Question about Olympus Camedia Stylus 300 Digital Camera
Charging problem My Olympus LI-10B Battery Pack is not anymore charging with the Olympus Battery Charger LI-10C
The same problem I have.
Defective battery.
Posted on Jun 16, 2008
Is there any charger of the battery of vr-310?
You can buy the LI-41C battery charger from Olympus.
May 13, 2012 | Olympus VR310 Digital Camera
My Olympus charger for the LI 10B battery does not light and charge the battery. Can the charger be fixed or do I need to buy a new one? By the way, my camera is Olympus C5000. Thank you.
I would say that you need a new charger. Standard chargers that come with digital cameras will eventually deteriorate depending on how often you use it. However, it could also be a battery issue, as batteries eventually will die even if they are rechargeable. I would try the charger with a different battery and see if it works, and if not, then you will know that the problem is with the charger.
May 07, 2011 | Olympus Battery Li-10B Li-12B (D6102003)...
How to start since the power button does not react? How to charge battery?
Try recharging the battery. If that doesn't work, try a new battery.
Use the supplied charger to charge the battery. If you've lost the charger, you can get an LI-41C charger from Olympus. You can also get LI-40B or LI-42B batteries from them.
Jan 15, 2010 | Olympus FE-340 Digital Camera
Logitech MX1000 Laser Cordless Mouse, I replaced the li-ion battery with a NiMh AAA battery pack, soldered in the board that was on the old battery and used it for a week before the battery pack needed...
Li-Ion battery and NiMh battery have completely different charging requirements! Li-Ion battery has much stricter charging requirement and the regulator is normally design to trickle charge at 0.1 Current rating @ 4.2V and then completely shut down.
WARNING: if you use a Ni-Mh charger on a Li-Ion battery, then it will erupt and even explode and catch fire!
Bottom line is that the rescued Li-ion regulator is not designed for your Ni-Mh pack and you will never get a full charge with it and you will need a completely different regulator board: you are better off putting in a suitably sized Li-Ion battery with inbuilt regulator but with higher current rating if possible.
Hope it helps! Let me know how you go.
Nov 14, 2009 | Logitech MX1000 Laser Cordless...
Olympus battery charger flashes red when battery is inserted.
@gminvite1
"Another way I found was when this happens, to push the battery to the point the light will turn on, when it starts flashing slide it off then back on. Do this a few times so it charges a little, then you should be fine to leave it on."
I tried to do this with my LI-10C Olympus charger and it worked..The blinking red light turns to solid red..Thanks for the info...Now I won't be bothering to buy a new batt.or have my charger checked..
Nov 14, 2008 | Olympus FE-230 Digital Camera
Battery charger won't charge
I'm sorry to say I don't know much about Olympus digital cameras, I've never had one on the bench.
I would take your camera and charger to a shop that sells Olympus batteries try a different battery first, this way you can try it out before you buy and make sure the camera and charger are working ok...
The battery is a Li-Ion, when these get flattened too far they shut down and will refuse to charge, they can sometimes be recovered by using a power supply to lift them but you must be very careful (use a 300ma wall wart at just over the rated voltage of the battery for 10 mins then put it back in the charger) as they can catch fire if over charged, shorted or connected backwards also if its been so flat it refuses to charge its certainly past its best and should be replaced as its likely it will let you down again.
On the other hand it could be the charger, so best to try and check out both before buying anything.
If it happened very suddenly and the battery was still able to run the camera for quite a while I would think a charger problem is more likely, if the battery has been taking less time to charge recently and lasting shorter times its more likely the battery..
Having said that the protection circuits can shut down a seemingly good battery for other reasons.
If you find its the charger third party (non Olimpus) chargers are available quite cheaply on ebay as are batteries
Best of luck
Jun 14, 2008 | Cameras
Camcorder
The General Rule is: if it's the same manufacturer (which it is in this case) if the connector fits then it will work. Manufacturers generally tend to change connectors designs whenever they move on to a different charging "platform" (which includes voltage, current, polatiry and other caracteristics.
However to be absolutely sure, I would first verify that the voltage isn't too off between your old and new charger.
Feb 20, 2008 | Video Cameras
Is the battery that comes with the camera rechargeable?
Yes, the battery that comes with the C-7000 can be recharged. This battery is the Olympus LI-12B Lithium Ion battery and it can be recharged using the LI-10C battery charger. Both the battery and charger are included with the camera.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Type of battery
The Olympus LI-12B (supplied) or LI-10B lithium ion battery can be used with this camera. Do not use any other type of battery. The battery is not fully charged when the camera is purchased. Charge the battery using the supplied cradle before using the camera.
Sep 01, 2005 | Olympus i:robe IR-500 Digital Camera
Olympus Camedia Stylus 300 Digital Camera Logo
129 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
