Question about HP Pavilion ze2000 Notebook
About laptop ethernet...
Laptop work fine and well without cable on in ethernet ...as soon as i keep cable in socket of ethernet screen apear blue and say memory dump and keep on doing that / i mean keep on restarting and blue screen.....without any thing i have to do....is to take off cable ..then it again start working properly...pls assist me
  • Anonymous Jun 27, 2008
    I have the same problem, but my HP laptop is model Compaq 6910p
  • 655 Answers
First figure out whether your hardware is ok and driver is installed properly. In Windows XP, click Start , right-click My Computer , and select Properties .
  1. In Windows 98 and Me, right-click My Computer , and select Properties .
  2. In Windows XP, click the Hardware tab, and then the Device Manager button. In Windows 98 and Me, click the Device Manager tab.
  3. If the Network adapters category is present with a (+) sign , then skip to Step 6. If Network Adapters has a (-) sign , continue to Step 5. Disregard adapters that do not reference an Ethernet Adapter .
  4. If a network adapter is not listed inside, do one of the following items based on the condition of the networking hardware:
    • Networking hardware is not installed. Install a new network card (desktop computer) or a new network PCMCIA card (notebook computer) per the card manufacturers' suggestions. This does not apply to on-board networking hardware.
    • The network card is not seated fully into its socket. For Desktops, remove the side-case, reseat the network card, and replace side case. For notebook computers, remove and reseat the network PCMCIA card. This does not apply to on-board networking hardware.
    • If the computer is older, it may need to have jumpers on the network card set to an IRQ and address range that is not already being used by another device. Remove the side-case, set the jumpers on the card, and replace the side case. Replacing the older network card with a newer Plug and Play network card is probably a better option.
    • For desktop PCs with on-board networking hardware, reset the BIOS:
      1. Restart the PC.
      2. Press F1 repeatedly when the first screens appear.
      3. Press F5 and Enter to reset the BIOS to default settings.
      4. Press F10 and Enter to save the settings and exit BIOS setup .
      5. Restart the PC.
      6. Check Device Manager again for the presence of the Networks adapters category. If the network adapter name is still missing, the on-board network adapter may be damaged. The motherboard should be replaced, or a PCI network adapter should be installed.
  5. If the network adapter is listed, but has a yellow exclamation mark over its icon about laptop ethernet... - c00060708.jpg , do one of the following:
    • Software drivers and supportive files may be missing or corrupted. Remove the device from Device Manager and reinstall the software by restarting the computer. See Step 5: Reinstalling network adapter software drivers .
    • If the computer is older, it may need to have jumpers on the network card set to an IRQ and address range that is not already being used by another device. Remove the side-case, set the jumpers on the card, and replace the side case. Replacing the older network card with a newer Plug and Play card is probably a better option.
  6. If the network adapter listed has a green adapter icon c00060709.jpg , the networking adapter is probably functioning correctly. If the PC still cannot connect to the Internet, make sure to complete the following steps before continuing:
    • The cable or DSL hardware may have stopped responding. Reset the cable or DSL hardware using the manufacturer suggestions.
    • There still may be a connection problem. Recheck the cable connections and replace any cables that have been pinched or that you suspect are bad.
    • The Internet Service may be down at your provider. Most Service Providers have a telephone support number. Call the ISP support number. If an outage is occurring, an automated response about system wide service outages will probably play. In this case wait until the service comes back.
    If the network adapter icon is listed without problems, and the connections, service, and modem are working properly, then refresh the networking drivers.
Thanks
Iqbal
Posted on Mar 16, 2008
SOURCE:
My m8 TV box continually says it cant connect to server despite having Ethernet cable attached what am I doing wrong?
Hi
yes it is the Ethernet cable. I find them rather troublesome. Look our for that they are completely in the socket and you can't move them. What I usually do next is that I change the cable , the one end goes into the other socket. I hope you get my meaning.
enjoy your coffee
Feb 02, 2015 | Televison & Video
My wireless adapter cannot see any wireless networks in range
you have a problem with the range or apear one indicator network work of ? if is the first maybe the ip adrees is corrupt in you mac conections or if not apear any your airport mac adaptor is work out change it vote plase
Mar 05, 2012 | Dell XPS M1210 Notebook
I am wanting to run my (currently wired) laptop to be wireless (have bought a USB adaptor to do this), but also keep my main PC wired. I clearly need the internet on my PC to set up my DLink G ADSL2+. I...
You will need a wireless router with a built in switch. Most of them these days will have a built in switch. Here is a picture detailing what I am talking about.
You're internet connection goes into the ADSL port. Now, it will be broadcast WIRELESSLY through the antenna to your laptop. With this example, you could connect 4 more WIRED computers through the LAN ports. The built in switch is the division of the connection into the separate LAN ports.
I trust that this will help you greatly and look forward to your response!
Feb 26, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Connecting to virgin cable modem
Hey, connect a network (straight through cable) from the blue socket on the modem to the WAN socket on your router (This socket will be split away from the other 4 on the router), then turn on your router 1st then modem.
Good Luck.
Nov 13, 2009 | Computers & Internet
Blue screen
your hard-drive is probably failing
Aug 19, 2008 | Acer Aspire 5100-5022 Notebook
My router will not connect to the internet
The laptop may not have the correct wireless settings same as the router.
What is the Operating system of your laptop and does it have a builtin card?
May 21, 2008 | NetGear WGR614 Wireless Router
Cant go wireless
I think the problem is not your laptop configuration. Can you check the setup configuration of the router it's maybe the wireless function is disable. Or try to reset the router to his default configuration. Press the reset bottom of the router for 15 second then try to connect your wireless connection if still not working setup again the router configuration.
thanks
Apr 15, 2008 | Belkin (F5D5231-4) Router
Laptop Problem
If you are still in warranty, or even not, HP support is very helpful, moreso than most. If you have no computer access, call:
800-HP invent
or
800-474-6836 24 hours a day, 7 days a week for most products
Mar 01, 2008 | HP Pavilion ze2000 Notebook
HP Pavilion ze2000 Notebook Logo
1,038 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
