Question about Pentax ME Super 35mm SLR Camera
Film counter does not advance when film is wound forward!
How do I fix this? It almost makes it to zero in some circumstances! So I know it kinda moves.
  • 667 Answers
The frame counter is engaged when the film door is closed by a small tab at the top of the door near the hinge. Try pressing that area of the door as you advance the wind lever. You don't need film in the camera to do this. The counter with work without it. The door may be a little bent and not pressing the counter lever in far enough to fully engage the mechanism.
Posted on Mar 16, 2008
Asahi pentax sv film advance lever stuck
Without film in the camera it may well read before zero, my K1000, K1000Se, and K2 do that. Press the film rewind button, maybe that will release it for you.
For camera repairs look to:
Eric Hendrickson: http://www.pentaxs.com/index.html
Oct 02, 2012 | Pentax K1000 35mm SLR Camera
Nikon F3 film counter will not reset
You need to open the right side top cover to repair this. The "button" is not a reset - the counter is activated by the pressure of the film door on the "button" - it holds a shaft with a 'slice of pie' cutout on it against the gearing on the bottom of the counter disk. When you open the film door, the spring on the "button" moves it away from the counter disk, and a circular spring under the counter disk makes it return to '0'.
This problem is usually caused by impact to the top cover, causing the disk not to turn freely, or spillage, usually of a 'sugar' drink. It it is spillage, you can put some Windex on a clean toothbrush and clean around the advance lever and hope it gets far enough inside to dissolve the stickiness. If you have canned air you can spray a little around the advance lever to dry it out. Take out the batteries first, and leave them out for an hour or so to make sure the Windex has completely evaporated. Do not spray the Windex directly on the camera!
Jun 15, 2012 | Nikon F3 35mm Film Camera
Film-advance warning won't go away on a RB67 Pro SD 120 film back?
Mamiya RB67 Pro SD that is new to me. loaded the film correctly took the first shot. But, the film won't advance. What am I doing wrong?
Feb 18, 2012 | Mamiya RB67 Pro SD Medium Format Camera
How to load film
http://www.usa.canon.com/app/pdf/compact_film/Sure_Shot_Z135_manual.pdf
The link above will take you to a .PDF that is an owners manual for the Canon Sure Shot Z135
On page 14 it lists how to load film into the camera.
1. Slide the back cover downwards
2. Insert the film
- Make sure the film is positioned above the film guide
3. Pull the film tip across until it reaches the film tip marker
- Make sure the film is flat
4. Close the back cover
5. Turn the dial to (auto)
(Turn the power on)
the camera will automatically advance the film to the first frame.
6. "1" should be displayed on the frame counter
If this show zero there has been an issue, make sure you are using the proper film for the camera
Aug 24, 2011 | Canon Sure Shot Z135 35mm Point and Shoot...
I put the film in the camera and the knob wont turn when i advance the film. I don't know what to do.
If the knob on the left hand side of the top plate (as viewed from behind) does not rotate when you operate the film advance lever, then the film has not been loaded properly and has failed to engage onto the take up spool. It's a very common fault and even experienced photographers sometimes make the same error. The frame counter will advance every time the lever is wound on, it only counts the number of full lever actuations, not the actual amount of film which has been wound on. The rewind crank is the only reliable way of knowing that the film is actually advancing.
Open the back of the camera and re-thread the film leader onto the take up spool. Close the back and wind one frame with the lever, and then open the back again to check that you got it right. This may potentially waste one shot but it will reassure you that you got it right. Once you're familiar with your camera you won't have to do this any more as you'll be able to feel and hear when the film is loaded properly or not.
If this does not solve your problem then please add a comment and I'll offer further assistance. If I have solved your problem then please take a moment to rate my answer.
Mar 06, 2011 | Vivitar V3800N Zoom 35mm SLR Camera
When I turn the knob on the camera to be able to take another picture, the number still stays at zero. What's wrong with my camera?
There are a couple of possibilities that I can think of:
First, film must be loaded into the camera for the picture counter to increment.
Second, if you've loaded film, but the counter still does not change, it is possible the film is not advancing (the film release button/knob/lever that you use to rewind the film may be activated) or the film has slipped off the sprockets on the take-up spool.
If you can stand to lose the photos you may have already taken, just open the back of the camera and make sure the film is advancing when you take a photo.
If you can't possibly lose the photos, rewind the film and take the film to be developed. Try to find a local developer that only charges for the photos that "came out"... This can save a lot of money if only a few frames develop properly (or if none come out!)
Sep 01, 2010 | Pentax K1000 35mm SLR Camera
Minolta X-7A - the film advances, but the counter
The film counter moves without the film inside the camera.
You will need to replace the film counter assembly.
Jun 14, 2010 | Minolta X-370S 35mm SLR Camera
The frame counter is set on S, the film advance lever doesn't work anymore either. Is there anything I can do or should i take it to get fixed?
frame counter,mechanism is bad,before u get it fixed,try urself open the back door of the film chamber u will find a lever just below the number counter,move it freely ,push and leave, the put a dummy roll and move forward the film,if u get number counter working ok
Mar 05, 2010 | Vivitar V4000 50MM 35mm SLR Camera
Can't advance film, press shutter, no result
Do you have film in the camera? If so, is it an old film or you have just loaded it?
If it's an old film, could it be at the end of the roll - to check this, 'lightly' turn the rewind lever backwards and forwards. As the camera is pointing away from you, turning the rewind knob clockwise will normally rewind the film (don't press the rewind button in, we don't actually want to rewind the film yet), turning the knob clockwise should be tight and a firm stop, if the film is at the end, you will feel the same tight firm stop if you turn it counter-clockwise. Don't turn the rewind knob backwards (counter-clockwise) too hard, you'll unscrew it and it may fall apart. If turning it backwards rolls freely in a full circle, then you have film left.
Another option is that, since it's been so long since you used it, the loading of the film may have gone amis and sometimes the cassette will flip backwards, jamming the film in place so it wont advance - if you have loaded the film and not taken any pics or have not been able to advance it at all, it should be safe to open the back as the film will be in it's original loading position, if you have left the film in it from some time and don't know what stage it's up to it may be best to take it to a camera store where they will have a "Black Bag" to put the camera in and manually open and unload the film. Make sure you get an experienced person - some pimply-face teen that's never used a film camera can easily put their fingers through the shutter while it's in the black bag - I've seen it plenty of times.
OK, that's enough to get started, did this work or do we need to try more options?
**.The best way to acknowledge contribution is to rate it's relevance.**
Feb 03, 2009 | Canon EOS-AE-1 35mm SLR Camera
Help, my camera wont take pictures
Did you try pushing the shutter button? It may already be wound. Otherwise, try pushing the rewind button in and holding it while you wind the lever. Now, it MAY be that your at the end of the roll-what does your counter say?
Mar 31, 2007 | Nikon FM10 35mm SLR Camera
Pentax ME Super 35mm SLR Camera Logo
270 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
