I have a 2002 rsx i have the same problem it works fine when i driving but when i stop blows hot air if i keep my foot on the gas
it will blow cold but when its on ilde its hot air i recharge it 3 times
at the shop and it still dos the same thing
SOURCE: 2003 acura rsx cough sputter
Regarding the heating issue, sounds like your thermostat is stuck open so the coolant isn't heating up. (May need replacement) Does your engine temp guage show it running colder than normal?
SOURCE: 02 acura rsx-s AC stopped
my 2002 rsx type s ac did the exact same thing. got to the point that i started hearing a weird noise like stuff clunking around everytime i turned it on. took it into the dealer and they said the compressor just fell apart inside... i had to buy a new one and it wasnt cheap to replace. problem was, the same equipment also played a part in the heating system too... so they told me.
SOURCE: My Acura RSX 2002 AC
If your vehicle had a condenser replaced and is now only blowing warm, chances are a cheap version of the OEM was installed. Demand an OEM replacement or you will never have cold air
If it is the original it is getting plugged up and needs to be replaced
