Question about Toshiba Satellite P105-S6104 Notebook
Toshiba audio failure
Toshiba Satellite
Problem: complete loss of audio including via mic input. crackling sound produced at times.
  • birgit Mar 16, 2008
    whats the going rate for a 3.5mm stereo jack plus labour?
    Scholar:
  • 105 Answers
Check for any hardware conflicts. If there are none then the 3.5mm stereo jack for audio out may be damaged - it has internal switches to turn off the speakers when headphones are used.
Posted on Mar 16, 2008
SOURCE:
Toshiba Satellite C655 crackling audio
hello . fixya appreciate to get some helpe here ... i got a lap of toshiba the model is satellite c655 . and recently i surprised that the speakers export crakcling sound .. . but as i remind that wasn't occur until i restore my lap of the origin windows 7 virsion ...in while i try to fix the problem i changed the sound driver lots but did'nt make make any sense ... how could i fix that problem and thanks for effort .
Nov 11, 2012 | Toshiba Satellite C655-S5212 Laptop /...
Does this type has been completed by microphone from the manufacturer?
Did you mean if Toshiba Satellite A205-S4617 integrated Microphone? If so, then the answer is no, the Laptop is not included or integrated with any microphone on it (not built on microphone).
you can read the detail and product spec here:
http://www4.dealtime.com/xPO-Toshiba-Satellite-A205-S4617
but you can still use microphone as an audio input, by purchasing external microphone.
Hope it help
regards
Apr 17, 2010 | Toshiba Satellite A205-S4617 Notebook
Cannot record sound
Normally every Lap is coming wit internal mic; so
1- Simply check your mic is mute or not
2 - Check your mic volume
3 - Use sound recorder that comings with windows (just record & play)
4 - Use an external MIC (known as working) with sound recorder
5 - Check in control panel->sound and audio device --> default recording device and Voice recoding device as your system’s built-in audio device (some times it’s changing when we installing b-tooth deice)
6 - Check device manager --> under sound audio controller for any issues
7 – Uninstall & install completely your Audio Device driver with default settings.
** If you didn’t solve your prob; my advice is take your lap to a good technician with component level Repair skills.
Thank you & Best Regards
Dinu..
Dec 20, 2008 | Toshiba Satellite A215-S4697 Notebook PC
There is a crackling sound after I record.
The problem was the VIA chipset firewire card. I changed it with a Texas Instruments one. Works perfectly now.
Sep 04, 2008 | M-Audio Solo Audio External Sound System
Audio Inputs suddenly producing buzz/broken
The UA 25 needs a GOOD quality USB cable, the thicker the better. Cable loss means that by the time the 5V power supply from the computer reaches your Edirol, the voltage has dropped to about 4V, which then has to be boosted back up to 5 Volts and inverted to -5V.
Cheap cables will hamper performance or prevent it working at all ( I lost 2 hours once with this problme ) . Also avoid using the FRONT USB connectors on PCs, use the connectors that plug direct into the MOBO on the rear of the chasis.
Good luck
Dec 22, 2007 | Edirol UA-25 External Sound System
Open Questions:
See all Toshiba Satellite P105-S6104 Notebook Questions
Toshiba Satellite P105-S6104 Notebook Logo
188 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
