Slow typping when I go to type I have to hold the key down for about 3 or 4 seconds then the type will show up. How may I fix that I have all my recovery disk if that would help it but what would I have to do to load them and not lose what I have?
  • 50 Answers
Recovery disks will tyically either remove everything on your system or at least prevent all the programs you have installed from working until you reinstall them. Do you have any virus or spyware protection? Your system could be overreun with malware (bad software) that is taking up all the processing power. You should probably run HijackThis to do an analysis and report back what you find. At the very least, you should be running Spybot Search & Destroy for anti-spyware and AVG for anti-virus (both are free) or other such software. Beware, however, of products that appear in pop up windows as those are usually malware that is created to get you to buy software from the same people who wrote the malware - in other words, they write software to infect your machine just so you'll buy their software to uninfect it..
Posted on Mar 16, 2008
6ya staff
SOURCE:
Costumer support
Data will be lost so first press the back up option and take a back up into sd card
Note: the different types of methods are numbered, method 1, method 2, method 3, etc.
1. When the phone is powered off, press and hold the Volume Up and the Volume Down keys both at the same time, then press and hold the Power key until a test screen that shows some available options appears, usually takes about 15-20 seconds. When that screen pops up you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights FACTORY RESET then press the Power key to select it.
2. Power the phone off all the way, press and hold the Volume Down key and press than release the Power key, still holding the volume down key for about 10-15 seconds. When you see some additional options pop up on the screen you can let go of the keys.
Press the Volume Down key to navigate down through the options until it highlights the reset option; it usually says FACTORY RESET, then press the Power key to make the selection.
3. While powered off, press and hold the Home key, while continuing to hold the home key power the device on by pressing the Power key.
Once the Android Recovery screen appears release the Home key, then while on the Android Recovery screen, press the Volume Up and Volume Down keys both at the same time.
If/when you're on the Android System Recovery screen release all the keys, and then use theVolume down key to navigate down to the "wipe date/factory reset" option. Once it's highlighted press the Power key to select it.
Once you see the "Confirm wipe of all user data?" Press the Volume down key to highlight "Yes-delete all user data", then press the Power key to select it.
4. Power the device off, then press and hold the Home key and press and release the Power key (while still holding the Home key).
From the Android Recovery screen, press the Search key.
Tap to select wipe data/factory reset then select Ok (located in the lower left of the screen). Note: if screen is not responsive use the Volume keys to scroll and the Camera key to select.
Select Yes - delete all user data, and then select OK (again lower left).
Select "reboot system now" and press OK.
5. This is becoming a common hard reset method and can be used to factory reset Samsung's more recent Galaxy smartphones such as the Samsung Galaxy S III, the Samsung Galaxy S4, the S5, the Samsung Galaxy Note the Note II and Note 3, etc.
With the device powered off press and hold the Volume Up key the Home key and the Power key all at the same time.
When the phone vibrates (or you see the GALAXY Logo) release the Power key but continue to hold the Volume Up and Home key.
Continue holding the Volume up and Home key until the "Android system recovery" screen appears.
Use the Volume buttons to scroll to and highlight the "wipe data/factory reset" option, and then use the Power key to make the selection.
Once the factory reset is finished you may use the Volume and Power keys to highlight and select the "Reboot system now" option and the hard reset will be complete and your cell phone will be nice and squeaky clean.
May 21, 2014 | Visual Land Connect 9" Android Tablet...
Hi i have a kenwood hdv 910 car sterio and i do not have the code key cod for it.
you can send your stereo back to Kenwood to have the security code reset.
Oct 19, 2008 | Kenwood Car Audio & Video
Hi, can you pls help me with the procedure to lock and unlock the keyboard of mini HP110 notebook?
Improve the Fixya experience for everyone by voting.
Holding down shift key for more than 8 seconds will lock the keyboard and it will stop responding. But if you keep pressing keys for few seconds you would be able to type in but it will be very slow. Plus, it will produce a nasty sound.
To get around this, go to start and then settings, then control panel and then finally accessibility options. Make sure all the 3 boxes are unchecked.
May 10, 2012 | HP Mini 1000 Netbook
My acer 6516 laptop keyboard is locked, and I cannot get it to unlock.
Jan 14, 2011 | Acer 91.63X07.001 Keyboard
I need to change my linksys routher password how to change?
Hi Friend,
If you want to change the password for router login page then please follw the steps:
1. Click Start \ Run\ type cmd and hit enter
2. In the black window typ the command ipconfig and hit enter.
3. Note down the default gateway and close this window.
4. Open the web browser and type the default gateway and hit enter.
6. The default password is admin and leave the username blank.
7. In the router setup page click Administration
8. In the left pane you will see Router password. Type the new password and re-type it. Then click save settings and turn the oruter off for 30 seconds and then try to login with this new password.
If you want to apply security on your router, so that no one can use your network, then please follow the steps:
1. Open the web browser and type the default gateway and enter the password.
2. Click Wireless and then Wireless Security.
3. Select WPA Personal from the drop down of Security mode.
4.WPA Algorithm should be TKIP
5.Type any ten digit number as the Shared key and note it down and click save settings.
Turn the router off and switch it on. Now whenever you try to connect your wireless devices use the shared key as the security key.
I hope this will resolve the issue.
Regards
Chiranjeet
Dec 14, 2010 | Linksys WRT54G2 Wireless Router
How to unlock keybrd of sony vaio
Nov 15, 2009 | Toshiba G83C0001K210 Keyboard
How do i unlock keyboard on a laptop
Nov 10, 2009 | HP Compaq nx6125 Notebook
How do I use lower case letters in a text?
If your Tracfone has an uparrow on the zero (0) key, after entering a character, IMMEDIATELY hit the 0 key.  The phone will change the case of the previously entered character AND change case for subsequent entries.
If you're too slow typing the 0 key, you'll get the characters assigned (0, +, etc.) to that key.
Mar 11, 2009 | Motorola Mobility TracFone® V170 Cellular...
I have to hold down keys for 2-3 seconds to type. How to correct?
It might be due to a service called "ATI Hotkey Poller" running
which is intermittently slowing the keyboard typing down.
To disable it in Windows XP Home:-
Go to Start->>Run->>type "msconfig"->> click the "Services" tab->> uncheck Ati Hotkey Poller->> Then Ok, then Restart computer.
hope this helps
chris
[email protected]
Dec 15, 2008 | Toshiba Satellite A105 Notebook
Need to get radio to show unlock code,has not been changed since put in car,can you help,thanks
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 31, 2008 | Audio Players & Recorders
Open Questions:
Computers & Internet Logo
Ekse
Marvin
Marvin
