Question about IBM ThinkPad 600X Notebook
Cannot get backslash (\) character to display
When I hit the backslash key I get #.
Have tried various key combinations.
Have also tried hitting # instead but still no luck.
Need it to enter into command prompt.
Help please, thanks.
  • 1 more comment
  • Chaswey Mar 16, 2008
    Have changed regional settings to English (UK) but still no luck.
    Do I need to select something different under Keyboards i.e. number of keys etc.?
    No, the keyboard is not UK (physical) layout.
    It has # above 3, @ above 2, " above ' etc.
    The IBM laptop has the \ key on the right above Enter. On the key above \ is something that looks like a colon.
    Changed it to UK in settings and now get £ above 3, @ above ' etc.
    It now gets weirder.
    When I tried the \ the # symbol still came up.
    Fiddled around with key combinations and hey presto it suddenly gave me the \.
    Great, opened DOS prompt, went to enter \ and got #.
    So, some sort of key combination DOES work.
    Kicking myself now because I didn't make a note of each one after I tried it.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    well..maybe it's an IBM innovation(NOT)..sounds like you have a bad keyborad of motherboard, eh?
  • 3 Answers
To get a backslash, you need to print the upper ascii character 92 (decimal). On most machines you can get upper ascii characters by holding down the Alt key and typing the decimal value on the numeric keypad. On the little IBM machine I'm typing this on, there is no numeric keypad, but if I switch on numlock (by doing shift-scroll-lock) the j-k-l keys become 1-2-3 etc. Now id I hold down Alt and type 92 (i.e.keys 9-k), this is what I get: \ Howzzat?.
Posted on Jul 26, 2009
  • grateful2 Dec 12, 2010
    I'm not very pc or lap top techy yet these instructions by dontango work perfectly. Hurray I can now get my backslash! Yeah!!! Thank you so much ! This question and answer facilty really works!
    Scholar:
  • 105 Answers
Is the keyboard UK [with a £ symbol over the three]? or US with a $ symbol over the three? Set your regional settings for the appropriate keyboard, open control panel - regional and language options - select the languages tab then on details. Check in the list of installed services that it has the correct keyboard language [if not add it] and remove any incorrect keyboard languages. Be sure to click on apply and ok and then close the window. A reboot may be necessary to ensure the correct keyboard type is in operation.
Posted on Mar 16, 2008
I have us gateway laptop using in uk on english settings backslash key shows#
Posted on Feb 27, 2010
Backslash key hit instead of cap
the keyboards are set up on international standards and it is not usual to be able to configure a separate key for some other symbol
what is the keyboard type you are using?
May 23, 2012 | Apevia Computers & Internet
Our pound sign has disappeared and other characters have swopped position. We have bought a new keyboard but the problem is still there. Can you help please and is your help free?
Hmmm let's try this and if it doesn't work, we'll try something else.
It's possible that you have hit the Num Lock key while you had another key pressed. Try the following combinations, one at a time, to see if any of them work. Be sure to test each one before moving on to the next one.
CTRL and NUM LK
Shift and NUM LK
ALT and NUM LK
A lot of times characters will swap places if one of these combinations has been pressed, and pressing the combination again should switch it back. Let me know how it goes!
Aug 26, 2011 | Compaq Keyboard
How do I get the question mark and backslash instead of green characters
The Question Mark and Backslashes are typed while holding the SHIFT key,
the "Green" characters sound like your FUNCTION keys.
If you're NOT holding down the FUNCTION key or the FN key you may have some kind of Function Lock enabled. (Look for a Fn Lock of F Lock button/light)
Jun 11, 2011 | Acer Aspire 5610-4648 Notebook
Occasionally a user reports that characters being typed do not appear on screen. Smarterm v12.1 configured as Digital VT session. Reboot of workstation fixes problem. Is there some sequence of keys user...
If "echo" is running, the terminal echoes what is being sent to the server. However, if "backslash" mode is enabled ("echo -e"), then the command "\c" tells echo "produce no further output." Try "\c" to see if that will toggle the command. If not, try "\C" or "\e" (escape). "echo -E" turns off the backslash mode entirely.
