SanDisk Sansa e260 MP3 Player Logo
Posted on Apr 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When dowloading music, my sansa fuze (Refurb)
When I dowload music onto my sansa fuze (Refurb), the display name of the artist and leaves off the first letter of the Artist and Title name. Is there something different I can do so that the complete name of the Artist and Title of the song show up on the fuze itself?
Joe Negus
Level 2:
President:
  • SanDisk Expert 652 Answers
  • Posted on Apr 07, 2010
Joe Negus
SanDisk Expert
Level 2:
President:
Answers
652
Questions
Helped
165769
Points
154
Save your music and format the sansa and reset
1: RESET: Go into the settings and scroll down to reset all, push center button, scroll to yes, push center this will restore factory settings.....
2: Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.
This is what it states in the manual for the 260 sansa Page 29
3: Recovery Mode also resets system settings when unplugged... lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode connect to comp when finished unplug
Why wont this sync with my itunes library?
Hi, Is the SanDisk Sansa Fuze compatible with iTunes? In some ways, it is. Unfortunately, the Sansa Fuze and iTunes don't always play nice together. You'll have to get a few workarounds to make these two sync together.
The SanDisk Sansa Fuze and iTunes
The SanDisk Sansa Fuze is natively a Windows product. You should be able to sync it with Windows Media Player automatically. However, not everyone owns a Windows PC and even if they do, they might store more music in their iTunes library.
If this is the case for you, you might find it helpful to be able to sync your Sansa Fuze with your iTunes music library. Bear in mind that you won't be able to sync apps, games or any other iTunes products that are not formatted for use on a Sansa Fuze.
Using iTunes with the Sansa Fuze
So, is the SanDisk Sansa Fuze compatible with iTunes? If you download the right software, it is. Apple offers a free download that works with many other non-iPod MP3 players, Sansa Fuze included.
Unfortunately, this product only runs on a Mac operating system. However, if you own a Mac, this is great news because it means you can still use your Fuze without buying a Windows PC.
If you use a Windows PC and want to transfer your iTunes music to the Fuze, don't lose hope - there's a way to do that, too.
Syncing the Sansa Fuze with iTunes
If you're using a Mac, visit this link for Apple's free software download. It comes directly from Apple, so you can be assured that it's spyware-free.
Install the software on your Mac. You need Mac OS X 10.4 or higher as well as iTunes version 8 or higher.
Plug your Sansa Fuze into the Mac and wait for the software to open. You should see a listing of your iTunes music library pop open in a window. You're then given the option to sync as many songs as possible onto your Fuze.
The syncing process is similar to syncing an iPod. Don't unplug the device until it's finished.
Syncing the iTunes Library in Windows
You can sync your Sansa Fuze with iTunes using a script called the Automator, found here. Once downloaded, open the script under your "Downloads" folder on your "C:" drive and find a string of characters that looks like this: "/Users/richard/Music/*.mp3".
Replace the name "Richard" with your own username. Don't change anything else. Select "File," "Save" from the menu.
Select the Automator icon with the right click button on your mouse and choose "Open with," "Automator Runner." If working properly, this should automatically sync the music from iTunes with your Sansa Fuze.
If that doesn't work, go into your iTunes library and highlight any DRM-protected tracks that you purchased from iTunes. Right-click and select "Make MP3 Version." These should now be compatible with the Automator.
This sounds like more or less of a "hack" than a solution, but this might be the only way to sync music from iTunes to your Fuze using Windows. If all else fails, make MP3 versions of the songs as shown above, then navigate to your iTunes folder where those files are stored. Then drag and drop these into Windows Media Player, where they should sync right onto your Fuze.
Hope that helps..
Can't load music onto my SanDisk Sanza Fuze Mp3 player
Itunes is what is known as proprietary software.
Which basically means that it only works with hardware of the same brand. (Apple- Ipod)
You will not be able Itunes to load mp3 files on a Sansa MP3 player.
Sansa Fuze not Regestering Songs
The device only likes mp3's. Most other files don't show up.
1helpful
Hi, Is it possible to download music from my ITUNES library onto my Sansa Clip+?
i thought only itunes worked for ipods
i would try using some other dowloading website just to save the hassle
good luck
1helpful
I don't know how to get music onto my Sansa Fuze.
There's a Sandisk support site for the Sansa Fuze, see:
http://kb.sandisk.com/app/answers/detail/a_id/3249/
Sansa Fuze user manual in pdf format:
http://mp3support.sandisk.com/sansa/UserManual/FUZE/fuze_userguide_en.pdf
Important
There are 2 ways the Fuze can be connected to a computer to transfer
music: MTP mode or MSC mode, read page 16 (=13) of the manual.
The player can be set to automatic detection of the connection mode
or can be set to either one of the available connections.
MTP mode is used for transfers using software like Sansa Media Manager or Windows Media Player 11.
MSC mode is used for transfers using the "drag and drop" method in the computer's explorer.
Need more help ? Just post a comment.
2helpful
2gb Sansa Fuze won't recognize 2gb Micro SD
place the blank card into the SanDisk player
go to SETTINGS press "enter"
go to SYSTEM SETTINGS press "enter
go to FORMAT press "enter"
it will ask "are you sure you want to format this device"?
select YES
dowload songs to REMOVABLE DISK drive F, at least that is what my PC assigned it to. You will overload your MP3 PLAYER if you continue to download to the Sanza Drive.
Hope this helps.
Mp3 is frozen after downloading a new song off of a website!!
let the battery die. hook it up via usb and reflash it using sansa firmware updater. it will erase everyting but at least it will start working again.
1helpful
2answers
Help in dowloading videos on sansa converter?
You could try another video converter like Wondershare Video Converter Platinum I always use, it could convert between all popular Video formats ( AVI, MKV, MP4, WMV, FLV, MPEG etc.) that support all popular portable media players (such as Zune/Zune HD, iPod/iPhone and PSP) and the latest iPod Nano 5G, iPod Touch 3, iPhone 3GS/OS 3.1.
Dowloading
plug it into your computer with the included usb cable, go into my computer and select sansa m230 and drag and drop music that you have on your computer onto the player. you can also sync your music if you use windows media player.
How do you dowload music on a sansa shaker chip
connect the sansa via usb to the computer and copy your music to the device once acknowleged by the computer.
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
