the wall - MAKE SURE THE MAINS ELECTRIC IS TURNED OFF BEFORE DOING SO, BEST TO CONSULT A QUALIFIED ELECTRICIAN.
3. If using a smaller electric oven, i.e. a baby belling, it may come with a plug to connect to the mains, check the fuse.
4. Check for signs of damage in the cable leading to the mains, Best to turn the mains switch off for the cooker before doing so.
IF gas check you have a supply of gas running to the cooker, i.e. at the gas meter/pipe feed if on.
IF none of these work contact your gas / electic supplier for further advice, as dealing with mains electric / gas supplies can be very dangerous.
Feb 09, 2013 | Kitchen Ranges
I have a Belling 335 everything still works apart from the actual oven part? What could this be and is it fixable??
check your timer,if it has a programm set(by accident)the oven will not work until this has been cleared,if your not to sure then switch cooker off at the cookers main switch on the wall.leave for a few mins and switch back on this should clear any set programm,good luck.
Nov 13, 2012 | Belling 335 Electric Kitchen Range
Correct cable size for belling cooker fitting
If this is a fan assisted oven then a 2.5mm twin and earth is sufficient, but please consult the manual and let me know the wattage, or contact a qualified electrician.
Nov 25, 2009 | Belling 335 Electric Kitchen Range
Can I connect my Zanunussi zkc6040x cooker with 2.5mm T&E into my cooker outlet switch that is powered by 6mm and runs about 25`to the fuse box? Thanks.
No. It must be 6mm t&e cable from the wall socket to the cooker. To use anything else will rick getting an electric shock.
Sep 10, 2009 | Ovens
WIRING FOR AN ELECTRIC COOKER (I NEED A DIAGRAM) !!!
Trying to wire up an electric oven. Good with electrics, normally. Sounds stupid bus there are no holes to place the wires into on the oven panel. In other words not like the speces on a plug or on the main live circut on the wall. Where do I put the wires????
Sep 28, 2008 | Belling XOU174 Electric Single Oven
Oven not working properly
It may be the oven thermostat needs replacing.
Jan 29, 2007 | Belling 644 Electric Kitchen Range
Belling 644 Electric Kitchen Range Logo
169 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
John Tripp
John Tripp
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