Nov 14, 2017 | Esker SmarTerm Essential VT
I cannot get backslash on logiboard keyboard
1) With your NUMLOCK on, hold the ALT key down and type 092 on your numeric keypad.  When you have NUMLOCK on, ALT and a 3-figure digit gives you special characters.  092 is the backslash on UK and Spanish keyboards, so hopefully it'll work for you.  If you get something different, you'll have to try different numbers until you find it
or
2) In Start --> Programs --> Accessories there's a program called Character Map.  This gives you a list of available characters
or
3) copy and paste this one:  \
Apr 21, 2010 | Logitech Wireless Access Duo Optical...
How do I find the standard deviation?
Here is a detailed exemple. Hope it helps.
Some comments on the various variables (should the information be needed. If not need, please skip it.)
1.All you have to do is follow the instructions key stroke for key stoke, but enter your own data.
2. If a number is repeated 3 times like the number 55, you can enter it 3 times or use the shortcut in the exemple
55 [2nd][FREQ]3 [Sigma+].
3.If you make a mistake and enter the wrong number, use the [Sigma-] key to remove it. That is similar to what a cashier does when an item is entered twice: it is entered a third time but with minus sign.
4. Every time an item is entered, the display shows the total number of items so far. When it is finished the cashier press the key that sums up the prices to get the total. This is the role of the [2nd][Sigma X] key combination.
5. The average number of the data is obtained by the [2nd][x bar] combination. The last two key combinations display the two type of deviations.
Check the theory you have been taught and try again. If that is not the type of statistics you were supposed to do, then give more information.
Oct 28, 2009 | Texas Instruments TI-30XA Calculator
Screen only displaying keys that are on blue on keyboard
sir if u wants to type the special characters then press the shift key before pressing that button.
Apr 23, 2009 | Dell 0Y3740 Keyboard
Gateway Keyboard left shift key adds a pipe character
The driver will not fix the problem, as this is a mechanical problem. I had the same problem and was able to fix it. Instructions with pictures can be found at: http://lotus.kick-***.net/keyboard
Here are the instructions without the pictures:
I had a problem with my Gateway keyboard where whenver I pressed the left shift key, it type a pipe | (verticle line) character. This is the same character that is above the back slash character . I searched the internet and people were suggesting reloading drivers and apparently Gateway was suggesting a destructive reload of the hard drive. That's absolutely rediculous.
After some research, I determined that on some European style keyboards, the backslash/pipe key is between the left shift and the "Z" key. So, I removed the left shift key to experiment. The key simply pops off by sticking a screwdriver under it. (It is not necessary for you to do this).
When I used a little screwdriver to press on the center of the plastic (red arrow) I would get a proper shift key. However, when I pressed to the right (green arrow), I would get the backslash character. If I pushed at the red and green arrow together, I would get the pipe character.
Ah-hah! I determined the problem. The inside of the keyboard is a "universal" type and can be used with U.S. or Europeon keyboard layouts. For whatever reason, the left shift key was hitting both dots under the key. (The dots are visible in the pictures below.)
To resolve the problem, it is necessary to disassemble the keyboard. On the bottom of the keyboard is a bunch of screws. Remove all of the screws. If you have any rubber feet, there is probably screws under the rubber feet. The feet are just held on by sticky taope, so they peel right off.
Once all of the screws are removed the top and bottom halves seperate easily. The circuits stay in the bottom half of the keyboard, so set the top half of the keyboard to the side. The red arrow marks where the left shift key presses down.
Pull back the top layer and you will see the flexible circuits. These are also made up of multiple layers. When a key is pressed it pushes these layers together to complete the switch circuit. The red arrow marks the shift key. The green arrow marks the backslahs/pipe key for European style keyboards. The blue arrow is yet another key that is not used on U.S. keyboards.
Pull back the first layer of the switch circuit to expose the space between the circuit layers.
Place a small piece of electrical tape on the extra backslash/pipe circuit connection as marked by the red arrow.
Now simply reassemble the keyboard and that weird pipe character will never accidentally show up again.
Mar 08, 2008 | Gateway 2520915 Keyboard
IBM ThinkPad 600X Notebook Logo
13,365 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
