Question about Sony PlayStation Portable (PSP) Console
Can't connect to the network
I have a sony PlayStationPortable and I tried to connect to the network but even if i'm close to the access point it says ''the connection cannot be established,try checking security settings'' but I checked every security setting it was alright but that message keeps on going if I connect to the network
  • badboy allan Mar 16, 2008
    hi i have 3.30 psp with wifi.can not connect to internet.keeps come up
    error.my server is orange.try vereus codes.nothing happening at all.
    my secrtie no not working can u heeeeeeeeeeeeeeeeeeeelp me
  • 31 Answers
Hi there check the firewall settings on the pc if they are too high you will not be allowed to connect
mike @ psp-repiars08
Posted on Mar 28, 2008
SOURCE:
Canot connect to 192.168.0.50 on a DAP-2695 wireless access point
It is extremely unclear from this what you are trying to achieve and what machine you are on. If the machine you are on is a desktop connected straight to the access point it may not have a wireless adaptor so you may see nothing like that in network connections. Cant comment on setting a static address without understanding why you are bothering with that and not just picking up a DHCP address from the router.
Jul 09, 2014 | D-Link AirPlus Xtreme G DWL-2000AP...
How can I connect my lg motion to other WiFi networks in the area? When I turn on WiFi network it says WiFi networks available most are password protected my mobile gives me options when I check the...
You need a password or a network key to piggy-back on someone else network. You can also contact your cellphone service provider and sign up for one of their data plan. This way you will have access to the Internet. Sorry if this answer is not even close to what you want.
May 04, 2014 | Computers & Internet
I have installed connectify on my windows 7 toshiba laptop. when i start it, the connection work well on my ipad for about 5 minutes and after it s get disconnected. each time i just close the wifi access...
1- I don't know what connectify is or even why you would use it. Your router can or should be able to handle wireless communications in your WiFi network. Once you have your wifi network setup under the router then go into settings on your ipad and point it to the right network and it should connect.
2- On your toshiba it should connect on it's own as well, get the wifi connection setup the go into network connection and point it to your wireless network in the house.
Like i said i don't know why or what this other program is or even for but see no good reason to even use it.
Hope this helps
Feb 21, 2014 | Computers & Internet
Mms/gprs settings.my network provider is smart
(How to get there? Open settings - Network - APN/Access point - New apn).
On internet settings try this first: Usually works but not always. Under are SMARTs own settings.
Connection name: Internet
Acces point name: Internet
NOTHING ELSE
Hope it helps.
I. GPRS/WAP Internet Settings
Connection name: SMARTGPRS
Data bearer: Packet data
Access point name: smart1
User name: leave this blank
Prompt password: No
Password: leave this blank
Authentication: Normal
Homepage: http://wap.smart.com.ph
Network type IPv4
Phone IP address: 10.102.61.46
Name servers: Automatic
Proxy server address: 10.102.61.46
Proxy port number: 8080 or 9201
(differs from one handset model to another)
Default access point: SMARTGPRS
Data bearer: Choose GPRS
Access point: internet
User name: (leave it blank)
Prompt p'word: No
Password: (leave it blank)
II. MMS Settings
Connection name : SMARTMMS
Data bearer:Packet data
Access point: mms
User name: leave it blank
Prompt password: No
Password: leave it blank
Homepage : http://10.102.61.238:8002
Network type IPv4
Access point: mms
Prompt p'word: No
Homepage: http://10.102.61.238:8002
Jun 08, 2011 | Sony Ericsson XPERIA X10 Cell Phone
How can i subscribed to packet data?
Packet data (EGPRS) Enhanced general packet radio service (EGPRS), packet data, is a network service ceive data over an Internet protocol which allows mobile phones to send and re (IP)-based network. It enables wireless access to data networks such as the Internet.77 . 2005 Nokia. All rights reserved © Copyright The applications that may use packet data are MMS, browsing sessions, Push to talk, e-mail, remote SyncML, Java application downloading, and the PC dial-up. Packet > Connectivity > Settings > Menu To define how to use the service, select Packet data connection > data . to set the packet data connection to be established when an When needed Select application needs it. The connection will be closed when the application is terminated. to set the phone to automatically connect to an packet data Always online Select network when it is switched on. indicates a packet data connection. Modem settings You can connect the phone using an IR or a data cable connection to a compatible PC, and use the phone as a modem to enable packet data connectivity from the PC. > Settings > Menu To define the settings for connections from the PC, select , activate Active access point > Packet data settings > Packet data > Connectivity Alias . Select Edit active access point the access point you want to use, and select , and enter a nick name for the currently selected access point. for access point , and enter the access point name (APN) to Packet data access point Select establish a connection to an EGPRS network. You can also set the dial-up service settings (access point name) on your PC using If you have set the 121 p. PC Suite the Nokia Modem Options software. See . settings both on the PC and on your phone, the PC settings are used.
