I need help puting it together
I AM TRYING TO FIND OUT WHAR TO HOOK UP MY POWER SW AND MY H.D.D.LED AND MY -PLED AND +LED
    Sergeant:
    Champion:
  • 293 Answers
If you are using the generic or compatible casing it is written in the connectors of the casing (power sw, reset sw, h.d.d led etc.) and in the motherboard you can see also the markings or labels. it depends on the motherboard brand and design just follow the manual.
Posted on Mar 16, 2008
Msi ms 7297 ver.2.1 front panel help
With the motherboard in the case and the back of the case away from you the front panel pins are on the front left of the motherboard. They will have simple labels;
PWR power
RST reset
HLED hard dive LED
PLED power LED
You can get it wrong without breaking it so just keep trying until the right buttons and lights work.
Jan 06, 2013 | Intel Motherboard
Where do I plug in the power sw and power led wire on the eMachines T5274 computer? Thanks
When looking at the motherboard with the back of the computer to your left, there should be a row of pins on the lower right corner of the motheboard (or close to the corner). These pins are normally marked as something like PLED (for the power LED), PWR SW for power switch, RST for reset, IDE LED for the hard drive light, etc.
The power switch is normally along the bottom row and the power LED is on the top. But--to find where the power switch goes, take a small screwdriver and short two of the pins to see if the computer turns on. If it does, you've found the power switch. When the computer is running, put the power LED plug across two pins to see if the power light lights. If it doesn't, try two more until you find it.
var fctb_tool=null; function FCTB_Init_88a0199091e74aa0ab8dd27b901b03c6(t) { fctb_tool=t; start(fctb_tool); }
Nov 13, 2010 | eMachines T5274 Desktop PC
How to connect jfp 1
go to www.msi.com.tw for MSI guide , it should show you your motherboards front panel intel connection guide , it should be like this
PSWITCH PLED Open
RESET HDD SPK
Jun 08, 2010 | MSI G31M3-L V2 Motherboard
TRYING TO HOOK UP MU POWER BUTTON NEED TO KNOW
Hi there
The front panel connectors are mainly,
  • harddisk activity connector
  • power switch connector
  • reset switch connector
  • power LED connector
  • speakers connector
  • USB connector
Harddisk activity connector
This normally comes red in colour and is labeled as HDD-LED
Power switch connector
This comes green in colour and is labeled as POWER-SW
Reset switch connector
This usually comes grey in colour and is labeled as RST-SW
Power LED connector
This is usually green in colour and is labled as PWR-LED
Speakers connector
This speaker will give different beep sounds during boot to tell the user if there is any errors. It occupies 4 pins, however only 2 is important for the function. Be sure to connect the red coloured cable to the positive polarity and the black to the negative.
front_panel_connectors.jpg Front panel connectors pins on the motherboard
front_panel.jpg Front panel connectors from the casing
Good luck and thanks for using FixYa!!
May 13, 2009 | eMachines T6420 PC Desktop
Case wire two mother board
Here is your front Audio guide:
http://www.fixya.com/uploads/images/3C3CD07.jpg
Here is your USB guide:
http://www.marnscda.com/Guide/USBPinMB.jpg
And here is your front Panel guide:
http://www.elhvb.com/mboards/intel/pinout-OEM-Intel-2x9pin.jpg
Let me know how that works out. The front panel guide is rotated 180 degrees however.
May 02, 2009 | Foxconn 661FX7MF-S Motherboard
I have a Northdate computer and every time I push the front button to turn it on it would shut right back down. I opened the side panel and took out the power supply box and replaced it. Still doing it...
ok find the pin on the mother board of your pc you will see a 9 pin like this ( ::::. ) or in reverse order just put the pw sw. in pw mark you can see that just read it
Jul 21, 2008 | Northgate Computers & Internet
Pwer led,resetsw,hdd led,pwer sw
It appears your board is made by Jetway.
Heres your link for the manual:-
http://www.jetway.com.tw/jw/downloadshow.asp?productid=V266B#
You can also download drivers et,c. from the same site.
Please don,t forget to rate the Post.
Best wishes mike @Compurepair
Mar 29, 2008 | Intel Motherboard
Need help bigtime
are those all seperate connectors for the button? Or are they all together on one block? Should be something near bottom right hand corner of mobo saying pwr, hdd, sw, snd, led, that kind of thing
Mar 24, 2008 | E-Machines eMachines Desktop PC
Icute to motherboard wiring
Hi, on the edge of your mother board closest to the front of the computer, you will find a double row of pins. Use a torch and if needed a magnifying glass and study these, you will find they are labeled the same as your cables from the case.
In some cases the plugs are set as a 3 space plug, if you find one of these that wont fit. just split it. If you plug the LED wire back to front, don't panic it won't hurt they just wont work. The power and reset are not pole sensetive.
Goodluck mistyman
Dec 23, 2007 | Computers & Internet
What motherboard? State your question in a more complete manner, not like a kid in kindergarten
Nov 24, 2007 | Computers & Internet
Computers & Internet Logo
384 people viewed this question
David Payne
David Payne
