Question about Watches
Ta Heuer Professional stopwatch minute hand reser to 12 position
Hi, my watch was recently serviced and now the minute hand of the stopwatch doesn't reset to 12 but to 2 minutes to.....
I don't have the manual with me and various combinations of the crown setting and the stopwatch hands only move the seconds and 1/10 secoinds hands.
Can you help me to reset the minute hand to 12 please?
  • Anonymous Mar 28, 2014
    i have a adp1065 the second hand goes round but the hour and minute hand does not move
  • 4 Answers
Pull the crown on first click and push the upper button until it reaches to your desired position.
Posted on Mar 20, 2008
Tag heuer stopwatch
Pull out the middle dialer once then try if that's doesn't work pull it again one will be the chronograph the other will be the stopwatch and if you turn the middle dialer it will change your clock
Apr 27, 2013 | Watches
Hamilton jazzmaster watch
The large hand is the chronograph (stopwatch) hand and only moves with the stopwatch.
Mar 07, 2012 | Hamilton Laboratories Hamilton Jazzmaster...
My tag heuer carrera stop watch doesnt reset properly, when u reset the stopwatch it goes one minute behind and doesnt reset to zero. how do i fix this. it never resets to zero and the red hands on the sub...
Try this.
Pull the winder out fully. Then press the top right chronograph button to move the centre seconds hand on. Then push the winder back in.
on some models you should only pull the winder half way out.
good luck
Sep 23, 2010 | Tag Heuer Carrera Tachymetre CV2013.FC6206...
Tag Heuer CA 1211-RO Min. Hand resets to 59 Min.
Unscrew the crown and pull out halfway. Use the stopwatch buttons to advance the hand to where you want it. Then push the crown back in and screw it down. You may need to pull the crown out all the way--I cannot recall which setting controls the minute hand and which the hour hand on the stopwatch function. This has to be done every time the battery is changed.
Jan 23, 2009 | Tag Heuer Link Automatic Chronometer...
Tag Heuer Link, stopwatch seconds hand stops 2 seconds before 12
Pull crown out to position 2 [in between unscrewed (1) and pulled all the way out (3)].  Tap Button B (bottom) to reset by step back to zero.
Incidentally, Button A works Hours register in same manner for position 2.  You can similarly reset second and 1/10th with Buttons A and B, respectively, while in position 3.  Cheers!
Jul 25, 2008 | Tag Heuer Link Automatic Chronometer...
Tag Heuer Aquaracer reset red hand
THANK YOU THANK YOU THANK YOU!!! I had a similar issue and this saved me!!!!
Apr 14, 2008 | Tag Heuer Aquaracer Quartz Chronograph...
Aquaswiss trax watch
AQUASWISS TRAX MODEL:
For clarity:
There are three adjustment knobs on the right side of the watch. Two are smaller than the main time adjustment knob. For clarification I will label:
Top knob: #1
Middle knob: #2
Bottom knob: #3
To adjust the stopwatch feature:
1. Turn #2 counter-clockwise until it pops out to its adjusting position.
2. Pull #2 towards the right until you feel the first click. (There are two click positions).
3. Simultaneously hold both #1 and #3 down until you see the 1/16 hand and the 30 minute hand rotate automatically to a fixed position.
Now you are ready to calibrate the stopwatch feature.
4. Click mulitiple times on #3 and you will see the 30 min. had move clock wise incrementally with every click. Keep clicking on #3 until the 30 min. hand reaches its apex (to its 12:00 position).
5. Now click multiple times on #1 and you will see the 1/16th hand move in very small increments clockwise. You may be bold and try to hold down #1 and let it swing as close as possible to the 12:00 position and then multiple click #1 to get it precisely to its apex.
You are almost done.
6. Now simultaneously hold #1 and #3 until you see both the 1/16th second hand and the 30 minute hands auto-rotate clockwise to their respective 12:00 positions.
Fantastic! However, now you have to return the watch back to its original locked position. This is where it could get a little tricky.
7. Make sure the time is correct. Using #2 fully extended to its 2nd click position you may adjust the time.
8. Using #2 extended to its 1st click position you may adjust the date. (Here's the trick, do not set the date for today's date. Rather, set it for the day before or in some cases, 2 days before. I will explain in a moment).
9. Now, depress #2 fully back towards the main body of the watch as best as possible and while holding down #2 turn it clockwise until it locks into position.
During this operation you may notice that the date will go forward until the watch locks into position, ergo, I had to make sure the date was for the day before...and it some cases, 2 days before.
Your watch is ready to use.
The stopwatch feature for this analog watch works very similarly to that of an actual stopwatch.
Press and hold #1 once to stop the 1/16 hand. Press and hold #3 to have both the 1/16th second hand and the 30 minute hands return to their 12:00 positions. Now you are ready to race!
Press #1 to start the stopwatch. Press #1 to stop the stopwatch. Press #3 to return the hands back to their respective positions. You may even press #3 after you press #1 to get a second reading but I will let you figure that out for yourself.
Hope this was helpful!
vsndesigns
http://www.rgmarchitect.com
Dec 20, 2007 | Tag Heuer Kirium (CL1212.BA0705)...
Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Oct 18, 2007 | Tag Heuer Aquaracer Quartz Chronograph...
Watches Logo
1,179 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