Apr 14, 2011 | Nokia 6020 Cellular Phone
I have a sony vaio about four years old. I have had no problems connecting to unsecured wireless networks and software secured networks, but cannot connect to a router secured network even when I have the...
Try removing the preferred Network and try to scan and connect
ON Windows XP
Start --> Run -->ncpa.cpl -->Right Click on the Wireless Network connection Icon -->Click on Properties At the top click on Wireless network tab --> Remove Your Network name if you found there then Try to scan and connect again will work
Aug 05, 2010 | Sony VAIO (PCWA-A200)
Psp
The following items are generally required to set up to connect to a network.
  • A WLAN access point or a wireless broadband router
  • Settings for the access point (SSID, WEP key, WPA key, etc. as specified when the access point was configured)
  • A network device, such as an ADSL/DSL modem or a cable modem.
  • An account with an Internet service provider
Hints
  • An access point is a device used to connect wirelessly to a network.
  • A router is necessary if a PC and the PSP™ system will be connected to the Internet at the same time. A router is a device that enables multiple devices to be connected to one Internet line.
  • SSID, WEP and WPA keys are types of wireless network information. This information may be required when connecting to an access point or a router.
  • User is responsible for Internet service fees.
Example of a network configuration Network equipment connection and setup methods vary depending on the equipment used.
require001.gif Common settings hr1.gif You can create network settings for use in connecting to the Internet through an access point and save them on the PSP™ system. You can save up to 10 connections.
Setting methods may vary depending on usage conditions. The following is an example of commonly used settings.
1.
Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the PSP™ system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2.
Select in_networkset.gif (Network Settings) under in_setting.gif (Settings).
3.
Select [Infrastructure Mode].
4.
Select [New Connection].
5.
Select [Scan].
The system searches for nearby access points.
Depending on the model of PSP™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
standard001.jpg 6.
Select the access point that you want to use.
SSID is an identifier assigned to an access point. If you do not know the SSID or the SSID is not displayed, contact the person who set up or maintains the access point.
standard002.jpg 7.
Select the type of security that you will use.
The type of security settings required vary depending on the access point. For details on what type to use, contact the person who set up or maintains the access point.
standard003.jpg 8.
Enter the encryption key for the security settings.
The encryption key field displays eight asterisks no matter how many characters you enter as the key. For information on the encryption key, contact the person who set up or maintains the access point.
standard004.jpg 9.
Select [Easy].
Basic settings are set automatically.
standard005.jpg 10.
Enter a name for the connection.
You can choose any name for the connection.
11.
Check the list of settings.
standard006.jpg 12.
Save the settings.
13.
Test the connection.
If you select [Test Connection], the system will connect to the selected access point.
14.
Confirm the connection test results.
If the connection is successful, information about the network connection is displayed.
Hints
  • If the connection test fails, follow the on-screen instructions to check the settings. Network settings for the connection can be changed from the options menu. For additional information, refer to the instructions supplied with the network device and by your Internet service provider.
  • Depending on the access point settings, you may need to enter the system's MAC address to connect to the network. The system's MAC address can be checked under in_setting.gif (Settings) > in_pspset.gif (System Settings) > [System Information].
Jul 12, 2008 | Sony PlayStation Portable (PSP) Console
Trying to connect psp to wireless network
probably because the router/access point wasn't configured properly
Jun 26, 2008 | Sony PlayStation Portable (PSP) Console
Trednet Access Point keeps dropping Network connection
Trednets are know to do this if you have another wireless component close or next to the device. Do you have any 2.4ghz phones? Cell phones? Other wireless devices? If you have not tried yet, Try switching the channel on the access point. If its not a channel issue, try getting new firmware and test the signal strenth with a wireless sniffer such as Net Stumbler
Jun 14, 2007 | Trendware TEW-450APB (TEW450APB) 802.11b/g...
Sony PlayStation Portable (PSP) Console Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
