SECTION 501-01: Body System — Interior
2004 F-150 Workshop Manual
REMOVAL AND INSTALLATION
Procedure revision date: 02/17/2004
Front Door Trim Panel Printable View (229 KB)
Removal and Installation
NOTE: LH side is shown. RH side is similar.
Item
Part Number
Description
224A60
Cover plate
N602704-S301
Screws (2 req'd)
14B132A (RH) / 14B133B (LH)
Window control switch
14630 (RH) / 14631 (LH)
Window control switch electrical connectors
5
W505424-S301
Bolt
6
W701930-S424
Bolts (2 req'd)
7
19A034
Water shield
8
W709132-S300 (High series trim) / W709133-S300 (Low series trim)
Speaker standoff (2 req'd)
9
219A65 (LH)/ 219A64 (RH)
Front door handle
Removal Note
10
23942 (RH) / 23943 (LH)
Front door trim panel
Removal Note
Item 9: Front Door Handle Removal Note
Item 10: Front Door Trim Panel Removal Note
CAUTION: Do not pull directly outward on the front door trim panel, as damage may occur.
Another place you get directions with pictures is Muth.
They are a mfgr of signal mirrors, and usually have good directions.
www.kwmuth.com
Enter your truck info ( make model MY ) and on the products page are the install directions in PDF format.
Obviously use the directions to the point of removing the door panel, no need to remove the mirror head for what you need.
SOURCE: Remove F150 door panel
They Are NO Fun thats for Sure There is a TOOL For the SNAP-ON Plugs on sides and Bottom, But the Top From Handle Up, there are A number of hidden HIDDEN Screws, at times with Interior Matching PLUG COVERS that Must be REMOVED to Gain Access to the Screws. It is TEEDIOUS and Nerv Racking to Remove Them But Just Have A GOOD EYE For the Fasteners and You Will Do Fine with it.
