Question about Ovens
Cooker power has gone.
While cooking a meal the cooker just lost all power. We have checked the fuse and the fuse in the cooker socket and they are all ok, Any ideas that aren't going to mean i need a new cooker!
It is a Zanussi built in oven model no. ZUQ875X
    Sergeant:
  • 236 Answers
Has it come back on? if not it may be a connection going into the back of the cooker or if it has come back on it may be an overheat stat kicking in -check the blower (cooling) fan is ok.
Posted on Mar 16, 2008
When i using my oven, suddenly off i don't know how to fix
If there are no lights showing or electric fan or heat
Check the cooker trip / fuse on the main Fuseboard.
Should be 32 amp rating.
If Light works / or / and Fan but no heat then likely to be Cooker element. If its a double element or oven with grill you may still have reduced capacity to heat / cook food.
May 25, 2016 | Ovens
Why is my oven cutting out
If your oven is cutting out and this goes for anyone else experiencing the same problem.
If this is happening WITH ONLY THE COOKER. then either you will need the item looking at for proper earthing OR you will need the wiring checked for the cooker along with the RCD to which the cooker is connected as these can SOMETIMES be faulty.
Does the same happen if something else is plugged into the same socket??? If so then the socket and the wiring to the fuse board/ distribution board / consumer unit must be faulty or the earthing
Dec 14, 2015 | Ovens
Turn on oven cleaning, but clean indicator stops after few seconds
hello
what this need is to set the reprograms
here are solution below
You can set the timer on a Corning ware slow cooker to automatically switch to a warming setting when you estimate Foods will finish Cooking The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the Work, and come home to a fully cooked meal.
  • Fill the insert of the Corning ware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • hope this hope ?
    thanks
    Oct 03, 2010 | Ovens
    Resetting the clock
    You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    Have a new electric cooker but the oven and 1 of the hob plates isn't working dc5422 beko
    hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
    Sep 17, 2010 | Ovens
    Pleace HELP!!! How do I set the clock on my Russell Hobbs RHM1712 microwave?
    You can set the timer on a range slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking. The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day.
    Set the timer on a range slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
    Fill the insert of the range slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
    thank and thanks for using fixya.
    Aug 20, 2010 | Ovens
    My zanussi cooker has just lost all power to it any help please
    Make sure there's power getting to your range, oven or cook-top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. I would also advise to inspect the junction point on the backside of the unit for a possible separation of the power cord as well. If all checks out Ok, control will be the culprit.
    Sep 15, 2009 | Ovens
    Can I connect my Zanunussi zkc6040x cooker with 2.5mm T&E into my cooker outlet switch that is powered by 6mm and runs about 25`to the fuse box? Thanks.
    No. It must be 6mm t&e cable from the wall socket to the cooker. To use anything else will rick getting an electric shock.
    Sep 10, 2009 | Ovens
    Fan but no heat
    This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
    Here are the 3 main faults to look for in your oven or cooker that is not heating
    1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
    2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
    If this helped like us on Facebook please
    Mar 14, 2009 | Smeg SE280X Stainless Steel Electric...
    Ovens Logo
    319 people viewed this question
    Top Ovens Experts
    Marvin
    Marvin
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
